Old 01-27-2007, 12:50 AM   #1
d40winker
Member#: 128010
2002 Impreza WRX
white
Default Threw P0442 code-emission leak
Hey I was driving home for work and I saw the light come on. My AP said it is P0442 and the manual calls it an "evaporative emission control system leak detected".
Im not sure what this is or what causes it. When I had my exhaust put on about three weeks ago I used the same gaskets, not sure if that could be the issue. I also thought earlier today I heard the turbo spool louder than usual which might be a leak. Any and all help is appreciated. Thanks
d40winker is offline   Reply With Quote
Old 01-27-2007, 08:07 AM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
...ya likely knocked a VAC hose off...has NOTHING to do with the exhaust system
Old 01-27-2007, 10:03 AM   #3
d40winker
Member#: 128010
2002 Impreza WRX
white
Well that happened about a week ago and I zip tied it back on there. Could it be from that even though it was awhile ago?
Old 01-27-2007, 08:51 PM   #4
blackfang
Member#: 131347
2007 Legacy 2.5i SE
98 Z/28, VN 900 custom
Check your gas cap, tighten it until it clicks and clear memory. If the code comes back on, take it in.
blackfang is offline   Reply With Quote
Old 01-28-2007, 12:02 AM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
....the gas cap is NOT the issue here, unless it was left off completely
Old 01-28-2007, 11:25 AM   #6
blackfang
Member#: 131347
2007 Legacy 2.5i SE
Ok you must be right then. Here are some things to check out then
http://www.obd-codes.com/trouble_cod...cted-small.php
Since you already know that if the gas cap is left loose in any way and not tightened until it clicks, it will set off the CEL with that code. You could possibly have something else bad in that system like the purge Solenoid, cut hoses or hoses with a hole in them.
Old 01-29-2007, 06:24 AM   #7
Uncle Scotty
Member#: 16200
OK buy Nates beans
....yeah...I already knew that
NEXT......
Old 01-29-2007, 06:18 PM   #8
blackfang
Member#: 131347
2007 Legacy 2.5i SE
Wow! Look at that, the first thing it tells you to do is check the fuel cap which is exactly what I said. I never said that was the ONLY repair that had to be made. It is a start and then you chimed in. In addition, the OP didn't state what other measures if any were done when I made my post.
If you want to be a smartass, then fine be one.
Anyone get a P0442 evap emission control turbocolin Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 09-27-2006 08:44 PM
Cel : P0442 Evaporative Emission Control System Leak Detected (small Leak)?? mrtrex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 05-09-2006 07:45 PM
P0442 code, only when cruising 48mpg Service & Maintenance 1 05-08-2005 04:46 PM
Threw P0442 DTC evL`WrX Service & Maintenance 4 04-13-2005 10:38 AM
P0442 Evaporative Emission Control System Leak Detected (small leak) Si2WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 05-01-2002 10:48 PM
