Old 01-29-2007, 11:31 AM   #1
sub25rs
Member#: 4319
2000 2.5 RS
BRB
Default I Poured too Much Coolant in My Car
My coolant was a little low so I decided to pour a little in this morning and put too much in there (it is the pre-mixed kind). Is this going to ruin my car? I won't have time to get the excess out until I get home tonight. I have to drive about 20 miles before I have time to get it out. How do I get it out and will it harm my car if I have too much coolant in there?
sub25rs is offline   Reply With Quote
Old 01-29-2007, 11:52 AM   #2
Schlad
Member#: 25433
2003 WRX SW
all we'll drive
Where did you put the new coolant into? The overflow tank? If so, just use an old, clean turkey baster and suck it out. You might be able to unhook the tank and dump it out into a catch pan too.
Corrected: overflow tank is vented...
Schlad is offline   Reply With Quote
Old 01-29-2007, 12:18 PM   #3
rkramer
Member#: 118209
2015 WRX Limitec
Becareful driving today though. What happens is that the coolant expands when the car is hot and goes into the overflow tank. The coolant might build enough pressure in there to burst through the cap if your car gets too hot. Messy...
nope... that is wrong. the overflow tank has a vented lid, it doesn't seal. WORST case scenario is that once it gets hot, you might spill some coolant out of the overflow. NOTHING else, no bursting, no damage... I honestly wouldn't worry about it. If you have too much, it will vent a little out and fix itself.
as far as the radiator. you can't overfill it. if you have room to add it means you are low.
Old 01-29-2007, 12:26 PM   #4
sub25rs
Member#: 4319
2000 2.5 RS
BRB
It was in the overflow tank. Its about 2 inches higher than the full line
Old 01-29-2007, 05:41 PM   #5
Black07Impreza
Member#: 131390
2010 5 Door
Spark Silver
your fine.. it has a vent and on and once ur motor heats up its gonna spill out the extra out of your vent.
Black07Impreza is offline   Reply With Quote
Old 01-30-2007, 08:50 AM   #6
Corkfish
Member#: 39503
It's not like motor oil. If you overfill it just leaks out.
Corkfish is offline   Reply With Quote
Old 01-30-2007, 09:05 AM   #7
BryanH
Member#: 993
Just don't freak out when you smell it....because you are going to for a little while.
BryanH is offline   Reply With Quote
Old 01-30-2007, 01:24 PM   #8
volkl23
Member#: 39092
2004 WRX STi
Java Black Pearl
Don't worry about it. Won't hurt a thing.
volkl23 is offline   Reply With Quote
Old 01-30-2007, 02:00 PM   #9
Hayes
Member#: 11808
+3 for no problem
Hayes is offline   Reply With Quote
Old 01-31-2007, 02:15 PM   #10
sub25rs
Member#: 4319
2000 2.5 RS
BRB
Nice! Thanks guys/gals
Shop forgot to put coolant in my car after 30k mile service.. smash Service & Maintenance 21 04-17-2009 10:04 AM
is a vf 22 too much turbo for my car? dj_booduh Newbies & FAQs 24 03-27-2006 08:48 AM
Stoopid internet makes me spend too much money on my car. boneriffic Mid Atlantic Impreza Club -- MAIC 72 11-14-2005 05:14 AM
Poured too much oil. What to do? il96 Service & Maintenance 4 09-01-2005 02:15 AM
Too much oil in my 05 STi? Hollidark Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 05-17-2004 04:09 PM
