Old 01-28-2007, 04:19 PM   #1
MAJRMSA
Member#: 22399
2002 wrx
250k mile high club
Default Help diagnose grinding noise
Hey,
I have a 2002 Wrx with about 105,000 miles. All service is up to date except the belts which I am planning on doing very soon. The car makes a grinding noise like a metal to metal noise that seems to be coming from the belts or the compressor in that area. When I turn on my A/C the noise somewhat goes away and when I depress the pedal I hear the same noise. I accelerate in 1st gear and the noise becomes louder as I go higher in the rpms. It's been doing this for a month now and I am thinking it's the compressor. Any suggestions would help. The only mod on the car is an up-pipe. Thanks
MAJRMSA is offline   Reply With Quote
Old 01-29-2007, 09:54 PM   #2
MAJRMSA
Member#: 22399
2002 wrx
250k mile high club
Any help is appreciated. Does anyone know the symptoms of a bad compressor?
Old 01-30-2007, 06:26 PM   #3
crampfan
Member#: 74321
2004 wrx wag
black UTEC stg 4
I would try adjusting the belts first, if the noise is still there, try removing one belt at a time and starting the engine. Try that first.
crampfan is offline   Reply With Quote
Old 02-25-2007, 07:58 PM   #4
buzzard
Member#: 84904
A shot pulley bearing sounds like metal on metal. You could have a bad idler pulley bearing, or a bad bearing in the compressor. Troubleshoot it by loosening the ac belt so it's just tight enough to take up the slack, but not enough to really load the pulleys. If the noise goes away, its a bearing in the compressor or the idler pulley. If it doesn't go away, tighten the a/c belt back up and try another belt.
buzzard is offline   Reply With Quote
Old 02-25-2007, 08:11 PM   #5
eb1888
Member#: 115226
2005 wrx wagon
Use a two foot or so piece of heater or other hose as a stethiscope to isolate the noise location.
eb1888 is offline   Reply With Quote
I need your help diagnosing this noise/problem Six Stars Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 03-21-2007 09:23 AM
Help diagnosing a noise ASAP (belts??) JLow03 Legacy Forum 10 02-27-2006 08:21 PM
need some help diagnosing a noise AndrewF844 Texas Impreza Club Forum -- TXIC 13 08-11-2005 04:22 AM
help diagnose tranny noise from my sti WRXout Transmission (AT/MT) & Driveline 2 12-22-2004 12:17 PM
Need Help diagnosing suspension noise USA1 Brakes, Steering & Suspension 3 11-24-2003 02:46 PM
