Old 02-04-2007, 07:01 PM   #126
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
www.surgelinetuning.com
Originally Posted by SaabTuner View Post
Less timing than even the 2.0? Same displacement/cylinder. It must be more efficient.
Don't need to worry about square inches. The twist of the crank will also affect it; not just the pressure. So the best method is probably hp/liter ... or maybe torque/liter. Either way.
Back to the regular discussion.
Here is a graph of the H6 timing I used in my first setup (GT30R).
This was about 420whp with at 13psi. Note timing ramped to about 17 degrees at redline, and about 12 degrees at torque peak. That is quite a bit less then either the 2.0 or 2.5L. While it is the same displacement per cylinder, it is smaller in bore. 89.2 vs 92.0, or 3% smaller in diameter. Even given the difference in bore it still has low timing given the output torque. I would also characterize the motor as pretty knock resistantant based on my tuning experience.
Jeff Sponaugle
sponaugle is offline   Reply With Quote
Old 02-04-2007, 07:33 PM   #127
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
Originally Posted by PHATsuby View Post
I am going to have to disagree on the thickness, from my eyeball and pictures I took, all of which are in my thread, the OEM sleeve from the H6 and the STi sleeve looked identical in thickness at the access hole. I don't see any reason why the taper would be much different internally but who knows as we never cut one apart, unless you have since then. THe exact numbers are somewhere in my thread but overall aluminum sleeve thickness at the top is only like a .7mm difference with much less hp per cylinder(I know you know this cause it was a point of discussion we had, haha). So yea, I agree it should hold up, just wanted to add that observation because originally we assumed and i was told it was a lot less thick, but no one had checked, so I checked and saw no difference. I could have been wrong though, but my eye is accurate enough to pick up on a 1/3 difference in thickness.
that is all. continue with technical discussion.
Ben
Since I have my case cracked open, I measured the thickness at the wrist pin access hole. On the H6 case it is right at .104" (2.64mm)s thick. (measured using a micrometer depth gauge. I don't happen to have an open 2.5L case here, but I will measure one when I get down to the shop.
Jeff Sponaugle
Old 02-04-2007, 08:01 PM   #128
CatfaceType-R
Member#: 81102
man..this is gonna get nuts...i am h6 envy already
CatfaceType-R is online now   Reply With Quote
Old 02-04-2007, 08:07 PM   #129
Numbchux
Member#: 71658
'84 Brat
4" lift and 29" tires
Originally Posted by sponaugle View Post
H6 Rods:
5.180" long (center to center)
.8665" small end diameter
2.1650 big end diameter
STI Rods:
5.138" long (center to center)
.905" small end diameter
2.1650" big end diameter
Note the H6 rod length is the same as the 2000+ SOHC 2.5L non-turbo rods. However the small end diameter is smaller then any other Subaru rod I know of.
So you could use US STI rods, but you would need to get a custom piston that us the STI pin diameter as well as a custom comp height since the rod is a bit shorter.
Jeff Sponaugle
very interesting. thanks!
Numbchux is offline   Reply With Quote
Old 02-05-2007, 02:21 AM   #130
SaabTuner
Member#: 67608
Jeff Sponaugle
Sounds about right. The motor is closer to a "square" bore/stroke and, judging by some of the more advanced other componants, I suspect the design is inherantly more efficient than the EJ20/25.
Have upgraded exhaust valves been considered for these builds? I don't think the EZ30 valves were really designed with turbo EGT's in mind.
SaabTuner is offline   Reply With Quote
Old 02-05-2007, 12:05 PM   #131
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
Yes, and here is a picture:
These were not ready in time for Jeff Perrin's build, but I did get them in time to put into my H6 heads. You are likly correct that the EZ30 vavles were not designed with turbo in mind as they are not sodium filled. These heads have custom made Supertec exhaust valves for the H6 EZ30R. ( as well as the Supertec intake and exhaust springs, retainers, etc)
I should also note the heads use the same spark plugs as the US STI heads (the deeper reach ones).
Jeff Sponaugle
Old 02-05-2007, 01:12 PM   #132
nxttruck2002
Member#: 90879
'07 STI valves are not sodium filled.
nxttruck2002 is offline   Reply With Quote
Old 02-05-2007, 01:36 PM   #133
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
True. I wonder if that was for a performance or cost reason?
Jeff
Old 02-05-2007, 01:58 PM   #134
nxttruck2002
Member#: 90879
Jeff
Some people said it's cost savings. Doug at TopSpeed said these ('07 STI) heads can make more power... So, I don't know....
Old 02-05-2007, 02:47 PM   #135
PERRINJeff
NASIOC Manufacturer
Member#: 74110
Numbchux,
STI rods will work with custom pistons as Jeff S said. This is a great way to save some costs on the build. The custom pistons wouldn't out weight the $1500 rods!
alachua,
Driveline is all stock! Except for the Exedy Twin plate, PERRIN shifter bushings, SS, and a PERRIN diff cover. But nothing to strengthen it up. At this point the axles, tranny and rear diff, hold up to this power level just fine, under road race type conditions. But under drag racing conditions, i know something is gonna give. Most likely its the axles!
PHATsuby,
I knew you would chime in on that! The overall isn't a huge concern as like you and I have talked about in the past, the HP per cylinder is still much lower than the 4 banger.
WRX2FAST4UFOOL,
Soon! But 1000WHP on the 4 cylinder will be a little tuff. Or at least they won't last very long at that. But who knows! If the 3.6L STI comes out, we will be the first to push to 1000, you wait!
SaabTuner,
Good point. HP in the end is all about Cylinder pressure, and maybe a better term would be Cylinder pressure per cylinder.
As far as more efficient, not sure on that. Maybe a little more, but my findings with timing curves are more agressive that Sponaugles. But, i have also been able to tune and push it a lot more than Jeff, so in the end he may find the same thing. But at low 14psi (No WI), i run 26 degrees at redline, and about 18-in the midrange, and i think there is more room to go at these boost levels.
At 22psi, i am seeing about 16 ramping to 22-ish. Not too far from the 2.0L. Also the timing after 6000 is something we are still pushing. Since i have no idea what the knock voltages are supposed to be, i am always playing with increasing timing to test the waters. So who knows more timing at redline!
The smaller cylinders will make for less timing overall, which is why they are still a little less than the 2.0L timing numbers, and way less than the 2.5L numbers.
With Jeff S's new build i think that he will be going a little higher than mine. Those exhaust valves are much better, and will get rid of heat a little better (thinner an made of Inconel). So slightly cooler combustion chamber, and a maybe a little more timing!
That is the funest thing about this engine, lots of uncharted territory. Lots of things to discover, and lots of myths to dispel!
PERRINJeff is offline   Reply With Quote
Old 02-05-2007, 03:01 PM   #136
PERRINJeff
NASIOC Manufacturer
Member#: 74110
nxttruck2002,
Our 07 STI made about 15WHP more than any other STI tested on the PDXTuning dyno. Maybe they found out that the sodium valves retain more heat?? OR then tinner valve behind the head is less restrictive? There is a reason why most race cars use normal SS or inconel valves.
Old 02-05-2007, 03:14 PM   #137
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
If you are laughing at me I apologize for not being on your same intelligence level. Feel free to continue your discussion with sponaugle since he is much more intelligent plus has those parts at his disposal and I do not at the moment.
Ben
Old 02-07-2007, 02:55 PM   #138
wrxburton
Member#: 83744
Have you guys ever thought about twin tubo setups? I am currently figuring out a plan of action and was thinking twin 3240's or a set of 3037's. Any reason you did not go that route? Is it because you would have had to remove to much stuff under the hood to get everything to fit? Also you mentioned you used a diferent radiator and STI thermostat and an extrenal oil cooler. Did you notice a difference in engine heat? Have you had any frivetrain problems with it? I know the clutch you have will hold but how about the axles and differentials? any trouble with them so far?sorry about all the questions but I would like to know what works and what dosent. thanks
wrxburton is offline   Reply With Quote
Old 02-07-2007, 06:44 PM   #139
Numbchux
Member#: 71658
'84 Brat
keep in mind, they're starting with an STi. so it's already got the 6MT and r180. pretty much the strongest drivetrain subaru has to offer...
also, check out PHATsuby's build in the legacy forum (probably will have to search). he's doing twin turbos on his EZ30R
Old 02-07-2007, 09:15 PM   #140
MikeCee
Member#: 136687
15 iginla, dup...
jdjfnjgvuicfjfdjfjdekugchvnmkz
MikeCee is offline   Reply With Quote
Old 02-08-2007, 03:54 AM   #141
SaabTuner
Member#: 67608
Jeff Sponaugle
Sodium filling does help keep exhaust valves cool, but I don't think it has a very big effect on what peak EGT the valve can take. I think it's done more to improve the amount of "thermal flux" the valve can take. IE: 4lbs/min airflow @ 1600*F won't generate nearly as much thermal flux as 40lbs/min @ 1600*F.
This is my reasoning: as I understand it, the problem with high EGT's in exhaust valves starts in the same way as it does with turbine blades (with which I'm more familliar), and that is that it stems from oxidation on the surface of the metal. EG: many steel alloys, both stainless and mild, are quite strong @ 1600*F in a vacuum.
Ergo, since I just can't see sodium-filling dramatically lowering the temperature at the outer-most surface of the valve, I can't see it dramatically increasing the EGT the valve can withstand. Saab used to use Sodium-filled valves, but switched to a higher-grade of stainless with a stellite coating, and then to a superalloy. Chrysler friction-welded superalloy heads onto ordinary stainless stems and then moved to full superalloy.
But, that's just my take on it and non-filled valves are indeed cheaper, assuming similar materials. So who knows?
Originally Posted by Jeff Perrin
SaabTuner,
Or, better yet, cylinder pressure x cylinder volume, since larger cylinders are less efficient, that would give you a good measure of how much subjective strain the cylinder is under.
It shouldn't be MUCH more efficient anyway, just a little ... if that. At least, that would be my guess.
Yes, engines with smaller bores tend to have more compact, and efficient, combustion chambers. The trade-off, however, is reduced valve curtain area and increased inertial forces for the relative increase in stroke.
Actually, though it's not really pertinent, my observations via MatWeb have been that most superalloys, especially common grades of Inconel, disperse heat fairly poorly compared to their "ordinary" stainless counterparts (with some notable exceptions). However, because they are so good at resisting heat, they last longer at high EGT's.
No way! I hope you're being sarcastic as I hadn't intended to come across as though I was laughing at you, or implying you were stupid.
I'm just sharing my opinion, and what facts I know, like everyone else, and I try to be light-hearted enough to laugh about it.
-Adrian
Old 02-10-2007, 05:13 PM   #142
SimAwd
Member#: 136586
2003 OBS
gray
Thumbs up
Realy nice job Jeff. Got some questions from a newby. Are you taking the car as a daily driver? If so,did you kept the car @ 600WHP? What about fuel consumption, more like a truck or not so bad? Driving it on slippery (we have snow in Quebec) or wet conditions hard to control? My other questions have been answered in the other 6 pages
Thanks, J.
SimAwd is offline   Reply With Quote
Old 02-13-2007, 03:57 PM   #143
PERRINJeff
NASIOC Manufacturer
Member#: 74110
wrxburton,
Phatsubys build is up and running, but not sure on dynoing it yet. You will have to bug him. I am excited to see what it does! We didn't go that route as this is still a big test, and it is much less complicated to just run one turbo. In the end, one or 2 can do the same job. 2 might spool a little better, but with in reason, the ultimate power, and spool can be be about the same.
Regarding the engine heat changing with the remote cooler, nope! the H6 runs pretty hot compared to the 4 banger, and there was zero difference in overall coolant temps.
Its a very strange engine in that regards. It runs pretty hot at 0-2500 RPM. Once you get above that the temps drop quite a bit. It might be do to how Subaru designed the passages. Since the engine normally runs in the 0-2500 range, they made it run warmer to be more fuel efficient. Once above this point the temps drop 10-20C! The T-stat doesn't effect this at all BTW.
MikeCee,
flkafqoiqoieriqanlkng, anjajfewoi. So, qrjeroijqoiferi.
SaabTuner,
With ya there!
I think that the Inconel is good just for that reason, resiting heat. I was not really thinking, but that is what i was meant. But who knows, its all speculation, the dyno runs will show the difference, if any. But is sure is cool to say "I have inconel valves"!
SimAwd,
It is driven every day! Since we started running out of fuel at 600, no. But it is running about 550-570 with the boost it is set to.
Fuel consumption is the same as before. But still worse than the 4 cylinder. To give you an idea, when the 4 cylinder was installed, i would get 220-ish MPT (miles per tank). With similar type of driving, i get 180-200. So its worse, but still much better than a Ford 350 gasoline truck.
In the wet, when boost hits, tires start to break free. So it is a little sketchy. But in the dry it is perfect!
Thanks for taking the time to read all the info. There is a lot there, and a lot to take in.
Old 02-13-2007, 09:33 PM   #144
subiescooby
Member#: 106303
'04 STi
WR Blue Pearl
wow... awesome write up... now just need some more pics and videos of dyno runs and driving around! I want one!
subiescooby is offline   Reply With Quote
Old 02-13-2007, 09:52 PM   #145
TJ
Member#: 41735
I'm on your lawn
do something about it
wow, what an amazing build
TJ is offline   Reply With Quote
Old 02-13-2007, 10:05 PM   #146
nxttruck2002
Member#: 90879
Jeff, since the '07 valves are not sodium filled, does that mean they are solid (not hollow)?
Old 02-16-2007, 07:27 PM   #147
mudshuvelz
Member#: 140257
2004 WRX
either jeff...what was your approximate cost, exluding labor for build?
mudshuvelz is offline   Reply With Quote
Old 02-16-2007, 07:29 PM   #148
mudshuvelz
Member#: 140257
2004 WRX
Either Jeff. what was your approx. cost for build? excluding your labor.
Old 02-16-2007, 10:34 PM   #149
UK Scooby
Member#: 92067
2006 STI
BLUUUUUEEEEEE !!!!!
subscribe
UK Scooby is offline   Reply With Quote
Old 02-17-2007, 02:58 AM   #150
SVXelerator
Member#: 78963
[quote=PERRINJeff;16937783]Numbchux,
nice to hear the STi rods will work. Did you use the ARP 260-4701 head studs?
Thanks
SVXelerator is offline   Reply With Quote
PDXTuning/Perrin H6 Info PDXTuning Proven Power Bragging 573 01-13-2010 09:04 AM
Car chase ends in front of my apt. building with bad results. Erudition Off-Topic 42 12-12-2005 07:38 PM
H6 Turbo EZ30R tear down/build up for BE Legacy PHATsuby Subaru Conversions 2 07-04-2005 04:27 AM
My Build, with dyno results Crash477 Normally Aspirated Powertrain 49 02-28-2005 05:04 PM
I own a WRC rally car! Just completed build up!! wrx_in_efx Texas Impreza Club Forum -- TXIC 10 01-22-2002 08:38 AM
