Old 01-27-2007, 11:38 PM   #1
cdigerlando
Member#: 6070
2015 STi
Dark Gray Metallic
Default Oil and exhaust gas spewing out of breathers
I have a 92 SVX that has oil and exhast gasses coming out of all of the breathers. Crankcase and both camcovers. I disconnected them and checked. I'm also getting oil spewing at high load and RPM. Any idea what is going on? Bad valve seals?
cdigerlando is offline   Reply With Quote
Old 01-28-2007, 08:33 AM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Could be a bad PCV valve, pull it and check it or just replace it. If not that there could be internal engine issues causing excessive blowby.
Old 01-28-2007, 08:51 AM   #3
cdigerlando
Member#: 6070
2015 STi
Dark Gray Metallic
Default blowby
I'm thinking its blowby, as I vent everything to atmosphere. I am also turbocharging. Stand alone EMS, injectors. It is odd to me that both sides of the motor would start at the same time. I had one guy say it might be seals in my turbo, but the thing is pretty new.
Old 01-29-2007, 02:27 PM   #4
dude6033
Member#: 138806
Default check
your pcv valve. shake it, if it rattles, it is probably good. Could clean it out too.
dude6033 is offline   Reply With Quote
Old 01-29-2007, 05:52 PM   #5
cdigerlando
Member#: 6070
2015 STi
Dark Gray Metallic
As I said before, I do not use a PCV valve. I vent directly to atmosphere. Any other ideas. Other than this I am quite stumped. I probably need to do a bleed down test.
Burning oil and blowing blue smoke out of exhaust stikboy9 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 27 03-06-2007 02:39 PM
I threw a P0300 and a p0301 pulling out of the gas station last night... ScoobyNubieToo! AccessPort 10 08-24-2006 08:41 AM
Gas leaking out of exhaust flp_sde Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 12-13-2005 04:15 AM
gas flowing out of my downpipe NeaD Normally Aspirated with bolt-on Forced Induction Powertrain 13 08-06-2004 11:39 PM
Dino Oil and Regular Gas k44 North West Impreza Club Forum -- NWIC 15 04-03-2004 01:09 AM
