Welcome to the North American Subaru Impreza Owners Club Sunday March 1, 2015
Old 11-14-2008, 12:20 PM   #26
sharkmonkey
Member#: 118566
2005 WRX
Originally Posted by User Banned View Post
SEATBELT CHIME ELIMINATION
DIFFICULTY: 0.5 out of 10.
1. Insert key into ignition. Turn to "Accessory On" position. This is the last click before you would turn the key to start the engine. Your radio and annoying seatbelt chime will be ON.
2. Within 5 seconds of turning your key to "ACC ON", take your seatbelt clip, and INSERT & RELEASE into the buckle 20 times repeatedly. Each time you INSERT the clip into the buckle, it must "click" into place. You must push the release button to remove it. Complete this 20 times within 30 seconds.
3. When you have completed the 20 clicks, turn your key off and remove it from the ignition.
4. Start your car as normal. You will notice that the seatbelt indicator chime will sound six (6) times, then go off. It will NOT come back on until the next time you start your car, and it will stay on this pattern indefinately.
5. To re-active your annoying seatbelt chime, simply unhook your positive (+) battery terminal for 30 seconds to reset the ECU.
It may be different on the newer cars but on my 05 it is a lot simpler than this. Under the driver's seat there is a black sleeved wire lead that goes up to the seatbelt lock mechanism. All you have to do is unplug that and put a jumper wire on the wire harness side. Tape up if you want, done, and won't come back when you reset your ECU.
sharkmonkey is offline   Reply With Quote
Old 11-23-2008, 03:57 PM   #27
NickWRX
Member#: 15948
2001 2.5RS
317awhp-277ft./lb
Dude, this worked great! The seatbelt chime erase is the best. Thanks a million, I hated that damn thing! Def. much easier than unplugging the plugs or whatever. This was very simple. Thanks again,
NickWRX is offline   Reply With Quote
Old 01-02-2009, 03:37 AM   #28
Induced_Flow
Member#: 185731
2002 WRX Wagon
great write up thanks alot
Induced_Flow is offline   Reply With Quote
Old 02-24-2009, 12:58 PM   #29
johnnyd
Member#: 48041
2006 WRX
red
This is awesome. That beeping has been pissing me off since I got the car. Now it's gone and I can live in peace.
johnnyd is offline   Reply With Quote
Old 04-14-2009, 11:54 AM   #30
Wanna06Wagon
Member#: 204771
2012 WRX Hatch
Plasma Blue Pearl
Everytime I do this the chime is eliminated for the one time the car is on but wont stick after the car is turned off. I've tried it several times and it wont seem to remember it.
Wanna06Wagon is offline   Reply With Quote
Old 04-27-2009, 10:31 PM   #31
OneTime888
Member#: 162028
2005 Silver WRX STi
"Hey,got change for gas?"
I am in the process of disabling the DRL. I have taken off the glovebox but I don't know where the clip/plug is.
Where is DRL plug relative to the cabin filter?
I have an 05 USDM STi. The DRL was put in when it crossed the boarder.
Thanks
OneTime888 is offline   Reply With Quote
Old 04-27-2009, 10:40 PM   #32
vms150
Member#: 172917
2004 WRX
Should be the same for you
It is to the right and rear of the car relative to the cabin filter and it is tucked up in there pretty good.
vms150 is offline   Reply With Quote
Old 04-27-2009, 10:56 PM   #33
OneTime888
Member#: 162028
2005 Silver WRX STi
^Thanks,
I'll have to check again.
Old 04-27-2009, 11:02 PM   #34
habitatxskate
Member#: 197537
06 WRX
matte black
Originally Posted by WhiteFox View Post
The seat belt chime trick works awesome. I always have the habit of putting on my belt as soon as I get in any car, so I don't need to be reminded..
yeah its a pain in the ass, the car doesn't even need to be on
i always wear my seatbelt especially since the accident i was in, if i wasn't wearing it i'd be dead 100% for sure
habitatxskate is offline   Reply With Quote
Old 04-27-2009, 11:07 PM   #35
habitatxskate
Member#: 197537
06 WRX
matte black
you can actually just hold the release button down and push it in and out completely 20 times
Old 04-28-2009, 02:54 AM   #36
Ioku
Member#: 164864
95 Impreza coupe
This is what I did, it might be different on my older 95 but I didn't have to jumper anything I just unplugged it, also I disabled the key in ignition waring chime on my coupe I just pulled back the lower trim by the B piller and there is a single wire plug that goes to the door open switch just unplug that and no more chime.
Ioku is offline   Reply With Quote
Old 04-28-2009, 09:43 AM   #37
Subarudave09
Member#: 209316
14 XV
how to disalbel DRLs on the 08s imprezas
Subarudave09 is offline   Reply With Quote
Old 04-30-2009, 08:35 PM   #38
Loki2x
Member#: 174432
2004 WRX
I just did the DRL unplug. I tried doing it without taking out the glovebox first but you would need fingers from Honey I Shrunk the Kids. It took about 10 min with a screwdriver. Super simple. Thanks for the writeup!!!
Loki2x is offline   Reply With Quote
Old 05-01-2009, 12:58 AM   #39
Dex
Member#: 163775
2014 Ford Party ST
Dudebro red
No.
Thank you for searching!!!
Noobs take notes, this is how you research.
Dex is offline   Reply With Quote
Old 05-01-2009, 10:59 AM   #40
07SlvrScooby
Member#: 208406
2007 Impreza WRX TR
Great write up!!! dissabling the DRL and Chime works great. Thanks!!!
One ? i had was; what could possibly go wrong with the intake silencer delete? That was the first mod i did LOL
07SlvrScooby is offline   Reply With Quote
Old 05-01-2009, 04:30 PM   #41
kh15
Member#: 132400
i just de-soldered the little speaker on the circuit board to get rid of the chime! easy!
kh15 is offline   Reply With Quote
Old 05-01-2009, 05:12 PM   #42
steve
Member#: 4718
~ too
many to list
that's more my style. But for the life of me, I couldn't find the damn chime box.
Glad I found this thread again. This time I printed the instructions for the next time my ecu needs a reset.
steve is offline   Reply With Quote
Old 05-01-2009, 06:35 PM   #43
harryson
Member#: 205933
2005 WRX
well, just removed the snorkus..... p.i.t.a. that thing is massive. You can't see too much of a difference, but I do feel it a bit in 1st and second....
harryson is offline   Reply With Quote
Old 05-01-2009, 09:48 PM   #44
In2Deep
Member#: 10651
2013 WRX - Silver HB
04STI(sold) 06STI(sold)
Nice, this worked
In2Deep is offline   Reply With Quote
Old 05-02-2009, 02:05 AM   #45
kh15
Member#: 132400
its the little black box under the steering column with the gray and blue plugs. I didn't bother disconnecting the ecu, to much work lol
Old 05-22-2009, 06:43 PM   #46
beedee
Member#: 124727
is our DRL plug the same as the 06?
beedee is offline   Reply With Quote
Old 05-23-2009, 02:33 PM   #47
u2_m4r1n3
Member#: 189606
E46 M3
Ti Silver
Would it be similar for the 09 sti? as far as disabling the DLR goes.
u2_m4r1n3 is offline   Reply With Quote
Old 06-10-2009, 05:39 AM   #48
MASTERMIND65
Member#: 124539
2005 Hybrid, PPGs
I am job
Great write up, it really helped me a lot on dissabling the DRL. Thank you....
MASTERMIND65 is offline   Reply With Quote
Old 06-10-2009, 10:54 AM   #49
antonch
Member#: 170384
2006 Sti
Seat belt chime fix has to be the best mod I've done on the car.
antonch is offline   Reply With Quote
Old 06-23-2009, 11:11 PM   #50
Boostalot101
Member#: 192087
2007 WRX 2.5i
Silver Metallic
I tryed to disconnect my DRL lights and I think the connectors aree diff. colors in the 07's could this be true or did i just not look in the right spot?
Boostalot101 is offline   Reply With Quote
APS 65mm Intake TD04 wrx stock tmic GP MOTO intake silencer delete 02rex62 Engine/Power/Exhaust 18 03-04-2010 07:30 PM
Intake Silencer delete elbow SupraScooby Newbies & FAQs 20 08-25-2004 03:33 PM
Intake silencer delete fluttering noise heffergm Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 04-27-2004 06:18 PM
intake silencer deletes? chrislehr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 03-11-2004 12:22 AM
gpmoto Intake Silencer delete elbow Benjamin Tang Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 11-04-2003 05:10 AM
