Old 12-10-2009, 09:19 PM   #226
Fierysun
Member#: 82745
2005 Subaru STI
2003 EJ207 S204 Wagon
Originally Posted by mannyOlicious View Post
dude the car is STILL at hb speed and has been sitting there for months... its a wreck... jon and the team must have had it with the car and i dont blame them
Anyone know if this car is back on the road or not?
Fierysun is offline   Reply With Quote
Old 12-10-2009, 09:59 PM   #227
db2integra
Member#: 114765
2005 WRX STI
CGM
The cams are the first strange thing you see as each valve has 3 lobes. One central lobe for the low lift and 2 outer ones for high lift, longer duration. The bucket is where the magic happens. There is an inner and outer piston that rubs on both cam lobes all time. When the solenoid allows oil pressure to shoot through the oil gallery, it locks the inner piston to the outer piston/bucket, and bam, new cam profile. I have to say this is probably the coolest part of the engine. Word is this is a co-developed technology from Porsche and Subaru, sure enough the parts are made in Germany.
So the valvetrain works exactly like the one from my 1992 honda? Awesome!
db2integra is offline   Reply With Quote
Old 12-10-2009, 10:10 PM   #228
db2integra
Member#: 114765
2005 WRX STI
CGM
Originally Posted by SaabTuner View Post
Sodium filling does help keep exhaust valves cool, but I don't think it has a very big effect on what peak EGT the valve can take. I think it's done more to improve the amount of "thermal flux" the valve can take. IE: 4lbs/min airflow @ 1600*F won't generate nearly as much thermal flux as 40lbs/min @ 1600*F.
This is my reasoning: as I understand it, the problem with high EGT's in exhaust valves starts in the same way as it does with turbine blades (with which I'm more familliar), and that is that it stems from oxidation on the surface of the metal. EG: many steel alloys, both stainless and mild, are quite strong @ 1600*F in a vacuum.
Ergo, since I just can't see sodium-filling dramatically lowering the temperature at the outer-most surface of the valve, I can't see it dramatically increasing the EGT the valve can withstand. Saab used to use Sodium-filled valves, but switched to a higher-grade of stainless with a stellite coating, and then to a superalloy. Chrysler friction-welded superalloy heads onto ordinary stainless stems and then moved to full superalloy.
But, that's just my take on it and non-filled valves are indeed cheaper, assuming similar materials. So who knows?
Or, better yet, cylinder pressure x cylinder volume, since larger cylinders are less efficient, that would give you a good measure of how much subjective strain the cylinder is under.
It shouldn't be MUCH more efficient anyway, just a little ... if that. At least, that would be my guess.
Yes, engines with smaller bores tend to have more compact, and efficient, combustion chambers. The trade-off, however, is reduced valve curtain area and increased inertial forces for the relative increase in stroke.
Actually, though it's not really pertinent, my observations via MatWeb have been that most superalloys, especially common grades of Inconel, disperse heat fairly poorly compared to their "ordinary" stainless counterparts (with some notable exceptions). However, because they are so good at resisting heat, they last longer at high EGT's.
No way! I hope you're being sarcastic as I hadn't intended to come across as though I was laughing at you, or implying you were stupid.
I'm just sharing my opinion, and what facts I know, like everyone else, and I try to be light-hearted enough to laugh about it.
-Adrian
Matweb is the bomb! I can't believe how many hours I've spent on that site.
Old 12-11-2009, 09:35 AM   #229
metoo
Member#: 4764
2004 STi sold :(
forizzle
I've had my STi since 2003. I want more top end over the GT30R setup I have now, but I will not sacrifice any of the low end that I currently have to get it. I was really hoping the H6 would be a fairly reliable ready-kit option by now. I would rather hit my 04 with an H6 and nice turbo than go with a different car that I can get both low end and high end with, but, it's not looking too good. Seems something with a V8 is in my future (cant afford a GT-R).
metoo is offline   Reply With Quote
Old 12-12-2009, 12:26 AM   #230
burnin4
Member#: 59764
10 sec STi
10 sec Z06
C6Z
burnin4 is offline   Reply With Quote
Old 12-12-2009, 03:06 AM   #231
cbourbs
Member#: 117749
maybe you could afford a used noble m400 though. I really find that the gtr stats are really good and it is a very good car....but its missing that little bit of something. I found driving it, it was very boring...i like a car where there is lots of driving skill involved. I like something that you know if you push it to much it can bite your head off.
cbourbs is offline   Reply With Quote
Old 12-12-2009, 04:35 AM   #232
barkley2-6
Member#: 221961
I want this in my wagon
barkley2-6 is offline   Reply With Quote
Old 12-12-2009, 10:53 AM   #233
Ferraz
Member#: 173553
1996 Civic VTi
Dark blue
That is exactly how I feel! I'm more of a GT3 than a GT-R guy; more SK8 than PS3, You know?
Ferraz is offline   Reply With Quote
Old 12-14-2009, 11:14 AM   #234
wrxwangjack
Member#: 205472
Brog Warner?
wrxwangjack is offline   Reply With Quote
Old 01-04-2010, 06:48 AM   #235
Kosti
Member#: 118434
2003 Liberty B4
Did anyone get a price for this engine?
Kosti is offline   Reply With Quote
Old 01-04-2010, 01:59 PM   #236
Krang
Member#: 134272
Chapter/Region: HIIC
2002 WRX Wagon - WRB
ej207 v8 vf37
^^ A lot.
Krang is offline   Reply With Quote
Old 01-04-2010, 05:08 PM   #237
BigRigger
Member#: 129969
2005 Sti
Silver/Black
Do you have any spare kidneys or hearts just lying around?
BigRigger is offline   Reply With Quote
Old 01-06-2010, 03:18 PM   #238
metoo
Member#: 4764
2004 STi sold :(
forizzle
That's sweet for the track, but my car is a daily driver.
I wonder if PDX or anyone will bother with the new 3.6L engine, or will that be just more of the same headaches.
Old 06-11-2010, 11:30 AM   #239
blackhawk07
Member#: 246919
2007 WRX STI
for this engine i do!
blackhawk07 is offline   Reply With Quote
Old 06-11-2010, 12:02 PM   #240
edro*
Member#: 177764
2004 STi
Adriatic Blue
I too would love to do an H6 swap...
edro* is offline   Reply With Quote
Old 06-11-2010, 06:13 PM   #241
PERRINJeff
NASIOC Manufacturer
Member#: 74110
Man we get a lot of hits off this thread! Maybe we should this again! I am dying for a new crazy project!
PERRINJeff is offline   Reply With Quote
Old 06-11-2010, 08:15 PM   #242
BigRigger
Member#: 129969
2005 Sti
Silver/Black
3.6 Twin Turbo Build!!
DO IT, DO IT!!
Old 06-11-2010, 08:34 PM   #243
2002WRXSTi
Member#: 58647
02 Exedy Carbon
clutches SLIP and SUCK $!
DO IT, DO IT!!
DITTO!!!
2002WRXSTi is offline   Reply With Quote
Old 06-11-2010, 11:25 PM   #244
BigRigger
Member#: 129969
2005 Sti
Silver/Black
Old 06-11-2010, 11:37 PM   #245
piddyplace
Member#: 181942
2002 wrx
DO it I NEED TO SEE THIS DONE!!!!!!
piddyplace is offline   Reply With Quote
Old 06-12-2010, 12:09 AM   #246
colombo140
Member#: 97790
2008 STi
If only Subaru would have copied you for the 2011 line up.
colombo140 is offline   Reply With Quote
Old 06-12-2010, 02:55 PM   #247
1cleenwrx
Member#: 170542
08 AGILEbuilt-STI
93Soarer/01RSTI/06SPEC-B
now that would be what i call SPECIAL EDITION STI!!!
1cleenwrx is offline   Reply With Quote
Old 06-12-2010, 05:13 PM   #248
BigRigger
Member#: 129969
2005 Sti
Silver/Black
A 3.6 Twin Turbo build is pretty much the only build left that NOBODY has done in the suby world.
You guys did the EZ30R build
Countless big turbo builds
A few compound charged builds
The 3.6 is the final frontier, that is the voyage of the Cobb Tuning crew, to seek out new con-rods and new piston designs, to boldy go where no builder has gone before.
Old 06-13-2010, 01:07 AM   #249
Saintsp
Member#: 249258
its realli cool
Saintsp is offline   Reply With Quote
Old 09-07-2010, 11:48 PM   #250
wighti
Member#: 15345
2001 2.5RS GC6 sedan
S.T.M.
Just amazing!
I'd give anything to have that set-up in my GC.
wighti is offline   Reply With Quote
PDXTuning/Perrin H6 Info PDXTuning Proven Power Bragging 573 01-13-2010 09:04 AM
Car chase ends in front of my apt. building with bad results. Erudition Off-Topic 42 12-12-2005 07:38 PM
H6 Turbo EZ30R tear down/build up for BE Legacy PHATsuby Subaru Conversions 2 07-04-2005 04:27 AM
My Build, with dyno results Crash477 Normally Aspirated Powertrain 49 02-28-2005 05:04 PM
I own a WRC rally car! Just completed build up!! wrx_in_efx Texas Impreza Club Forum -- TXIC 10 01-22-2002 08:38 AM
