![]() Tire & Wheel Forum sponsored by The Tire Rack |
#1 |
Member#: 31908
South East
Vehicle:1999 Impreza RS Rally Blue |
I notice folks putting wider tires (than stock fitment) on the same wheel width. (e.g., I have stock '99 RS wheels that come w/ 205's, and have seend 225's on the same wheel.) So my question is, does this help or hurt performance, and if it helps, is there a point at which it's too wide to help?
#2 |
Member#: 82488
Vehicle:06 Lotus Exige Storm Titanium |
It depends. A wider tire will give you better lateral grip, but can increase unsprung weight. Most of the time when you see people going wider it's for the look, with an AWD car you're not going to see much performance difference between a 205 and a 225 in normal driving.
If you go with a wider tire, just make sure that 1.) it'll fit, 2.) it's not heavier than stock, and 3.) the overall diameter isn't taller than stock, which is the biggest no no. |
#3 |
Member#: 31908
South East
Right, I understand the general concept of going wider, but my main concern is going wider on the tire and not the wheel.
#4 | |
Member#: 25859
South East
Vehicle:1965 MGB yellow 2009 MB C300 |
#5 |
Member#: 109216
Vehicle:08 STI DGM 76-77 Lancia Scorpion(s) |
Generally, going wider on the tire alone will improve handling capability, but going wider on the tire and wheel will be better. Also, going wider on the tire but not the wheel may result in less steering response, even though handling has improved.
#6 |
Member#: 24447
SWIC
Vehicle:2010 Evo GSR GG |
#7 |
Member#: 36155
TXIC
Vehicle:03 WRX Platinum on Gold |
Hmm, I just posted in the tire review sticky about this. Then saw this thread.
I switched from 225s to 215s, and the handling feels much more precise on the narrower tire. Grip went down, feel, especially at turn in, went up. But I also went from old tires to new, so... You can read my post in the the tire review sticky. |
#8 | |
Member#: 24038
South East
We'd be saying the same thing, but I'd say to a point you'll gain grip, but your handling feel will drop off. For the street, its not worth going wider and losing that. On the track, if your wheel size is limited, you'll be willing to give up feel for outright grip. |
#9 | |
Member#: 109216
| Thread Tools | |
| Display Modes | |
| Wheels width vs. wheel weight on street car | CR22 | Tire & Wheel | 34 | 12-10-2008 12:33 PM |
| Tire Size vs. Wheel Width | njskatchmo | Tire & Wheel | 15 | 07-31-2006 09:54 PM |
| Wheel Weight Vs. Wheel Width ... What's more important ... | makofoto | Motorsports | 19 | 09-13-2004 12:26 PM |
| Offset vs. Wheel width question | bobafett | Brakes, Steering & Suspension | 5 | 10-08-2002 10:35 PM |
| tread width vs section width? | WRXhauls | Brakes, Steering & Suspension | 2 | 06-13-2001 07:12 AM |
