Old 01-28-2007, 06:30 PM   #1
fastlanerex
Member#: 133391
2004 boosted saleen
white
Exclamation Need help finding 04 wrx struts
I have searched for weeks and still cant seem to find struts for 2004 wrx. I can only find them for 02-03. Can anyone help me. I need struts and dont want stock ones. I cant do coilovers cause its my daily driver. I dont want a harsh ride.
fastlanerex is offline   Reply With Quote
Old 01-28-2007, 07:51 PM   #2
Tattoo!
Member#: 123057
04 WRX blue
Volk CE28N and Cusco lip
Koni inserts are the only ones out for the 04+ WRX. Kind of a PITA to do but it's also the best way to go. You can get them here http://alexperformance.com/products.asp?id=10&pg=2 they have good prices and the yare very helpful
Tattoo! is offline   Reply With Quote
Old 01-29-2007, 02:17 AM   #3
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
+1 for alexperformance and koni's
Arnie is offline   Reply With Quote
Old 01-29-2007, 03:50 AM   #4
cbarth3
Member#: 67249
2004 WRX
I have done the koni install and it is very easy to do. I would recomend having a dremel instead of trying to use a hack saw like the directions so.
I think i got mine from alexperformance and where very good to deal with. pm me if you want some pics of my install or have any questions if you go that route. also have some pics of my 50mm wheel studs that i installed
cbarth3 is offline   Reply With Quote
Old 01-29-2007, 09:02 AM   #5
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
What many people do is buy the 02/03 struts then get spacers for the rear struts to make them work with the 04+ top hats. There are several threads about it. The struts for the 02/03 are KYB, AGX, Tokico D spec, and Konis.
Tony
Old 01-29-2007, 12:25 PM   #6
subachad
Member#: 8488
1993 Impreza GCStyle
Teal
Tony
Could you please link to a thread that might even include pictures? I have installed springs on 2 06 WRX's that have had blown rear struts. One had 9000 miles and the other had closer to 15k. I have probably done about 5-6 spring installs on 06 WRX's so far.
Chad
subachad is offline   Reply With Quote
Old 01-29-2007, 12:34 PM   #7
REXtard04
Member#: 112928
2004 WRX Sedan
WR Blue
Would there be any benefit to replacing the struts with the OEM struts from an 04 STi? I need to replace my struts as well, but am torn between getting the Koni's, or getting the Tein Basic coilover system (which rides REALLY nice from what I've heard).
REXtard04 is offline   Reply With Quote
Old 01-29-2007, 12:35 PM   #8
subachad
Member#: 8488
Teal
Chad
Found a solution. Oddly, I couldn't find it by doing a search?
http://turninconcepts10.chainreactio...cca0dcf75da8dc
Old 01-29-2007, 05:24 PM   #9
fastlanerex
Member#: 133391
2004 boosted saleen
white
on alex racing is it 320 for all 4 or is that each?
Old 01-29-2007, 06:31 PM   #10
fastlanerex
Member#: 133391
2004 boosted saleen
white
nevermind its 612 for all 4 my bad
Old 01-30-2007, 12:28 AM   #11
cbarth3
Member#: 67249
2004 WRX
here is the link to my wheel stud install. did the struts at the same time.
http://forums.nasioc.com/forums/show...8#post12228828
pretty easy to do the strut install
drill pilot hole being careful as the gas escapes. this hole will be made bigger to accomodate the screw that holds the insert in to go through.
hack saw job gone bad on first strut
strut pulled from body
koni recomends measuring the distance from the top to the ridges on the body so you know where to cut the strut
we figured out after the first one that it looks cleaner and works better to dremel here.
frist strut ready to go back in. also installed group n strut tops at that time also.
couple shots up on the stands
Old 01-30-2007, 12:33 AM   #12
cbarth3
Member#: 67249
2004 WRX
crazy part is i just installed koni's in my rx8 which are a replacement shock altogether for $525 for all 4 shipped. was a lot harder gettting those in though.
Old 02-16-2007, 05:09 PM   #13
cbarth3
Member#: 67249
2004 WRX
anyone looked into the tokico d spec shocks for an 04?
saw those on a parts site and thought that might be another option. I was looking at going sti pinks and an adjustable shock other than the koni (don't want to gut again and mess up my stock struts)
Old 02-16-2007, 06:56 PM   #14
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
...dearGODINHEAVEN....
ya only NEED 2
2 spacers T-O-T-A-L
1 FOR EACH REAR STRUT
...how in the hell can something so damned simple be blown so completely outa the damned water into something so blitheringly stupid and complicated as this SIMPLE-STRAIGHTFORWARD MOD
Old 02-16-2007, 08:37 PM   #15
TurbojonLS
Member#: 38772
2 Cars, No Bling
ya only NEED 2
2 spacers T-O-T-A-L
And if you think anyone is paying $612 for the TIC spacers, you're whack.
It is $612 for 4 konis though.
TurbojonLS is offline   Reply With Quote
need help finding grp n strut mounts mofugga South East Region Forum 8 05-30-2008 04:24 PM
Need Help On 04 Wrx JDM Scooby Texas Impreza Club Forum -- TXIC 12 08-09-2006 06:01 PM
Need Help Finding a WRX RockChalkJayhawk Newbies & FAQs 3 04-09-2006 11:35 PM
I need help bad!!!!! 04 WRX wrxman4 Factory 2.0L Turbo Powertrain 13 11-29-2005 04:33 PM
Need Help With 04 WRX chinoswrx South East Region Forum 0 08-27-2005 11:45 PM
Message Board Statistics All times are GMT -4. The time now is 06:19 AM.
