Old 01-29-2007, 09:15 PM   #1
DemiSlayer
Member#: 120339
02 WRX
Alliance Motor Sports
Default got my VF22 and have some questions
how smooth is it suposed to revolve also how do you check for shaftplay. it doesnt turn super smooth but is firm i know this is not a ball barring.
DemiSlayer is offline   Reply With Quote
Old 01-30-2007, 12:27 AM   #2
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
It's hard to be objective here. It's going to spin, and shortly stop. there should be no, or an almost inperceptible amount of radial or axial play in the shaft ends, and absolutely no "crunch" when spinning it.
Jorge (RiftsWRX)
www.ProjectWRX.com
RiftsWRX is offline   Reply With Quote
Old 01-30-2007, 12:29 AM   #3
Rwu00313
Member#: 82153
2016 WRX
CWP
Jorge (RiftsWRX)
www.ProjectWRX.com
What if there is a little "crunch"? I put my stock turbo back in...but car hasnt been started up yet and there is a very faint click to the wheel when I spin it gently. Not everytime but sometimes.
Rwu00313 is offline   Reply With Quote
Old 01-30-2007, 12:52 AM   #4
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
Try pressurizing it with some oil. pour some oil in the top, grab an air compressor air nozzle and lightly "pressurize" the top port you poured the oil in. That should force oil around the bearing to support the structure. Then retest it.. If it still crunches... pull it.
Jorge (RiftsWRX)
www.ProjectWRX.com
Old 01-30-2007, 07:05 AM   #5
breathinez
Member#: 79859
2002 384 whp
332.5 lbs
It is a ball bearing turbo.
breathinez is offline   Reply With Quote
Old 01-30-2007, 07:40 AM   #6
02R6
Member#: 22157
'02 WRX '04 350Z
Cause We Are The Aquateen
Correct me if I'm wrong, but I believe the VF22 is a sleeve bearing unit - not to be confused with ball bearing units.
02R6 is offline   Reply With Quote
Old 01-30-2007, 08:13 AM   #7
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
you are wrong.
it is CERTAINLY not a sleeve bearing.
over the years, testimonies to it being both needle and ball bearing have been made.
either way, it isn't a plain bearing.
hth
ken
Old 01-30-2007, 10:07 AM   #8
DemiSlayer
Member#: 120339
02 WRX
it does make a super faint grind to it not a crunch but it has been off the car for awhile could i take it to a speed shop and have them test it ?
Old 01-30-2007, 11:17 AM   #9
DemiSlayer
Member#: 120339
02 WRX
the grinding actually sounds like chewing in a way its not that bad. is this because of the oil not being pressurized or is the turbo bad?
Old 01-30-2007, 12:47 PM   #10
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
Well, like I said, try pressurizing it. It's SUPER simple to do.
Jorge (RiftsWRX)
www.ProjectWRX.com
Old 01-30-2007, 12:57 PM   #11
DemiSlayer
Member#: 120339
02 WRX
Thanks i will try it when i get home.
Old 01-30-2007, 01:22 PM   #12
02R6
Member#: 22157
'02 WRX '04 350Z
Thanks for setting me straight.
Originally Posted by ride5000 View Post
you are wrong.
hth
ken
Old 01-30-2007, 02:10 PM   #13
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
no worries. the only reason i have the knowledge is because i've followed the saga for a while now!
as a little side note, the vf23 chra is the same as the vf22, so the same bearing exists.
also, fwiw, the actual pics i've seen of a disassembled chra showed ball bearings. see them here.
oddly enough, deadbolt/jerry himself insisted they were roller bearings, so...
Old 01-30-2007, 06:24 PM   #14
02R6
Member#: 22157
'02 WRX '04 350Z
Thanks a lot for that link, pretty interesting stuff there. (I can't believe that guys smokes Luckies!)
I wrecked my car and have some questions. wantsti General Community 27 08-15-2009 12:42 AM
Need to ammend my taxes from last year for my house and have some questions wizzle-stick Texas Impreza Club Forum -- TXIC 7 07-15-2009 11:04 PM
Finally got my UP! But have DP question. the_poser Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 03-14-2006 08:59 PM
Just got my STi, but have some questions. ushtang STi Forum Archive 4 08-10-2003 06:15 PM
k, abotu to install my EJ22T and have some more question Eric SS Normally Aspirated with bolt-on Forced Induction Powertrain 7 09-27-2001 07:18 PM
