Old 01-29-2007, 05:45 PM   #1
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
News New Log-Analyzer program comming soon!
I have been hard at work in the past few weeks/months getting a new program out there for the masses to use for analyzing logs of all varieties. I hope it will be ready in a few weeks but for now I am going to release a beta version for those who are interested. I am making a few last-minute tweaks to the website and then I will release the address for you all to download the beta. If you encounter an error or have a suggestion, please do not pm me. Instead, send me an email via the forums.
If you would like to prepare your computer for this program you should go ahead and istall the .NET 2.0 framework now to get it out of the way.
Jeff C
NavyBlueSubaru is offline   Reply With Quote
Old 01-29-2007, 05:54 PM   #2
Tap
Member#: 21893
2002 WRX w/STi swap
If it is good as your UTI, then this could be interesting.
Tap is offline   Reply With Quote
Old 01-29-2007, 05:58 PM   #3
LastResort
Member#: 99289
Will this work with the tactrix cable?
LastResort is offline   Reply With Quote
Old 01-29-2007, 06:40 PM   #4
Crystal_Imprezav
Member#: 84105
2005 Super Slow STi
CGM
I would be interested. I use everything to log right now including streettuner, ecuexplorer, delta dash, and enginuity. This could help you make sure it runs well with everything. Let me know when your ready.
Crystal_Imprezav is offline   Reply With Quote
Old 01-29-2007, 07:18 PM   #5
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
It will work with virtually ANY log file, all you need to do is generate a 'definition' for it. They are super-easy. Built-in is support for ECUExplorer and of course UTI.
Jeff
Old 01-29-2007, 07:59 PM   #6
LastResort
Member#: 99289
That makes sense, that it supports importing the logfile, rather than the logging itself.
Old 01-29-2007, 09:16 PM   #7
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
Ok guys, here it is. Please read the read-me before using the program. I tested the install and it works on my computer so hopefully it will work for you all. If you like the program, please show your support!
Click Here For Program Page!
*Note: I just tested it on my laptop which is 1024x768 and the X-Y charts get cut off at the bottom. I developed the software at 1680x1050 so I guess that was an oversight(no pun intended). If you are at this resolution I guess you can just turn on panning or a virtual resolution or whatever it is called.
Jeff C
Old 01-29-2007, 10:44 PM   #8
druxboyz
Member#: 16827
2003 WRX(Sold), Z4
interested in checking out your beta, but.. i'm not really sure which .net 2.0 i should be installing for win xp.
There's:
* Download x86 version
* Download x64 version
* Download IA64 version
Or, can you just link up which one to dl, thanks
druxboyz is offline   Reply With Quote
Old 01-29-2007, 11:05 PM   #9
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
99% of people will get the x86 version. You can get it by clicking doing the "Windows Update" then selecting "custom" and you will see the .net 2.0 in there under the category "Software, Optional".
This link might also do it:
http://www.microsoft.com/downloads/d...DisplayLang=en
Jeff
Old 01-30-2007, 01:46 AM   #10
WRXRallyBlue
Member#: 48831
2002 Protuned Wagon
Bugeyes Forever
Good for you, man. Thanks for all the hard work!
WRXRallyBlue is offline   Reply With Quote
Old 01-30-2007, 02:42 AM   #11
crashtke
Member#: 120912
Hmm I just get an error every time I try to run it. I did install .net 2.0 I am now trying 3.0 x86 just to give it a shot. Nope nothing with that either....not sure of the reason.
crashtke is offline   Reply With Quote
Old 01-30-2007, 06:41 AM   #12
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
what is the error? Click the 'details' button to get a description of the error.
Old 01-30-2007, 07:13 AM   #13
Tap
Member#: 21893
2002 WRX w/STi swap
Here is what I get...
EventType : clr20r3 P1 : log analyzer.exe P2 : 0.8.2585.37692
P3 : 45bea5c8 P4 : log analyzer P5 : 0.8.2585.37692 P6 : 45bea5c8
P7 : 18 P8 : e9 P9 : system.invalidoperationexception
Old 01-30-2007, 07:17 AM   #14
cr125r
Member#: 104908
2005 Lotus Elise
I get an error too.
it says this:
cr125r is offline   Reply With Quote
Old 01-30-2007, 01:11 PM   #15
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
What OS are you 2 running?
Old 01-30-2007, 01:13 PM   #16
cr125r
Member#: 104908
2005 Lotus Elise
XP fully updated
Old 01-30-2007, 01:25 PM   #17
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
It is very strange because it works just fine on my laptop which has xp home on it and I expect it would react the same as anybody elses computer. The error might be associated with a fade-in that the program does, I can eliminate that and see if the problems go away for you guys. I'll update the program later today and you can re-download and see if it works.
Jeff
Old 01-30-2007, 02:02 PM   #18
crashtke
Member#: 120912
Event type: clr20r3 P1: log analyzer.exe P2: 0.8.285.37692 P3:45bea5c8 P4: log analyzer P5: 0.8.2585.37692 P6: 45bea5c8 P7:18 P8 e9 P9: system.invalidoperationexception
I am using windows Xp Pro with all the updates as well.
Old 01-30-2007, 03:11 PM   #19
WeldingHank
Member#: 98645
2002 WRX Wagon
I get the same error report as the rest.
WeldingHank is offline   Reply With Quote
Old 01-30-2007, 03:57 PM   #20
Tap
Member#: 21893
2002 WRX w/STi swap
XP Pro with all updates...
Old 01-30-2007, 04:32 PM   #21
MidRex
Member#: 32841
2007 STI (Sold)
03 WRX FP Green PPG (RIP)
Got same error also.
MidRex is offline   Reply With Quote
Old 01-30-2007, 07:05 PM   #22
Airboy
Member#: 72829
2006 WRX
2015 WRX
I run XP pro with Athlon64 and windows just give an error about having to shut down the program...
Airboy is offline   Reply With Quote
Old 01-30-2007, 08:40 PM   #23
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
Ok, I uploaded a modified version. Go back and re-download and see if it works. This is probably something to do with the dependency files. Once this is sorted out it should be smooth-sailing.
Jeff
Old 01-30-2007, 09:11 PM   #24
Fred Fredburger
Member#: 2539
2005 STi WRB/Gold
Now w/Íhlins... Yessss!!!
I'm still getting the error after downloading the newest from the site (v 0.8.2586.32961)...
EventType : clr20r3 P1 : log analyzer.exe P2 : 0.8.2586.32961
P3 : 45bfd440 P4 : log analyzer P5 : 0.8.2586.32961 P6 : 45bfd440
Fred Fredburger is offline   Reply With Quote
Old 01-30-2007, 09:18 PM   #25
Tap
Member#: 21893
2002 WRX w/STi swap
^^^^^Getting same error
Log analyzer - check it out jmc9809 Engine Management & Tuning 42 11-04-2007 09:00 AM
U-LAME -- UTEC Log Analyzer and Map Editor WolfDrive Engine Management & Tuning 14 12-05-2005 11:01 PM
End Links for: STi, WRX, RS and others, New Products Comming Soon PolTec Inc Suspension/Brakes/Handling 74 08-16-2005 04:02 PM
UTECA (new log analyzer software)... need beta testers WolfDrive Engine Management & Tuning 10 05-31-2005 02:42 PM
