Old 02-17-2007, 02:33 AM   #151
I3izzy
Member#: 127809
Great build, love to see people trying different things than just EJ25 builds, keep up the great work!
I3izzy is offline   Reply With Quote
Old 02-17-2007, 08:22 PM   #152
El Gato
Member#: 110648
Chapter/Region: PRSIC
2005 Hydramist 35R82
93oct 479whp 456tq
Are you going to take this baby to the 1/4 track?
El Gato is offline   Reply With Quote
Old 02-18-2007, 11:53 PM   #153
sandmachines
Member#: 141143
check out atomic speedware for arp head studs
sandmachines is offline   Reply With Quote
Old 02-19-2007, 12:04 AM   #154
sandmachines
Member#: 141143
I am new to this site how come I can't see the pictures of this simi closed deck block?
Old 02-19-2007, 12:45 PM   #155
SVXelerator
Member#: 78963
Did you measure the stem length of the valves? It would be great if they are the same length as the valves in the EG33
SVXelerator is offline   Reply With Quote
Old 02-19-2007, 06:30 PM   #156
gordy
Member#: 23488
H6 STI 600hp 23mpg
Will you take my money and do this to my car?
You can have my car and the 20k up front just don't give it back until it's done.
Better yet - is the H6 beast going to be for sale?
gordy is offline   Reply With Quote
Old 02-20-2007, 03:53 PM   #157
roksax
Member#: 56126
2012 VW CC
Do you think it'd be possible to get 911 turbo-ish power levels and spool with this engine and a different turbo setup? Around 400/lb ft at 2000 rpms flat until 5000 ish would make a pretty sweet DD!
roksax is offline   Reply With Quote
Old 02-20-2007, 05:30 PM   #158
wrxburton
Member#: 83744
I love this thing. subscribed
wrxburton is offline   Reply With Quote
Old 02-20-2007, 06:01 PM   #159
xlsupreme
Member#: 120789
2005 USDM STi
I'm still f'n amazed at that torque spread... a mountain of torque basically from idle till arrested...
xlsupreme is offline   Reply With Quote
Old 02-20-2007, 06:52 PM   #160
themarxist
Member#: 104555
1996 VW Passat Wagon
TDi White
A large part of that is due to the variable geometry turbochargers, and it would be almost impossible to replicate with a conventional turbo, even if the engine itself is quite similar. However, it certainly seems feasible to mimic the performance of the 996 and earlier Porsches that didn't have this technology and didn't have quite as broad a torque band.
themarxist is offline   Reply With Quote
Old 02-20-2007, 08:10 PM   #161
roksax
Member#: 56126
2012 VW CC
Yeah, those variable geometry turbos seem to do it all. I'm no turbo guru, but maybe an appropriate twin-scroll turbo could achieve similar results?
Old 02-20-2007, 08:20 PM   #162
SMUwrx34
Member#: 98299
2005 STI
White on Black
Wow amazing.
SMUwrx34 is offline   Reply With Quote
Old 02-21-2007, 03:41 PM   #163
deathinacan
Member#: 76826
2013 delorean
P.I.T.A. to clean silver
Thumbs up
twin scroll turbo equal to the H6 Combo with the GT40?
well, in all answers you're going to get to that question, the basic theory is the same in any reply.
You cant beat displacement when it comes to spool up time - More airflow through the engine compensates for the flow or push of air through the exhaust housing in the turbo - regardless of twin scroll or not.
Regardless of the turbine size at either end, regardless of how many pipes you run into the exhaust housing of your turbo, the H6 simply pushes more air than the STi 2.5L - Therefore, you have more ability to push a larger turbo - Same Concept as in a Rotary (except with a lower RPM threshold), and in such engines as the RB26, and the 2JZ.
Ways to counter this in a smaller displacement engine are through more aggressive cam profiles, ported heads, and/or Stroker kits... or engine packages that come with all of the above - Often these kits are more expensive than actually just going to an H6 in the first place.. haha.. (in Theory)...
from my experience:
With a VF37, I've just about maxxed it out at around 320WHP, with peak boost reaching early at around 2800-3200 rpm's... thats with a rough tune, an AVO Wastegate, and 94 octane. This is just slightly larger than the VF39, and much smaller than the turbo kit I'm going to install (when I return from Iraq this summer) with a combination of a GT32R twin scroll(exact details under wraps) and some heav mods to the engine. ... hopefully the development of the car is with the help of Jeff *hint hint* and the ever-knowledgable guys at PDX Tuning...
The endstate - The H6 & GT40 combo cant be beat in terms of spool up time and powerband - Its simply awesome to see this actually be built and used on the road -
Keep up the awesome work Jeff and I'll definately be subscribing to this thread!! WOOT!
Kory Noble
www.myspace.com/projectalphaproductions
deathinacan is offline   Reply With Quote
Old 03-06-2007, 12:18 AM   #164
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
www.surgelinetuning.com
For those curious, I posted up some pics of my H6 assembly process. Both Jeff and I will be running at the Subiefest 2 here in Portland on April 7th btw.
http://forums.nasioc.com/forums/show....php?t=1215617
Cheers,
Jeff Sponaugle
sponaugle is offline   Reply With Quote
Old 03-06-2007, 12:29 AM   #165
EjtwentyfiveSti
Member#: 141279
05 STi
Built/sleeved/cam'd 35r
Looks so tedious, but very sweet!
EjtwentyfiveSti is offline   Reply With Quote
Old 03-06-2007, 07:07 PM   #166
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
wow awesome ! Seems like alot of work though. I wonder how long it will be before more people are running the h6 instead of the boxer 4.....
do we see a future trend coming on ??
IllNastyImpreza is offline   Reply With Quote
Old 03-06-2007, 07:58 PM   #167
Numbchux
Member#: 71658
'84 Brat
4" lift and 29" tires
I hope so. I'd be pretty happy if a little off-the-shelf aftermarket support was available by the time I get around to it
Numbchux is offline   Reply With Quote
Old 03-09-2007, 01:50 AM   #168
DoctorNick
Member#: 7022
heh, DC ITCA are
my rides
Cheers,
Jeff Sponaugle
Whats your thoughts on gearing with an H6 powered subaru? Are you rowing thru the gears just to get up to speed with all that torque?
DoctorNick is offline   Reply With Quote
Old 03-09-2007, 02:37 AM   #169
Numbchux
Member#: 71658
'84 Brat
that's a good question! I find my self doing that with this tranny that was designed for an EA82t (lo compression, 1.8l turbo...). and now with the ej22e behind it, I find myself shifting sooo often.
Old 03-09-2007, 03:39 AM   #170
wacerx
Member#: 96075
07 Schwinn
Candy green
wow i wish i had the money and time for a build like that. if there was a kit for this i would look into it in the future. i also wonder about the gearing with that kind of power. seems like i would be shifting every 2 seconds with something like that.
wacerx is offline   Reply With Quote
Old 03-09-2007, 01:46 PM   #171
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
Yes, the aftermarket is slowly catching up. Supertec now has pistons and valve train parts you can purchase, and Pauter can always make more rods. The work to notch and install the sleeves is quite expensive, but will certainly drop as more shops do it.
The short answer is yes. I am reving to about 6800 right now, and with the JDM tranny I am shifting all of the time. In fact I am in the process of doing a swap to the 07 gears just to get something a bit longer. With >300 lb-ft of torque from 3100 rpm to redline, the gears go pretty quick. Flooring the car at lower rpm results in wheel spin pretty quick, so a bit taller gearing would make things much better. I'll let you know how the 07 gears work out!
Jeff Sponaugle
Old 03-09-2007, 01:55 PM   #172
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
^ are the o7 sti gears longer ?
Old 03-09-2007, 02:14 PM   #173
silverwrx666
Member#: 86514
01 rsti,86 k10,lex
LS400,is350
I think 5th and 6th are
silverwrx666 is offline   Reply With Quote
Old 03-09-2007, 02:37 PM   #174
Chiketkd
Member#: 71634
In hibernation...
This is old news but here goes -
STi 2006 vs 2007 gears:
1st 3.636---3.636
2nd 2.375---2.235
3rd 1.761---1.521
4th 1.346---1.137
5th 0.971---0.971
6th 0.756---0.756
Final Drive remains unchanged at 3.90
Source: http://www.media.subaru.com/
Chiketkd is offline   Reply With Quote
Old 03-09-2007, 03:18 PM   #175
wacerx
Member#: 96075
07 Schwinn
Candy green
yes they are longer. i can edge out 60 in 2nd right at redline and just shy of 90 in 3rd. its nice to not have to shift as much as the older models. with that much power i dont know how much that will help though. im sure that the 07 gears will not be enough and taller gears will be tossed in again.
PDXTuning/Perrin H6 Info PDXTuning Proven Power Bragging 573 01-13-2010 08:04 AM
Car chase ends in front of my apt. building with bad results. Erudition Off-Topic 42 12-12-2005 06:38 PM
H6 Turbo EZ30R tear down/build up for BE Legacy PHATsuby Subaru Conversions 2 07-04-2005 03:27 AM
My Build, with dyno results Crash477 Normally Aspirated Powertrain 49 02-28-2005 04:04 PM
I own a WRC rally car! Just completed build up!! wrx_in_efx Texas Impreza Club Forum -- TXIC 10 01-22-2002 07:38 AM
