Old 01-29-2007, 02:33 PM   #1
dude6033
Member#: 138806
Default Head gasket question
I'm tearing down the 98 outback 2.5 and the timing belt is exposed, intake lifted, valve cover off and exhaust out of the way. Before I remove the timing belt, my question is...Is there any special procedure prior to removing the camshafts to get to the head bolts? I'm concerned about timing issues. Do you just let the cams roll some until they stop, then remove the cams or should you hold the cam sprocket in place, then loosen up the cams? Any info would be great. thanx
dude6033 is offline   Reply With Quote
Head building and head gasket questions hybrid gti 2 Built Motor Discussion 21 04-11-2010 11:04 AM
Head gasket questions... otisfireboy Normally Aspirated Powertrain 23 07-09-2003 10:47 AM
Yet another head gasket question... MHC Normally Aspirated with bolt-on Forced Induction Powertrain 7 06-29-2003 02:40 PM
Head Gasket Question bgd scooby Normally Aspirated with bolt-on Forced Induction Powertrain 0 02-13-2002 06:08 PM
Pat Olsen - head gasket question once again. 2.5GT Normally Aspirated Powertrain 1 11-16-2001 01:32 PM
