Old 01-25-2007, 02:48 PM   #1
KiggerSTI
Member#: 93813
2005 STi
Post Witch tire should I go for on 05 STi?
rite now i have 3 choice of tires to pick...
1. Nitto INVO 245/40/17
2. Nitto NT555 245/45/17
3. Kumho ECSTA MX 245/45/17
these are the tires that im looking for... if any of u guys used this tires can u let me know pros, and cons.... thanks in advance!!!
KiggerSTI is offline   Reply With Quote
Old 01-25-2007, 05:43 PM   #2
_sti_05
Member#: 72313
16 STi
on stock rims? i kinda of on the same boat as you. i want to buy the kumbo's but looking at what size. if i should go wider or stay at 225. i have the rota torques tho 17x8. with 245 would u need to roll the fender?
sorry for jacking your thread =\
but i would go for the kumho's
_sti_05 is offline   Reply With Quote
Old 01-25-2007, 06:01 PM   #3
millerni
Member#: 80756
2005 STi
from everything I've read, there's no need to roll fenders with 245's on our STi's...oh, and yes to the kumhos
millerni is offline   Reply With Quote
Old 01-25-2007, 07:19 PM   #4
silverz06guy
Member#: 138316
bfg kdw g force all the way
silverz06guy is offline   Reply With Quote
Old 01-25-2007, 08:24 PM   #5
KiggerSTI
Member#: 93813
2005 STi
Post
yes on my stock STi Rim.
and witch tire has harder side wall from these 3??
Old 01-31-2007, 12:03 AM   #6
KiggerSTI
Member#: 93813
2005 STi
Post
bump!!
Old 01-31-2007, 12:11 AM   #7
Promis
Member#: 138755
What do you guys think are better? the stock STI tires Potenza RE72 or the Potenza RE960AS?
Promis is offline   Reply With Quote
Old 01-31-2007, 07:04 AM   #8
bluert
Member#: 126959
Have you look into Falken's I think the 452 or even the less expensive 512. That's what I am getting. The price is right.
They seems to have pretty good reviews from buyers at discounttire.com?
onhttp://www.discounttire.com/dtcs/refineTiresByBrand.do?rcz=43035&rc=OHCINT&sortOrde r=Model&typ=Passenger%2FPerformance&mf=Falken&so=H igh+Performance&so=Maximum+Performance&x=40&y=5 om
bluert is offline   Reply With Quote
Old 01-31-2007, 08:45 AM   #9
krzyss
Member#: 8365
2013 Ford Focus SE
Define better.
Krzys
krzyss is offline   Reply With Quote
Old 01-31-2007, 11:41 AM   #10
BlkWRXWag
Member#: 31821
2015 DS WRX
Buy a broom.
BlkWRXWag is offline   Reply With Quote
Old 01-31-2007, 11:43 AM   #11
fastgsx
Member#: 68238
Originally Posted by BlkWRXWag View Post
Buy a broom.
haha123
fastgsx is offline   Reply With Quote
Old 01-31-2007, 12:31 PM   #12
Promis
Member#: 138755
Originally Posted by krzyss View Post
Define better.
Krzys
Will give the most grip in various situations. Be it wet, dry, ice, snow etc.
Old 01-31-2007, 12:57 PM   #13
Mind
Member#: 109216
08 STI DGM
76-77 Lancia Scorpion(s)
All seasons. I would highly recommend against running the RE070 in snow/ice/cold rain.
Mind is offline   Reply With Quote
Old 01-31-2007, 01:01 PM   #14
krzyss
Member#: 8365
2013 Ford Focus SE
if snow, ice, dry, wet but cold then winter tires like LM-25 or Revo.
if snow, ice, dry, wet + warm dry, hot then all seasons like RE960.
Snow, ice, cold do not mix well with summer tires like RE070.
Krzys
Old 01-31-2007, 08:33 PM   #15
Promis
Member#: 138755
Thanks...I think I am going with the Potenza RE-01R. After doing a little more looking I think thats what I want......thanks again
Old 01-31-2007, 08:44 PM   #16
sigurd
Member#: 128721
2002 impreza WRX
psm
I would get Falken 452's over all three of those. For the very small amount of dry traction you would loose as apposed to the Kumho you will gain ten fold in wet traction and tire wear. Probably noise too.
Edit: Nvm I see you needed an all season.
sigurd is offline   Reply With Quote
Old 01-31-2007, 10:56 PM   #17
Mind
Member#: 109216
08 STI DGM
That's not something that will work in snow or ice... actually, it could end up being very dangerous.
Maybe something like the Pirelli PZeroNero M+S would be good for you. One of the best reviewed all-seasons when it comes to performance. Not the best for cold weather precipitation, but will probably get you to where you need to be safely.
Old 01-31-2007, 11:38 PM   #18
shemoves
Member#: 80663
2005 STi
Well, I can not comment on any of the tires specifically, but there are some things to consider. Unless you have a secondary 'normal' car, even in socal, you will want a tire that can at least be technically driven in the rain. Also, if this is your only car, do you ever go up to Bear/High in the winter?
I don't know much about Nitto, but Kumho seems to make a great tire for the money. A lot of people run MXs, but I dunno if it can take the abuse an STi can put out. As far as tire size is concerned, a 245/40 will handle better than a 245/45, but be less comfortable. Also a 245/40 will make your speedo read a bit higher than actual (they already read a little high), but a 245/45 will make it read a fair amount slower than actual.
shemoves is offline   Reply With Quote
Old 02-01-2007, 12:15 AM   #19
Thumper23
Member#: 11571
Well, he's living in So Cal. They don't exactly get much snow or ice there.
Thumper23 is offline   Reply With Quote
Old 02-01-2007, 07:58 AM   #20
krzyss
Member#: 8365
2013 Ford Focus SE
He said that ice and snow is important to him
and then he chooses almost R-compound tire. Strange.
Krzys
Old 02-01-2007, 03:17 PM   #21
Promis
Member#: 138755
Krzys
Na I was just looking for over all good tires. And opinions from people to see what yal thought. I never said I needed a tire for the ice and snow. Where I live we only get ice patches, it never completely ices over, and that is only every once and a while.
I did not want to rule any out before I knew more about what all was out there. Then once I found the RE-01R it is exceptional for everything but ice and snow. So as of now I am thinking of going with it, but am still shopping around.
Though I do appreciate everyone that has pointed me at a tire I have looked at them all...thanks
Thanks for looking out for me but in the Austin-Houston area we get some ice patches. I just didnít want to rule any out early in the game. What would you recommend for that area of Texas?
Old 02-01-2007, 09:10 PM   #22
KiggerSTI
Member#: 93813
2005 STi
i live in so cal and i really dont deal with snow, and ice. but in a way i go 2 snowboarding often in winter time. little bit of rain but i can deal with summer tire... so lets not talk about snow, and ice guys....
i just want feedbacks what u guys think about 3 different tires on the top of the thread.... if u have or had experienced with these tires let me know how u like it.... Thanks...
Tae
Old 02-01-2007, 09:54 PM   #23
krzyss
Member#: 8365
2013 Ford Focus SE
I think you did mention ice and snow.
Krzys
Need little help to decide what tire should I go for terror7 Tire & Wheel 2 05-09-2007 09:15 PM
How much should one pay for an 05 sti miraclemonkeywrx North West Impreza Club Forum -- NWIC 4 09-24-2004 02:09 AM
What alignment specs should I go for on stock car (for better handling)? ImportVenom Tire & Wheel 11 06-23-2004 04:23 PM
what size of all season tires should I get for a 2005 sti with stock wheels? eshtog Tire & Wheel 8 05-20-2004 09:48 PM
what sorta profile should I go for on my new tires? Bankheist Texas Impreza Club Forum -- TXIC 10 08-09-2001 08:06 AM
