Welcome to the North American Subaru Impreza Owners Club Saturday July 2, 2016
Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Drivetrain
Closed Thread
Old 01-29-2007, 05:21 PM   #1
Gruppe-S
Vendor Sales Rating: (65)
Member#: 23216
2006 949-457-1234
949-457-1234
Default 07 SPEC-C 6SPD/STI V6 RA Gearsets/ACT STI 6-pk Clutch Kits $679/Cusco LSDs/Tranny Mnt
Hey guys,
We have ONE STI 6-speed Tranny available!!
USDM SPEC-B 6-SPEED
-This transmission came from a special place in Japan. It is a late model 07 transmission practically brand new when it came in (ran on a tranny dyno). We have since inspected the entire unit and replaced all relevant seals, etc.
-Open front diff
-Viscious LSD (non DCCD)
-No front speed sensor (you will need to upgrade for WRXs or run aftermarket EM), ok for Legacys.
-USDM Gear Ratio
$3499 Shipped!!
STI V6 RA GEARSETS!!
-350 ft/lbs capable
-Lower gear ratios
-First Gear 3.083 /Second Gear 2.062 / Third Gear 1.545 / Fourth Gear 1.151 / Fifth Gear 0.825
-Includes Gears, mainshaft, shifterfork, custom speedo gear, etc.
-Cryogenically treated for better wear resistance
$1399 Shipped!!
Great Clutch Deals!!
ACT STREET DISC KIT + GRUPPE-S FLYWHEEL (15.0lbs) 04+ STI
Normal Price: $749.00
Sale Price: $679.00 Shipped!!
ACT 6-PUCK KIT & GRUPPE-S FORGED FLYWHEEL 04+ STI
-Recommended for up to 500whp
-Drivable and Streetable
-No CELs with Gruppe-s flywheel
ACT HEAVY DUTY 6-PUCK KIT + GRUPPE-S FLYWHEEL (15.0lbs) 04+ STI - $749.00 SHIPPED!!!
Exedy Hyper Single Clutch/Flywheel Kit (Stage 3) - 04+ STi
-Clamp Load: 2655 lbs/ft.
-Ideal for 20g, FP Green, and GT30r Turbos.
$PM FOR BEST PRICE!!!
Exedy Twin-Plate Clutch/Flywheel Kit (Stage 4) - 04+ STi
-Clamp Load: 2205 lbs/ft.
-Ideal for FP Red, GT30r, and GT35r Turbos.
ATS CARBON/CARBON CLUTCH KIT- 04+ STi
-Torque Capacity: 650 lbs/ft
-Pressure Increase: 1350kg
$1999 Shipped!!!
$2299 Installed!!!
JDM STI 6-SPEED CLOSE RATIO CONVERSION GEARSET
The USDM 6-speed transmission was compromised by stringent US regulations for cruising fuel efficiency. Sacrificed was the close ratio gearing of the JDM 5th and 6th gears. This kit includes a shorter 5th and 6th gears to convert your taller USDM 6-Speed Transmission to a true close ratio JDM STi spec gear box. Professional installation is recommended.
Ratios
5th Gear - 1.062 (0.971 stock)
6th Gear - 0.842 (0.756 stock)
$279 Shipped!!
CUSCO TYPE RS 1.5 way LSD SUPER SALE!
*1.5 way LSD
Activates under acceleration while the understeer is less than on the 2 way LSD.Recommended for drivers having difficulty with 2 way LSD understeer and one way LSD braking.
RS 1.5 WAY REAR 02+ WRX - $799.00 Shipped
Front, Center, 6-speed LSD's all available - please call or e-mail for more info!!!
Thanks!
Gary
[email protected]
510-783-5300
510-783-4300 fax
Gruppe-S is offline
Old 01-30-2007, 03:33 PM   #2
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Bump!!
Gruppe-S is offline
Old 01-31-2007, 03:29 AM   #3
socrates42
Member Sales Rating: (4)
Member#: 7747
2004 WRX 5door 5spd
08 E90 M3
that 07 spec b sti tranny, does it have the same gearing as the USDM 06 sti limited, and the new 07 USDM sti? (different from 06 sti)
socrates42 is offline
Old 01-31-2007, 06:09 PM   #4
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
It has the same gearing as the 06 STI but does not have the 1.1 center differential. It is a viscous center diff, so it does not need a DCCD management system, AND it is more durable than the DCCD center diffs.
Cheers,
Gary
Gruppe-S
Gruppe-S is offline
Old 01-31-2007, 09:55 PM   #5
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Bump!!
Gruppe-S is offline
Old 02-01-2007, 03:41 AM   #6
socrates42
Member#: 7747
2004 WRX 5door 5spd
08 E90 M3
does that center diff still allow for E-brake disengagement for rally like the USDM sti? or is that part of the DCCD system? (ie just lock the rear wheels and unlock the center diff)
Old 02-01-2007, 01:51 PM   #7
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
No that would be part of the DCCD system. Sorry about that. Thanks!!
Bump!!!
-Travis
Gruppe-S is offline
Old 02-01-2007, 02:10 PM   #8
Ru fan
Member#: 1605
1997 1.8L Brighton
NESIC TrackH0z member#1
Do you have any source for lightly used 5-speed gearboxes? I remember a few years back you had a bunch.
Ru fan is offline
Old 02-02-2007, 09:18 PM   #9
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Sorry about that we currently do not have any in stock. Let me know if theres anything else i can do for you. Thanks!!
-Travis
Gruppe-S is offline
Old 02-02-2007, 10:04 PM   #10
Pavoni8297
Member Sales Rating: (3)
Member#: 83651
08 Legacy Spec B
I need a center diff for my 03 WRX what do you have for me???
In a cusco? or STI?
Pavoni8297 is offline
Old 02-05-2007, 10:00 PM   #11
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Give me a call at (510)783-5300 and ask for me, Travis. I'll try to order something in for you. thanks!!
-Travis
Gruppe-S is offline
Old 02-06-2007, 10:10 PM   #12
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Bump!!!
Gruppe-S is offline
Old 02-08-2007, 08:54 PM   #13
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Bump!!!
Gruppe-S is offline
Old 02-09-2007, 08:06 PM   #14
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Bump!!!
Gruppe-S is offline
Old 02-10-2007, 03:48 PM   #15
crazyGC8
Member Sales Rating: (58)
Member#: 107421
MY00 RSTi-SOLD BUILT
MY04 STi-SOLD AG2 S13-DD
Pm'd you
crazyGC8 is offline
Old 02-12-2007, 02:11 PM   #17
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Bump!!!
Gruppe-S is offline
Old 02-13-2007, 02:14 PM   #18
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Bump!!!
Gruppe-S is offline
Old 02-14-2007, 10:04 PM   #19
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Bump!!
Gruppe-S is offline
Old 02-15-2007, 04:17 PM   #20
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Bump!!!
Gruppe-S is offline
Old 02-16-2007, 02:52 PM   #21
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Bump!!!
Gruppe-S is offline
Old 02-17-2007, 07:02 PM   #22
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Bump!!
Gruppe-S is offline
Old 02-19-2007, 08:23 PM   #23
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Bump!!!!
Gruppe-S is offline
Old 02-20-2007, 02:21 PM   #24
Altaic
Member#: 31098
I'd like one of your DCCD units to swap into my 05 WRX if the price is right. Used would be better, since I can't spend $7k on a new setup. And if you want to trade for my 5-speed tranny w/ ~19k miles, that would be excellent. Please PM me if you're interested.
Altaic is offline
Old 02-20-2007, 07:26 PM   #25
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Hi, unfortunately we can't accept trades at this time. I do have 2x DCCD 6-speed units coming in on the next Japan container, please give us a call if you're interested.
Thanks!
Gary
[email protected]
510-783-5300
510-783-4300 fax
Gruppe-S is offline
Closed Thread
FS: v6 RA Gearset Cryo Treated 6,500 Miles srREXed Drivetrain 32 11-24-2009 03:28 AM
03 trans case w/ sti type RA gearset, act clutch, and act lightweight flywheel-feeler 03SuBbYWrX Drivetrain 5 07-07-2008 10:29 AM
STI V6 RA Gearsets ARE BACK/ACT STI 6-puc Clutch Kits $679/Cusco LSDs/Tranny Mnts Gruppe-S Drivetrain 15 01-29-2007 03:19 PM
STi V6 RA Gearsets, Cusco Motor Mounts, ACT and Exedy Clutches and Flywheels Z1 Performance Drivetrain 13 10-10-2005 06:15 PM
STI Type RA Gearset and STI Helical LSD with Excedy Organic Sport Clutch=Good Setup? 2.2gotboost Transmission (AT/MT) & Driveline 5 03-29-2004 08:55 PM
