Welcome to the North American Subaru Impreza Owners Club Saturday July 2, 2016
Old 01-29-2007, 06:02 PM   #1
runninstrong
Member#: 121474
1991 SS & 2013 STi
Red & Blue
Default Front Differential ?
Just a general question, I'm not 100% sure whats in a 95 auto front diff. Is it gear oil or ATF? It smells an awful lot like gear oil, but I've read around and saw that its ATF maybe? Its really black/dark gray, which I don't think it matters what it is, thats a key sign that its time to change it.
runninstrong is offline   Reply With Quote
Old 01-29-2007, 07:20 PM   #2
Jonathan
Member#: 4021
1999 Legacy GT Ltd
Quick Silver Metallic
The kind and "knowledgeble" folks at Jiffy-Lube explained to me last week end that my '96 Legacy "L" AWD w/4EAT Automatic uses ATF for the Transmission, and 80-90 wt Gear Oil for the front differential. Seeing as I always assumed that the Transmission, AWD clutch packs/"transfer case", and the Front differential were all one unit running in ATF, and they politely explained to me that they arent - and showed me that they are in fact different - I let them change the Front Differential fluid.
Jonathan is offline   Reply With Quote
Old 01-29-2007, 08:07 PM   #3
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
MT: uses 75W-90W gear oil for both the transmission, center-diff, and front differential (rear too for that matter). The front diff lubrication is supplied from the transmission supply so you only fill/drain in one place.
AT: uses ATF fluid for the transmission only. Then has a separate internal reservoir for the front differential. You drain/fill the ATF tranny separately from the front-diff. Not sure about the center-diff..(?)
xcntrk75 is offline   Reply With Quote
Old 01-29-2007, 10:24 PM   #4
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
The center diff uses gear oil? I guess there are some parts in there that need oiling, I was just thinking it was just the viscous fluid.
Wiscon_Mark is offline   Reply With Quote
Old 01-29-2007, 10:26 PM   #5
runninstrong
Member#: 121474
1991 SS & 2013 STi
Red & Blue
I'm pretty sure the auto center you cannot replace the fluid.
Thanks, I KNEW it was gear oil.
Old 01-30-2007, 11:39 AM   #6
IronMonkeyL255
Member#: 38120
1991 Rio Red
Legacy Turbo
You can't do jack about the center diff. The front diff uses the same gear oil as the rear diff. It drains from the plug just a bit behind the engine x-member. You fill it through the dipstick tube (really more like a hole, come to think of it) on the passenger side. A long, flexible funnel helps a ton for this.
IronMonkeyL255 is offline   Reply With Quote
Old 01-30-2007, 12:52 PM   #7
bugeye829
Member#: 81995
2008 Impreza
02 WRX 247k RIP
front diff uses gear oil, seperate from the trans fluid. i'm not sure if its the same as the rear diff, i thought it was slightly different.. like 80w-90 vs 75w90 or something like that but look it up in the manual first to check.
drain underneath and fill from above, the dipstick is on the opposite side from the auto trans dipstick as mentioned above. i believe it takes just 1 quart but can't remember exactly now.
bugeye829 is offline   Reply With Quote
Old 01-30-2007, 03:23 PM   #8
flanders
Member#: 76382
2000 BH
BP Wannabe
This should be covered in the manual, not that I read them myself
flanders is offline   Reply With Quote
Old 01-30-2007, 04:50 PM   #9
runninstrong
Member#: 121474
1991 SS & 2013 STi
Red & Blue
Actually, all it says is front differential gear oil. Not very clear if you ask me.
Old 01-30-2007, 04:55 PM   #10
IronMonkeyL255
Member#: 38120
1991 Rio Red
Legacy Turbo
When I ordered my Motul from a local dealership, they gave me the same stuff for front and rear diffs.
Also, if you have a lsd rear diff, you don't need to add anything to the fluid. all the fluid for the lsd mechanism is internal and un-changeable. The Haynes manual says you need an additive, but you don't.
Does the AT have a front differential? V6 Transmission (AT/MT) & Driveline 3 05-01-2002 06:36 PM
Front differential oil = transmission oil? WRXVII Service & Maintenance 8 03-19-2002 11:46 PM
(4EAT) Front Differential Dipstick doesn't stay in place remarcable Transmission (AT/MT) & Driveline 1 12-15-2001 04:01 PM
Where's the fill point for front differential on AT cars? remarcable Transmission (AT/MT) & Driveline 7 12-11-2001 09:35 PM
Anyone have a KAAZ 1.5 way front differential? lo0pback Brakes, Steering & Suspension 13 02-20-2001 12:44 AM
