Old 01-27-2007, 01:44 AM   #1
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
Default would 17x8.5 wheels with a 48mm offset fit a GC8? fenders rolled on tein flex's
I have a guy who wants to trade wheels. I need wheels to clear my wilwood 6pot brakes on my GC and the wheels he has up to offer are advan RGII's in 17x8.5 with a 48mm offset.
Would these clear my brakes and Fit my car? the tires he has are 255's and I know they won't fit. I have a feeling these wheels are too wide for my car... I want to run 235/40/17
thanks
scobaru is offline   Reply With Quote
Old 01-27-2007, 02:54 AM   #2
D Money
Member#: 109948
. Most famous car
on Nasioc ever. :/
They fit on my car, but then again I got a GDB. Those are going to clear your brakes NP, mine clear a 355mm project mu bbk.
D Money is offline   Reply With Quote
Old 01-27-2007, 03:09 AM   #3
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
yah a wrx wagon is closer to a GC8 than the GDB
Old 01-27-2007, 05:58 AM   #4
Hoppie
Member#: 86150
'13 WRX Hatch
Schwarz
Im not trying to sway you. According to tire rack, you can ran 225/45/17 on a 8.5inch rim. If you pick a tire and click on specs it will show you the rims it fits. Here is an example of the Bridgestone RE050A pole position (look under the "rim width range" column):
http://www.tirerack.com/tires/Spec.j...irePageLocQty=
With these you would probably be okay on the fender, Im just not sure about the inside. I think BAN SUVS was running 235's on 17X8.5s but if I recall he had pulled fenders and spacers on the rear to a +44 offset.
Hoppie is offline   Reply With Quote
Old 01-27-2007, 06:06 AM   #5
scoobyimpreza
Member#: 11454
1998 impreza L
brillant red
kevin (bans) was running a 235/40 S03 (runs wide) on 17x8.5 +44 (to clear the inverted struts)
i say just put the tires on, get the wheels. role/pull and camber to fit it
scoobyimpreza is offline   Reply With Quote
Old 01-27-2007, 03:39 PM   #6
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
well I want to avoid spacers at all cost. and I'm more worried about the wheels rubbing on hte strut as much as on the fender. how do u go about pulling a fender?
Old 01-28-2007, 08:32 PM   #7
4wdrift
Member#: 1403
99 RBP GC8 Impreza
You should be good to go. I run 17x8.5 with 45 offset over Rotora's and
no rubbing at all. Your best bet is to put them on to see if they fit. A true
friend would do that for you right.
4wdrift is offline   Reply With Quote
Old 01-28-2007, 08:40 PM   #8
Andrew
Member#: 1170
2005 STi
I think it wont work. I used to own 18x8 with 40 offset and that was the limit on my GC8. I don't know how you would run an 8.5 with 48. 48 is perfect for 7.5" wide rims.
also I thought the widest you could go with a gc8 is 215 maybe 225s
Andrew is offline   Reply With Quote
Old 01-28-2007, 08:47 PM   #9
scoobyimpreza
Member#: 11454
1998 impreza L
brillant red
tell that to the GC owners running 235's and 245's, hell tell it to the auto-x people running even bigger
Old 01-28-2007, 09:13 PM   #10
Andrew
Member#: 1170
2005 STi
I don't remember what profile I was running when I had 17s but I'd imagine to run 235+ you would have to run 35 profile and that would mess with your tachometer's daily driving recording.
Old 01-28-2007, 11:46 PM   #11
moss
Member#: 10197
Pics?
I want to go wider....
Right now my plan is a 235/40/17 on a 17x7.5.
moss is offline   Reply With Quote
Old 01-29-2007, 12:04 AM   #12
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
I've easily seen 235's on Gc's and a few rare cases of 245's. but the part I'm unsure of is a 8.5 wide wheel I've seen 8inch wide work but I don't hear of 8.5.
I'm pushing the limits with 8.5....
also on my car I've ran 225's with out any issue, its begging for more tire lol
Old 01-29-2007, 12:05 AM   #13
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
he lives in another state thus I can't check
Old 01-29-2007, 11:50 PM   #14
4wdrift
Member#: 1403
99 RBP GC8 Impreza
Here is an old pic from when I had 40 series (slightly small) but the 45's I have now do not rub either...
Old 01-30-2007, 01:29 PM   #15
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
How much fender rolling/cutting are you willing to do?
Old 01-30-2007, 02:14 PM   #16
wptek9
Member#: 139238
yes but watch your camber
wptek9 is offline   Reply With Quote
Old 01-30-2007, 03:53 PM   #17
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
I just cut the inner lip of the fender right? I'll cut it all off it doesn't matter to me
Old 01-30-2007, 05:59 PM   #18
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Ok, then you can fit it, as long as you are willing to tweak the crap out of the fenders and even cut the fender liner in the front.
Will 17x8 rota torques with a 48 offset fit my wagon?? hella_sti Tire & Wheel 4 08-14-2007 12:46 AM
Socal: Yokohama Advan RCII (RC2) 17x8.5 Wheels with AVS Sport - $1350 wal.lin Private 'For Sale' Classifieds 31 10-13-2005 04:57 AM
Socal: (6) Yokohama Advan RCII (RC2) 17x8.5 Wheels with Rubber wal.lin Private 'For Sale' Classifieds 31 09-26-2005 05:17 PM
Will a 16x7 wheel with a 50mm offset fit my 05 2.5i Legacy? Edvig Tire & Wheel 9 11-05-2004 12:56 PM
