![]() Tire & Wheel Forum sponsored by The Tire Rack |
#1 |
Member#: 95337
Vehicle:2008 Spec.B |
Has anyone done this? I've seen it done quite a few times but never knew exactly how it was done. I'd like to see if I can mount them myself using this method. I'm assuming I would have to spray the inside of the wheel with a flammable liquid (lighter fluid?), mount the tire on as far as I can get it on the wheel, then leave a thin stream of fluid on the ground so I can light it from a distance. Tell me if it's really this easy and what the actual risks are. I will have a bucket of water nearby lol
By the way, I searched for this under "fire" and "mount tire" but no luck.
#2 |
Member#: 119028
TXIC
Vehicle:2005 Legacy 2.5i SWP '06 WRX Wagon |
I've seen it done w/ ether, but I've never done it. The tire was off the bead and needed to be re-seated. The dude emptied a can of starter fluid into the tire around the wheel then held an open flame near it and *BLAM* the gas exploded and caused the tire to seat on the rim.
It is really dangerous to do and it isn't easy at all. |
#3 |
Member#: 70234
Vehicle:MY86 BMW E30 325 SCIC/NWIC tranplant (-_-) |
macgyver much?
#4 |
Member#: 138997
Vehicle:0000 Nothing |
idk about a spare...
#5 |
Member#: 95337
No, I didn't mean "spare" as in a donut. I meant that I just got a set of wheels and tires for dirt cheap and I'd like to try this out method. Anyone have a better idea or description on how to do it?
#6 |
Member#: 95337
Anyone else?
#7 |
Member#: 95337
This is everything I could find. I'd say most of the people in these videos had no idea what they were doing. No safety equipment, no protective clothing, and a lot of close calls lol.
http://www.youtube.com/watch?v=9hV6DFMXMIU http://www.youtube.com/watch?v=7yjkGRASVBM http://www.youtube.com/watch?v=_M0GNLvPmAg&NR http://www.youtube.com/watch?v=5_e1suUBoT0 http://www.youtube.com/watch?v=TK6o8Js2nZE&NR http://www.youtube.com/watch?v=QI0vi_z2Gys http://www.youtube.com/watch?v=nGj6dtJluKE&NR http://www.youtube.com/watch?v=RupgxQdhww4&NR |
#8 |
Member#: 48048
International
Vehicle:. Nasioc, serious Bidnazz |
it's like 20 bux to get tires mounted on "loose" wheels...
#9 |
Member#: 116596
South East
Vehicle:2012 STI SWP |
Holy crap I almost pissed myself watching those vids funny stuff. I def. would not do it like that
#10 | |
Member#: 119028
TXIC
#11 |
Member#: 89528
Vehicle:2005 sti crystal grey |
are you unable to bead them properly or does this just look like a cool way to do it ?
#12 |
Member#: 134326
International
Vehicle:1998 STi Type R Blue |
Make sure you pull the valve stem out, or you may get 100 psi in the tire really quick. I carried a propane torch with me when riding quads, and popped the bead a few times, it works well, but if you have a choice do it on the machine, I burnt up an eyebrow doing it. And for god sakes do not use lighter fluid, only propane or eather. and not a bunch. If you are out on a trail that is!
#13 |
Hoodbridge!
Moderator Member#: 560
Vehicle:2006 STi, '11 A4 Crystal Gray, Silver |
Please video tape when you try it. And make sure there's a someone around to call 911. This seems like such a bad idea, just to save a few $'s.
#14 | |
Member#: 131845
NWIC
Vehicle:1994 Acura Integra R-81 |
how exactly does it work ? if anyone wants to take the time to break it down to me. |
#15 | |
Member#: 103510
NESIC
Vehicle:2006 rex Aspen Brake Dust |
I have done it out on the trail when the compressor wouldn't set the bead. Pulling the valve core out of a 31" tire isn't nessesary as long as you don't go crazy with the fluid. I just bolted the wheel back up to the truck so it wouldn't go anywhere if a part of the wheel failed. When it is below 0*F you don't even need to spray anything into the tire, a lighter and some WD in the form of a flame thrower will do it! |
#16 |
Member#: 63411
Vehicle:2004 Impreza WRX White |
use spray ether spray inside tire for 5-10secs. then light using stick with flaming rags at the end. use stick about 4 ft long as so not to get burnt. this is what we do offroad to set beads. This works very well with larger tires but I am not sure how it will work with tires for your subaru.
#17 |
Member#: 95337
Yea, it was just an idea since I have extra tires and extra wheels laying around. I always wanted to try it but I don't want to be one of those idiots on Break.com missing fingers lol
#18 |
Member#: 95337
But really, has anyone personally tried this? I'd like to know the details of it.
#19 | |
Member#: 15617
Vehicle:2007 WRX STi Obsidian Black |
I've never used the ether method but I have seated the bead by wrapping a rope around the curcumference of the tread and using a pipe like a tourniquet to squeeze the tread so that it buldges out the side wall. Then use an air valve that flows a large volume of air to set the bead. Getting a tire to bead on the rim is the easy part (unless you are going for that stretched look), the hard part is getting the tire ON the rim. |
#20 |
Member#: 30342
#21 | |
Member#: 103510
NESIC
plus if you are in a car you aren't going to be where a towtruck can't get to you. Or if you are, you are most likely screwed anyway. |
#22 |
Member#: 132130
TXIC
Vehicle:2002 Ford F-150 Graphite Gray |
Those dudes in the artic do that stuff when there 4x4's tires fall off the rims. They run like 2 psi in there tires and its below 0 out..which forces them to use the lighter fluid trick
#23 |
Member#: 103510
NESIC
#24 |
Member#: 132130
TXIC
no, like ant-artica
i saw some show on the discovery channel or TLC and they showed those guys using that technique to re-mount the tires |
#25 | |
Member#: 103510
NESIC
Google Arctic trucks or Iceland trucks they do some pretty cool things, but somehow haven't figured out beadlocks ![]() |
| Thread Tools | |
| Display Modes | |
| Do you trust the dealer to mount tires on your wheels?? | GeneralTsou | Tire & Wheel | 4 | 05-29-2010 10:35 AM |
| WTB 04 STI spare tire or OEM wheel | Screwbal | NWIC Private Classifieds | 2 | 11-12-2009 02:34 PM |
| Mounting tires on Volk wheels | InfamousDX | Tire & Wheel | 1 | 12-09-2005 01:55 PM |
| BAIC GB on Rota wheels via Redstar Racing... | MPREZYA | Bay Area Impreza Club Forum -- BAIC | 76 | 03-02-2002 05:36 PM |
| Help Please... time to mount new tires on wheels | cfwdfw | North West Impreza Club Forum -- NWIC | 0 | 05-25-2001 06:30 AM |
