Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 03-09-2007, 07:26 PM   #176
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
^ sweet....now if you guys can just start totaling them so I can pick up your tranny for cHeAp
IllNastyImpreza is offline   Reply With Quote
Old 03-09-2007, 10:09 PM   #177
LiquidForce
Member#: 12811
2002 2.5l Wrx
517whp/516wtq (Stage pi)
Originally Posted by sponaugle View Post
The short answer is yes. I am reving to about 6800 right now, and with the JDM tranny I am shifting all of the time. In fact I am in the process of doing a swap to the 07 gears just to get something a bit longer. With >300 lb-ft of torque from 3100 rpm to redline, the gears go pretty quick. Flooring the car at lower rpm results in wheel spin pretty quick, so a bit taller gearing would make things much better. I'll let you know how the 07 gears work out!
Jeff Sponaugle
Are you swapping out the whole tranny or you fitting the 07 gears in the JDM case? If you are swapping what year is your JDM tranny?
Nevermind. I found your other post regarding the transmission. You wouldn't happen to have any info on the 02 JDM 6 speed?
LiquidForce is offline   Reply With Quote
Old 03-13-2007, 03:26 AM   #178
StinkerPeter
Member#: 143258
I came across the PDXTuning/Perrin Turbo H6 forums while researching desert racing. I am interested in running a Turbo EZ30R in a desert pre-runner/ sand car and the information here has been great. I have gone from a novice to a beginner in one night in terms of turbo tech with the 30R.
My biggest concern in the desert is reliability. What sort of "reliable" power can one expect to get out of a turbo powered 30R runnign on pump gas? I saw numbers near the 400whp mark (I think near 13psi or 16psi of boost), but they were followed by questionable reliability on a nearly stock motor (stronger pistons I believe). Also, I don't plan on running an Aquamist Water Injection System, but an intercooler is a must.
Peter
StinkerPeter is offline   Reply With Quote
Old 03-13-2007, 04:58 AM   #179
3.2L AWD Turbo
Member#: 141909
2004 GOLF R32T(GT35)
Black Magic Pearl Metalik
Originally Posted by gordy View Post
Will you take my money and do this to my car?
You can have my car and the 20k up front just don't give it back until it's done.
Better yet - is the H6 beast going to be for sale?
Seems like it might be a little better idea to find an OEM 6-cylinder car and build it for cost and complexity reasons.
Either way, this is an awesome project. Exactly what I would do if I had a Subaru!
3.2L AWD Turbo is offline   Reply With Quote
Old 03-13-2007, 12:10 PM   #180
gordy
Member#: 23488
H6 STI 600hp 23mpg
But I love my WRX
I've already spent so much. I figure the hole is so deep may as well go all the way to china
gordy is offline   Reply With Quote
Old 03-13-2007, 02:14 PM   #181
PDXTuning
Member#: 49831
2008 Get Tuned Now
Knowledge is Power
The info I posted was about the 04 US Tranny, but I actually have an 02 JDM tranny. It is coming apart today to see what will fit, so I will let you know.
Jeff
PDXTuning is offline   Reply With Quote
Old 03-19-2007, 10:41 AM   #182
andrewanderson
Member#: 64898
2005 Legacy GT LTD
That is probably the most common question. Well that and how much does it cost. Making something like this into a production kit is possible, but difficult. The wiring is specific to the make of the car, and the plumbing depends extensively on which turbo and which wastegate type you are using.
If a customer were to drop off a car and want to pick it up complete, I would think the labor alone would be more then $10,000, not including the engine, the $3000 cost to sleve it, the head work, the turbo, piping, the $2000 custom Hydra, custom Pistons and Rods, Valve train parts, etc. My guess is something in the $20K+ range.
Then factor in the multiple builds, the destroyed blocks, head damage, etc. One thing is for sure.. This isn't cheap!
I was still interested till you said 20k+
12k-15k I would consider. 10k I would easilly pay. Especially with the 3.0R Legacy coming out next year(I am not a Impreza fan).
You all did great work on our 05 LGT. 20k+ is ALOT of cash though
andrewanderson is offline   Reply With Quote
Old 03-19-2007, 06:17 PM   #183
gordy
Member#: 23488
H6 STI 600hp 23mpg
20k+ to turn your WRX into what's essentially a less sexy awd porsche turbo w/4 doors aint bad!
I'm trying to get a local shop here to consider doing it.
Old 03-19-2007, 07:17 PM   #184
wacerx
Member#: 96075
07 Schwinn
Candy green
just send the car up north to them and have it swapped. they have the experience with the build now and will get it done right in one try. such an awesome build that i hope to one day have done to my car.
wacerx is offline   Reply With Quote
Old 03-20-2007, 05:38 AM   #185
andrewanderson
Member#: 64898
2005 Legacy GT LTD
I am located in Germany and had them do the work on my LGT. We actually flew back there to buy the car and have them do the work.
And 20k is alot of money. Not sayign it is not worht the money. I am just saying that to save 20k I can live with 350HP our car is putting out now.
Old 04-06-2007, 01:12 PM   #186
PERRINJeff
NASIOC Manufacturer
Member#: 74110
Well its about that time.... The new 08 is coming out soon, so its time to sell the PERRIN H6!
I would be willing to take offers, or even engine trades?? I am up for ideas. But in case there is anyone serious about doing the H6 swap, this would be a good opportunity.
PERRIN H6 for sale HERE!
It will be at Subyfest this weekend if anyone would like to sit in it or maybe go for a ride..............
PERRINJeff is offline   Reply With Quote
Old 04-06-2007, 02:21 PM   #187
SIKDUBX
Member#: 145546
2004 WRX
Black w/ custom scratches
ridonkulous. i couldnt even read it, i was just looking for dyno numbers. i couldnt help myself.
SIKDUBX is offline   Reply With Quote
Old 04-06-2007, 05:15 PM   #188
andrewanderson
Member#: 64898
2005 Legacy GT LTD
Let us know if you sell it. I would be interested in seeing how much you all get for it.
Old 04-06-2007, 06:22 PM   #189
PERRINJeff
NASIOC Manufacturer
Member#: 74110
Will do!
Anyone know Jay Leno's phone number?
Old 04-06-2007, 09:00 PM   #190
tino
Top Scoob 019
Member#: 43630
2004 GT40R-built 2.5
604 whp @1.8 BAR on VP109
Originally Posted by myliberty View Post
keaniegenie,
PPG now make a 4speed straight cut dog engagement gearset for the 6 speed box. They call it their DRAG set.
yes, only 4 gears, but hydrogen bomb proof. and any ratios you want.
and only A$6,800. what's that, about US$4.38?
i know hollinger makes them also, roughly 10gs. but with 5 gears asfaik
tino is offline   Reply With Quote
Old 04-06-2007, 11:09 PM   #191
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
i would love to go for a ride in that thing!
This engine in a WRB coupe would be iLL!!!
mxpunk is offline   Reply With Quote
Old 04-06-2007, 11:15 PM   #192
wuuusaa
Member#: 92894
2015 Wrx
So what is going to be your new project car?
Old 04-06-2007, 11:26 PM   #193
2slofouru
Member#: 90539
95 L with ej257k
powa, Raven R6
Yes, and here is a picture:
These were not ready in time for Jeff Perrin's build, but I did get them in time to put into my H6 heads. You are likly correct that the EZ30 vavles were not designed with turbo in mind as they are not sodium filled. These heads have custom made Supertec exhaust valves for the H6 EZ30R. ( as well as the Supertec intake and exhaust springs, retainers, etc)
I should also note the heads use the same spark plugs as the US STI heads (the deeper reach ones).
Jeff Sponaugle
Could it be the sodium filled valves are used to shave inertial weight (to save hp) and the sodium is there to help dissipate the heat more evenly throughout the shaft since there is less metal to do it?
2slofouru is offline   Reply With Quote
Old 04-07-2007, 09:55 AM   #194
PERRINJeff
NASIOC Manufacturer
Member#: 74110
mxpunk,
Yes, it would, 500WHP in that light car would be fun!
ol'skoolwrx,
Well the 08 of course! But until it comes out, i will be turbo-ing the Elise!
Old 04-07-2007, 06:21 PM   #195
kheff46
Member#: 66739
2002 WRX wagon
any plans on the new bigger 3 liter mill going in ?
--keith
kheff46 is offline   Reply With Quote
Old 04-07-2007, 09:39 PM   #196
wuuusaa
Member#: 92894
2015 Wrx
Is it true that you guys were having problems with 6spd and how much tqe and hp the 40r is producing?
Old 04-09-2007, 09:11 AM   #197
aps2fast4u
Member#: 57871
2004 WRX
13.4 @ 102
Well, I hope the car goes to a worthy buyer!!! That is peanuts for an asking price considering the time/money/work put into that beast!! Good luck with the sale.
aps2fast4u is offline   Reply With Quote
Old 04-09-2007, 04:29 PM   #198
sadRS
Member#: 11328
2002 Impreza
2005 Legacy
MY favorite Write-up by far!!!
Great job guys!!
sadRS is offline   Reply With Quote
Old 04-09-2007, 08:03 PM   #199
PERRINJeff
NASIOC Manufacturer
Member#: 74110
--keith
Lets see, 3.6L in the new hatch might be kind of fun! We will see. As cool as the H6 is, and as powerful as it is, it not for everyone. Our new 08 most likely will be built to show off what anyone can do. But who knows, things change.
Never had any problems with the tranny. I wouldn't expect any issues with the drivetrain except maybe the axles.
Thanks! Its nice that some people understand the Time/Money/Work part of the "price equation"
Great job guys!!
Thanks! Look for more write ups on our cars as we build them!
Old 04-18-2007, 11:10 AM   #200
teamslow wrx
Member#: 18986
2002 wrx
sliver i Have 4 cats!!!
Jeff what does the motor Rev to??? Thanks
teamslow wrx is offline   Reply With Quote
PDXTuning/Perrin H6 Info PDXTuning Proven Power Bragging 573 01-13-2010 08:04 AM
Car chase ends in front of my apt. building with bad results. Erudition Off-Topic 42 12-12-2005 06:38 PM
H6 Turbo EZ30R tear down/build up for BE Legacy PHATsuby Subaru Conversions 2 07-04-2005 03:27 AM
My Build, with dyno results Crash477 Normally Aspirated Powertrain 49 02-28-2005 04:04 PM
I own a WRC rally car! Just completed build up!! wrx_in_efx Texas Impreza Club Forum -- TXIC 10 01-22-2002 07:38 AM
