Old 01-29-2007, 06:08 PM   #1
subarustate
Member#: 82314
2005 WRX STI wannabe
Darkness
Subaru Stars Side repeater install on my BD
I recently found and ordered a set of clear repeaters on eBay for my 98 Legacy GT. I remember seeing somewhere that some slight modifying may need to be done. I know there are people here who have performed this modification successfully and I'd like to know what kind of modification this entails. Is there some sort of write up, somewhere? I'm sure I'll figure it out when they get here, but any insight would be helpful.
subarustate is offline   Reply With Quote
Old 01-29-2007, 07:30 PM   #2
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Old 01-30-2007, 01:12 AM   #3
that one legacy
Member#: 103665
just in case you don't feel like clicking on that link (which actually has a really good write-up so you might want to check it out anyway!), the little plastic molding piece in the fender just pops right out and then the sidemarker pops right into the hole that's beneath it. wiring, you just hook the positive lead to the signal light on your front signal/marker light, and you're set. i believe it's a green wire with a white stripe on the passenger side, and a green wire with a yellow stripe on the driver's side (might have the colors mixed up though, i did mine a while ago). JDM sidemarker installs on BD/BG/BK Legs are so easy it's almost cheating!
that one legacy is offline   Reply With Quote
Old 01-30-2007, 04:35 PM   #4
98_soobie
Member#: 17071
super easy..
pull the side markers, loosen the fender well plastic piece, squeeze your hand behind the plastic molding piece, and push it out. run some wire from the power leads on the marker light, and get some small female connectors hook it up and slide the new light in the side molding slot, reverse install and BAM your done.
98_soobie is offline   Reply With Quote
Old 04-08-2007, 06:41 PM   #5
EastsideLegacy
Member#: 58806
1998 RIP Legacy2.5GT
2.2L legacy wagon
does anybody have any trouble with the sidemarker staying in all the way, i think that the little tabs that hold mine in are either worn down or something anyone have this problem?
EastsideLegacy is offline   Reply With Quote
Old 04-09-2007, 12:37 AM   #6
that one legacy
Member#: 103665
nope, never had that problem with mine. not too sure where you can get a replacement clip unfortunately.
Old 04-09-2007, 01:15 AM   #7
Radeon
Member#: 105251
13 BRZ,STI
may be the bolt holding that clip in the light housing loosened somehow...
Radeon is offline   Reply With Quote
Old 04-09-2007, 01:25 AM   #8
Plays_With_toys
Member#: 82556
1996 Legacy L wagon
Plays_With_toys is offline   Reply With Quote
Side repeater install on my BD subarustate Alaskan Impreza Club Forum -- AKIC 1 01-29-2007 07:03 PM
Should I install this crap on my BD? xcntrk75 Legacy Forum 23 09-29-2005 09:14 PM
RS Axelback on my BD? Perdue Legacy Forum 2 12-17-2004 04:39 PM
Side repeater install jajogega Interior & Exterior Modification 22 10-28-2003 12:59 AM
Side Repeater Install Instructions??? eastbaysubaru Interior & Exterior Modification 3 04-03-2001 12:01 AM
