Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 01-27-2007, 12:37 AM   #1
mikecoscia
Member#: 105846
2006 Impreza WRX STi
WRB w/gold rims
Default Having a hard time starting 06 STi in cold weather
This is really the first winter that I have had my car and I noticed anytime it is under 25F or so car has a really time starting and everytime it dies a few seconds after the first start. Have to take the key out and start it again and then its fine. What's the deal?
Only add on's to the car are stereo system, (800 watts) and the SPT performance pack.
mikecoscia is offline   Reply With Quote
Old 01-27-2007, 12:47 AM   #2
Nuke209
Member#: 108089
2003 WRX
NF Performance
weak suby battery
i believe the cca is only 300?
Nuke209 is offline   Reply With Quote
Old 01-27-2007, 12:48 AM   #3
mikecoscia
Member#: 105846
WRB w/gold rims
what do I have to do get an aftermarket battery?
Old 01-27-2007, 12:50 AM   #4
Nuke209
Member#: 108089
2003 WRX
NF Performance
that's what I did
did you check the fluid level in your battery
that can help too by topping it off
Old 01-27-2007, 01:00 AM   #5
mikecoscia
Member#: 105846
WRB w/gold rims
Will an aftermarket battery void my warrenty, what brand/model do you suggest. I don't know much about this stuff....sorry for the noobish questions.
Old 01-27-2007, 01:15 AM   #6
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
I dont think an aftermarket battery would void the warranty. Batteries should last between 3-5 years and your car is barely a year old.
mxpunk is offline   Reply With Quote
Old 01-27-2007, 01:58 AM   #7
PS_REX
Member#: 109907
2006 WRX Stg2
SGM
happens a lot from what i hear. try turning the key to "accessory position" for a few seconds before fully turning it to ignition. it'll get the fuel pump going before ignition.
PS_REX is offline   Reply With Quote
Old 01-27-2007, 02:04 AM   #8
fasterthanrayswrx
Member#: 48672
2005 Subaru
WRX
It's most likely your stereo system. The car needs a lot of power to start, that mixed with the cold weather puts a lot of straing on your weak battery.
In cold weather, the car may struggle a bit to start, but it'll start up on the first time. Mine does. today was under 20 degrees and it started up within 1/2 seconds.
fasterthanrayswrx is offline   Reply With Quote
Old 01-27-2007, 02:09 AM   #9
subielicious02
Member#: 133964
1991 legacy
gold brown champagne ish
optima is usaully what ppl go with. i have a red top and its never died on me. i have a 600 what system and i have had it run for about 3 hours and its started right up
subielicious02 is offline   Reply With Quote
Old 01-27-2007, 02:43 AM   #10
Mavrik
Member#: 90347
2013 BRZ & Imp 2.5RS
Yamaha FZ8
no an aftermarket battery will not void your warranty. It "may" restrict warranty on say an alternator if the battery went bad and caused the alternator to burn up while under factory warranty.
That being said also get a block heater, makes cold morning cranking easier.
Mavrik is offline   Reply With Quote
Old 01-27-2007, 02:52 AM   #11
HighRevimpreza
Member#: 90235
1993 GC ej255 swap
Originally Posted by Nuke209 View Post
weak suby battery
impossible lol... it has to be around 550 and they dont make 300cca battery for a 4 cyl
HighRevimpreza is offline   Reply With Quote
Old 01-27-2007, 02:54 AM   #12
HighRevimpreza
Member#: 90235
1993 GC ej255 swap
optima batteries are gel celled batteries so there lighter and they last pretty long.
Old 01-27-2007, 03:12 AM   #13
DumbUglyDragon
Member#: 61077
1993 WRX
OEM for 02-03 wrx was 330CCA..... so its not impossible. Dont know about now, though.
DumbUglyDragon is offline   Reply With Quote
Old 01-27-2007, 08:30 AM   #14
silverwrx666
Member#: 86514
01 rsti,86 k10,lex
LS400,is350
my 06 sti started up fine at 2 degrees the other day
silverwrx666 is offline   Reply With Quote
Old 01-27-2007, 09:13 AM   #15
mikecoscia
Member#: 105846
WRB w/gold rims
Can anyone give me an exact model number for the optima battery?
Old 01-27-2007, 10:08 AM   #16
mikecoscia
Member#: 105846
WRB w/gold rims
OKay looks like its the D35, but should I go red or yellow? Red is starting, yellow is deep cycling. Whats the difference?
Old 01-27-2007, 10:11 AM   #17
sheikthin
Member#: 77592
* missdawn = MILF
now with 25% less pistons
stock subaru batteries blow hairy goat nuts. mine completely died in less than a year. about 6 months after it was new it was noticable when trying to start it in either cold or warmer weather that it was struggling. finally one cold morning it totally died and didn't even have enough charge to run the fuel pump to pop start it.
sheikthin is offline   Reply With Quote
Old 01-27-2007, 10:33 AM   #18
Boxer112
Member#: 78751
2015 Sti (SOLD)
Crystal White Pearl
it happens to a lot of subie... no big deal..just start it again....also..no big turns when it is cold..
Boxer112 is offline   Reply With Quote
Old 01-27-2007, 10:33 AM   #19
jasonallenross
Member#: 125978
2002 WRX Wagon
To provide a counterpoint -- '02 wagon, still on original battery, no issues. I top up the water from time to time, but the car starts right up, even yesterday when it was single digits.
Disclaimer: the car is garaged most of the time, so the battery doesn't hit the really cold temps all the time ....
jasonallenross is offline   Reply With Quote
Old 01-27-2007, 11:33 AM   #20
mikecoscia
Member#: 105846
WRB w/gold rims
Do you have a high wattage stereo system in your car?
Old 01-27-2007, 11:49 AM   #21
06STINyC
Member#: 108704
I get my STi in
Sept.
Thank god I read this thread. I'm goin out for a battery. I'm going to most likley need it.
06STINyC is offline   Reply With Quote
Old 01-27-2007, 12:44 PM   #22
SQ3.0dotJP
Member#: 136330
# OCCUPY
theres cheaper, lighter, better batteries then optima
SQ3.0dotJP is offline   Reply With Quote
Old 01-27-2007, 01:17 PM   #23
subielicious02
Member#: 133964
1991 legacy
cheaper, yes, lighter, yes, better...i dont think so. name one.
Old 01-27-2007, 02:47 PM   #24
jasonallenross
Member#: 125978
2002 WRX Wagon
Nope. Stock. The only accessory is a tire pressure monitoring system.
I was more supplying the counterpoint that while batteries DO fail, I have one that's running fine after a few years of ownership. There are often a lot of people who show up with "OMFG the batteries are teh suck" comments while there are a lot of people running just fine.
There's a lot of stuff that can kill a battery quick -- your thumping stereo setup could help, especially if you combine it with sitting listening to it, cold weather, with the engine off. Also if (for some reason) the alternator can't keep up with the charging (you make short trips, it can't keep up providing the power to the stereo+recharge), you definintely could use a higher capacity battery.
There are a few major elements in the charging system -- the battery being only one. Luckly, it's easy to replace, (relatively) cheap, and there are definitely better ones out there than stock -- but if you have another problem in the chargins system you could just as easily be fixing a symptom, not the problem. The first step is to definintely march out there, clean it off, and check the water levels. If it's low, run down to the drugstore and get some distilled water and fill it up.
Old 01-27-2007, 03:37 PM   #25
Titanium
Member#: 10749
2006 WRX Wagon SGM
2006 BMW E85 3.0si
On my '02 I had no issues at all in the 40K that I owned the car. My '06 when it sits for a few days at the airport crew lot in cold weather, often takes more time than usual (which is sitting in the garage at home) to start. One day I just know it's not gonna start. I think I'm gonna swing for the Optima.
Titanium is offline   Reply With Quote
Car is having a hard time starting... aveera Electrical & Lighting 4 12-17-2008 09:56 PM
Why is my car having a hard time starting? SUBYDOODIE Electrical & Lighting 0 08-27-2007 10:37 PM
98 Legacy having a hard time starting jasona Normally Aspirated Powertrain 3 10-11-2005 03:38 AM
starting the car in cold weather creaquack Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 01-15-2004 08:14 PM
