Old 01-29-2007, 12:26 PM   #1
BamBooI
Member#: 10945
2006 Evolution IX
Default New seals with timing belt replacement??
The dealership says when doing a timing belt replacement they also change out some seals. They said they change out the front main seal. Is this a common thing people do when replacing their belt? I did a search and it seems a lot of people change the water pump at the same thing which I am probably going to do as well.
BamBooI is offline   Reply With Quote
Old 01-29-2007, 05:19 PM   #2
John*G
Member#: 19562
95 coupe
red
Since it is apart, and the parts are cheap, I would put the pump and seals in.
Most people do would reccomend doing this.
Regards John
John*G is offline   Reply With Quote
Old 01-29-2007, 06:22 PM   #3
blackfang
Member#: 131347
2007 Legacy 2.5i SE
98 Z/28, VN 900 custom
I would recommend doing that and save yourself some money.
blackfang is offline   Reply With Quote
Old 01-30-2007, 01:54 PM   #4
BamBooI
Member#: 10945
2006 Evolution IX
can anyone name the exact seal?
Old 01-30-2007, 06:28 PM   #5
blackfang
Member#: 131347
2007 Legacy 2.5i SE
Crank seal and cam seals.
New, sealed : Timing belt tensioner jblaine Engine/Power/Exhaust 2 12-19-2008 05:44 PM
Water pump replacement at second timing belt replacement? doobie Service & Maintenance 1 10-19-2007 12:12 PM
Replacing Seals With Timing Belt? ulei eagle Service & Maintenance 13 08-13-2006 08:02 AM
What else to replace while doing timing belt replacement? the_glassman Normally Aspirated Powertrain 3 04-16-2006 11:58 AM
