Old 01-27-2007, 11:09 AM   #1
WRXctasy
Member#: 125897
2006 WRX TR
Default Is this Bad ???
well i got a bubble in my right rear tire....so i replaced my rear two tires and left the front two tires be. will this affect my all-wheel drive system at all ? the front tires have a little or 50% left on them but are same exact size and all as the rear two being replaced...
appeciate any input thank you
WRXctasy is offline   Reply With Quote
Old 01-27-2007, 01:06 PM   #2
SQ3.0dotJP
Member#: 136330
# OCCUPY
i dont see a problem, may want to check ur alignment thats about it. its pretty common to change tires in 2 vice all 4.
SQ3.0dotJP is offline   Reply With Quote
Old 01-27-2007, 01:39 PM   #3
WRXctasy
Member#: 125897
2006 WRX TR
thats what i thought bc its both rear not something odd like one rear nad one front were it would cause uneven wear on the other tires....
Old 01-27-2007, 02:07 PM   #4
meglissWRX
Member#: 115965
not low enough for
nasioc mbr #001
nope you will have no problems other than a small alignment issue if any
meglissWRX is offline   Reply With Quote
Old 01-27-2007, 02:35 PM   #5
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
Are the 2 new tires the exact same make and model as the fronts? If not the total tire hight (outside diameter) might be different even if they are the same displayed size.
also the fronts having half the tread are going to roll slightly faster than the rears (slightly)
Now will this affect the center diff... i donno, but you might consider that.
Old 01-27-2007, 03:48 PM   #6
ivwarrior
Member#: 100610
MBP
I believe the official spec is 1/4 inch difference in circumference MAX.
ivwarrior is offline   Reply With Quote
Old 01-27-2007, 05:12 PM   #7
flukewrx
Member#: 75081
2003 WRX
Consult your Owner's Manual for the details. Typically though, with AWD cars, you will want to replace ALL 4 tires at the same time as to keep all of them within 1/8" - 1/4" difference or else you could cause a break-down in the AWD system. Since you have 2 tires that are about 50% worn out and 2 tires that are basically brand new with closer to 100% tread, I would suspect that the more you drive it, the greater your chances that something is going to malfunction.
flukewrx is offline   Reply With Quote
Old 01-27-2007, 05:19 PM   #8
WRXctasy
Member#: 125897
2006 WRX TR
well i plan on replaceing the front two tires within the next month or so , i dont plan on driving long like this i just want to make sure it's not going to be a huge problem and seriously break anything , they are all the same size tire , just a little bit more wear in the front two tires then the rear...
Old 01-27-2007, 07:01 PM   #9
ivwarrior
Member#: 100610
MBP
As was asked above, are they all the same BRAND/MODEL of tire? Just because they're all stamped as being the "same size" doesn't mean they are identical in size. I've seen visible differences in new tires that were marked as being the same.
Is this bad for the transmission? volkl23 Transmission (AT/MT) & Driveline 8 03-23-2004 02:00 PM
My installed STi injector spins- is this bad? Need4Boost Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 10-04-2002 11:23 AM
Arrrrgh... is this bad? jimhoyd Newbies & FAQs 2 04-18-2002 04:29 PM
Is this bad? Syntax Newbies & FAQs 21 03-13-2002 11:30 AM
My E-brake 360 HELP is this BAD! DarkLite Technical Forum Archive 3 10-06-2000 11:47 AM
