Tri-State Area Club
Go Back   NASIOC > NASIOC Regional Areas > Tri-State Area Forum
Old 01-27-2007, 11:07 PM   #1
redoktober_99
Member#: 17430
Sedona Red Pearl
Unhappy HELP HELP HELP Need help diagnosing a clutch problem....
I need some help to try and figure out what happened to my clutch. I was driving home tonight after getting the car washed. The car was behaving normally, no issue shifting, no sounds that were out of the ordinary. Suddenly, when shifting from second to third the clutch pedal went straight to the floor. No pressure and the pedal did not return. I got the car off the road and tried to diagnopse the problem.
Here are the symptoms:
No pressure when pressing on the clutch.
The pedal stays down.
You can pull it back up by hand
This would seem to say the system is low/out of fluid.
However, the fluid level is at the max.
Does anyone have any idea what the issue could be.
redoktober_99 is offline   Reply With Quote
Old 01-28-2007, 12:16 AM   #2
piker28
Member#: 22664
no idea on why this owuld happen
but to a car at work this happened to, they guy used a bungey cord on the pedal to the steering colum (was kinda funny like a racing clutch stiffness ha)
piker28 is online now   Reply With Quote
Old 01-28-2007, 12:24 AM   #3
99subi
Member#: 78118
2002 Corvette coupe
05 Legacy
i had this happen in my old 99 impreza once, i forgot why but it was an easy fix im pretty sure i had to tighten the cable back to the pedal as it got loose somehow, go check that out 2mrw its prolly it...
99subi is offline   Reply With Quote
Old 01-28-2007, 01:35 AM   #4
saab90089
Member#: 31998
89 900Turbo w/295K
97 Impreza L wagon
If there is fluid in the system I would question the clutch master or clutch slave cyclinder.
Ian
saab90089 is offline   Reply With Quote
Old 01-28-2007, 01:09 PM   #5
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
sounds like a bad clutch slave cylinder to me.
Old 01-28-2007, 03:43 PM   #6
trinistyles
Member#: 71627
180 Wrx/Fozzy/OBS
DGM/DGM/Silver S
Yes this can be the cause,I had the same think happen to me on my rs but it was the clutch fork,the pivot point on it broke and that why it stuck to the floor.my 1cent
Good luck.
trinistyles is offline   Reply With Quote
Old 01-28-2007, 08:31 PM   #7
Paisan
Tri-State Track Instructor
Member#: 197
'14 Touareg TDI '14
BRZ http://48hrs.info
Ian
Ditto.
-mike
Paisan is offline   Reply With Quote
Old 01-28-2007, 09:21 PM   #8
Jimpreza
Member#: 62459
2003 Wagon
same happened to my friends MR2 one time and it turned out to be the cylinder...Id go with that
Jimpreza is offline   Reply With Quote
Old 01-28-2007, 09:31 PM   #9
Murray
Member#: 11312
2009 Gray
Legacy 2.5i
clutch master cyl. - $94.02 37230FE060
clutch slave cyl. - $40.94 30620AA100
these are the 2 main parts that could fail...
just to give you a heads up
Murray is offline   Reply With Quote
Old 02-06-2007, 10:28 PM   #10
redoktober_99
Member#: 17430
Sedona Red Pearl
Default update
As it turned out, the slave went sometime in the past. This caused the master cylinder to work harder and eventually fail, but not before the clutch plate and flywheel went.
Me being the eternal cynic, when the mechanic told me all that needed to be replaced, I thought the guy was trying to rip me off. So I asked to see all the old parts before he put in the new ones. He was right.
Now I have a brand new clutch and can see the difference.
Need some help diagnosing a clutch problem rmang27 Transmission (AT/MT) & Driveline 2 06-25-2007 07:08 AM
Please help me diagnose my clutch problem redoktober_99 Transmission (AT/MT) & Driveline 0 01-27-2007 11:48 PM
Hey guys, someone please help me ~ New STI owner w/ clutch problem? Turb0STi Transmission (AT/MT) & Driveline 8 04-10-2005 01:26 PM
please help in desperate need of advice for starting problems y2k02scoob Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-14-2004 08:49 AM
HELP! exhaust n00b needs help for custom turbo-back juztin180 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 10-02-2002 12:45 AM
