Old 01-27-2007, 12:38 PM   #1
scoobydrew06
Member#: 32951
Default Copper Gaskets vs. OEM Gaskets
Which gaskets are better? From my understanding copper will help prevent leaks more than the oem ones. The only retailer I know of is Crucial, Does anyone have experience with their copper gaskets? Or should I just stick with OEM to ensure proper size/fit.
thanks.
scoobydrew06 is offline   Reply With Quote
Old 01-27-2007, 02:06 PM   #2
02WHITEDUB
Member#: 96793
02 ProTuned TD04
Now with more clunks!
I'd say OEM. I'm convinced because I did a bunch of research on this a while ago - but I don't want to search for the threads that convinced me.
02WHITEDUB is offline   Reply With Quote
Old 01-27-2007, 02:31 PM   #3
AWDWRXLOVER
Member#: 50267
02 built hybrid
sr55/meth/sick speed
oem and copper spray
AWDWRXLOVER is offline   Reply With Quote
Old 01-27-2007, 03:26 PM   #4
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
www.turninconcepts.com gaskets not good enough? A gasket is a gasket is a gasket, get some and be happy.
Old 01-27-2007, 04:22 PM   #5
TheMadScientist
Member#: 23717
2005 Big red
IMO (and you can disagree but I have used all the aftermarket ones out there)Nope sorry, even worse than the copper ones.
Go OEM(if you can use them) or go home.
TMS
TheMadScientist is offline   Reply With Quote
Old 01-27-2007, 04:36 PM   #6
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
But you haven't used the TiC ones have you? Those are brand new and have only been on the market maybe a month. I too tried aftermarket and got bit on the old, old, old Subiedude gaskets. The TiC ones is different. If you PM me your address, I think I can get you some to put your esteemed eye on and I think you'll agree. Andrew at www.gearboxtech.com used probably the first set in the world to fix an uppipe leak. He had a car with an uppipe flange that looked like a Ruffles potato chip. Them TiC gaskets sealed it like crazy. Really idiot proof gaskets if you ask me and the only ones on the market that REBOUND, which is absolutely killer.
Old 01-27-2007, 04:59 PM   #7
TheMadScientist
Member#: 23717
2005 Big red
For how long did it stay sealed. In m experience with graphite gaskets they WILL seal initially but once they start to leak they just blow themselves apart really fast.
If the uppipe was that bad then it should have been replaced. There is no reason to put faulty parts on a car. Unless you are trading it in.
TMS
OEM head gasket vs. Aftermarket cooleys04 Built Motor Discussion 4 04-12-2009 10:52 PM
SCE Titan Copper Self Sealing head gasket NO O-Ring Needed for STI UV BN RXD Engine/Power/Exhaust 4 10-15-2008 06:01 PM
Thermotec copper wrap vs. non copper wrap. MartinSTi05 Built Motor Discussion 0 11-11-2007 12:56 PM
Copper RTV on UP gaskets?? silence2-38554 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 06-30-2007 12:47 PM
copper vs oem gasket for uppipe kkam030 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 06-12-2006 07:13 AM
