Old 01-29-2007, 11:42 AM   #1
MRGLASS
Member#: 66424
2005 STI
Default Cold start problem
My wife has an 05 LGT that has problems starting in the winter when the temps get really cold.....she has taken it to the dealer only to find out they couldn't find a problem (they left her car inside of the garage at the dealership to duplicate it, we told them we don't have a garage thus the car is always exposed). The problem is when I go out and start her car in the mornings (and the temps are 15F or colder) nothing happens, no click whatsoever, then wait approx. 5 minutes and the car fires right up...any ideas
MRGLASS is offline   Reply With Quote
Old 01-30-2007, 07:32 AM   #2
MYfirst00
Member#: 22928
2015 Legacy Limited
Lapis Blue
Hey Mr Glass. You might want to try asking your question over at www.legacygt.com since that site is made for that year car.
Ryan
MYfirst00 is offline   Reply With Quote
Old 01-30-2007, 08:34 AM   #3
MRGLASS
Member#: 66424
2005 STI
Thx Ryan
Old 01-30-2007, 08:42 AM   #4
SleeperLGT
Member#: 97125
2007 G35 Coupe
03 Wrx wagon
That sounds very strange, I would think the battery is shot, but there's no reason for it to start up right after when nothing has changed. Mine starts up everytime even at 15 below zero.
SleeperLGT is offline   Reply With Quote
Old 04-10-2007, 10:02 AM   #5
Kevinch
Member#: 56047
Unhappy Same Problem - Please help!
I know this is reviving an older thread, but my problem is very similar & I could really use some help!
1999 Legacy Outback SUS, 2.5L Twin Cam
115k miles
New Battery
When the temps are cold, this car (sometimes) will not start. Battery is good & strong - all the lights work & are bright, etc. When you turn the key, you'll hear a click, or possibly nothing. After a while or a few tries, the car will start.
This never happens when the car is warm, or the temperature is above freezing.
Anyone have any ideas?
Kevinch is offline   Reply With Quote
Old 04-10-2007, 11:58 AM   #6
spdracr00
Member#: 65823
1996 Impreza L
Red
check the battery cables. if you have a ton of gunk on your terminals it can travel up the cable and kill your power. i just had this happen in my 92. starts fine when its warm outside, but if its cold, forget about it. turned out it was a bad positive battery cable. plus its an easy check at like $10.
spdracr00 is offline   Reply With Quote
Old 04-12-2007, 11:30 AM   #7
Kevinch
Member#: 56047
spdracr00, thanks - I'll do that. I replaced the factory battery a few months ago (this car is a '99), but I did not replace any cables. I've also heard that these cars have poor grounds - any truth to that?
Old 04-12-2007, 12:03 PM   #8
spdracr00
Member#: 65823
1996 Impreza L
Red
yeah do a search for "grounding mod" and you'll see a ton of stuff about that. it will help smooth out your idle and might help with the starting issue, but who knows, it helps each car in different ways, but its worth it.
Old 04-13-2007, 09:43 AM   #9
MYfirst00
Member#: 22928
2015 Legacy Limited
Lapis Blue
nevermind
2.2L engine cold start problems wslk Service & Maintenance 13 10-30-2002 12:53 AM
Cold start problems wslk Normally Aspirated Powertrain 1 10-18-2002 11:21 PM
Cold start problem.. I Love Turbo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 08-15-2002 04:36 PM
Can the unichip cause cold-start problems MARTY5446 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 23 01-04-2002 02:00 PM
Cold Start Problems? Kapwi Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 08-10-2001 04:36 PM
