Old 11-28-2001, 03:48 PM   #1
imprezawd
Member#: 45
99 2.5RS-N (SOLD)
Question Will A Fuel Pressure Riser Give any gains??
What sup!
I know MY99 Rs runs pretty rice from the factory, and then modding it out with you average bolt ons will then tend to lean it out a little>> SO Will a Fuel pressure riser give me POWER
Let me know what you think.
I will end up probably buying a Weapon R FPR
imprezawd is offline   Reply With Quote
Old 11-28-2001, 04:04 PM   #2
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
no....not on a non pressurized car....you can get an adjustable fuel pressure regualtor and you might see a SLIGHT improvement...but not much.
jeremy
Old 11-28-2001, 04:22 PM   #3
bsquare
Member#: 1911
2000 Impreza 2.5RS
Silverthorn Metallic
Or just get a S-AFC since you aren't at the limit of the stock fuel system, so raising the pressure will just make it wear out faster.
bsquare is offline   Reply With Quote
Old 11-28-2001, 04:29 PM   #4
ylexot
Member#: 6878
2002 MBP 2.5RS
1994 GMC Sonoma
Question
What about when your car is fairly modified? i.e. CAI, headers, exhaust, hi-flow cat, cams (I'm getting there)
I think that setup would be stressing the stock fuel system. Also, would a fuel pressure riser be adequate, or is it a better idea to change the injectors (and anything else?).
ylexot is offline   Reply With Quote
Old 11-28-2001, 04:43 PM   #5
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
Default Re: Will A Fuel Pressure Riser Give any gains??
ROFLMAO! Runs rice from the factory! LOL
K... the FPR will help if you're outrunning the fuel supply. Untill then, it wont do you a bit of good. FWIW you're gonna need both a FPR and a safc (or similar) once you get over what you injectors can handle at stock pressure.
Originally posted by imprezawd
[BI know MY99 Rs runs pretty rice from the factory[/b]
Midwayman is offline   Reply With Quote
Old 11-28-2001, 06:03 PM   #6
imprezawd
Member#: 45
99 2.5RS-N (SOLD)
I met Rich
Old 11-28-2001, 06:09 PM   #7
bsquare
Member#: 1911
2000 Impreza 2.5RS
Me too, he's a great guy that Rich!
Old 11-28-2001, 07:03 PM   #8
Longshot
Member#: 2359
2001 Impreza 2.0 WRS
ROFL
Umm.. who says the 99's run rice... er rich from the factory? I was under the impression they lean out like mad once you put an intake on?
Korey
Longshot is offline   Reply With Quote
Old 11-28-2001, 08:25 PM   #9
scubaracer
Member#: 4909
1992 legacy 2.2Turbo
silver sports sedan
Default Ha ha ha!
Bsquare, you are funny.
The 98's and 99's will lean out with an intake and exhaust. that is why you will need fuel enrichment. buy an safc and maybe a fuel pump and tune it. then you'll be fine.
FWIW, I have a friend with an integra and he said he noticed very minimal gains with a new fuel regulator.
peace.........
scubaracer is offline   Reply With Quote
Old 11-28-2001, 09:12 PM   #10
Captain Ding
Member#: 5773
2003 Forester XS
Pacifica Blue
The reason that 98s and 99s run lean is because of the MAF sensor not reading airflow correctly. The fuel system itself is able to pump out all the fuel the engine needs up until around 200hp. Interference in the CAI where the MAF is located causes the MAF to send a signal to the ECU that indicates a lower volume of air than what is actually there. Since fuel is injected based on this signal, not enough fuel is pumped through causing a lean condition. All you really need to get around this is an SAFC.
Captain Ding is offline   Reply With Quote
Looking for Directions for Fuel Pressure Riser. yebokmj Normally Aspirated Powertrain 1 03-05-2001 09:47 AM
Fuel Pressure Riser Kit Delicious Tuning Technical Forum Archive 0 08-25-2000 05:25 PM
Weapon R Fuel Pressure Riser and Icon Delicious Tuning Bay Area Impreza Club Forum -- BAIC 0 08-21-2000 03:55 PM
Super AFC vs Fuel Pressure Riser (must read) Xscreamer Technical Forum Archive 2 05-16-2000 05:50 AM
How to contact bell eng... fuel pressure riser kit needed DJIMPREZA Technical Forum Archive 1 05-15-2000 03:04 PM
