Welcome to the North American Subaru Impreza Owners Club Saturday December 20, 2014
Old 01-30-2007, 01:12 PM   #1
dwmoss_68
Member#: 6030
04 Gold FXT
07 WRB FXT Sport
Default Sticking Interior Door Handles
02 wrx wagon
138k miles
some of my interior door handles will stick in the open postion.
it seems to be occuring on the less used handles. Drivers door doesn't seem to have this problem, but my others sporadically do.
you open the door from the inside, and the inside door handle does not want to spring back to the closed position. you need to manually push the handle closed to be able to close the door.
anyone have this and find a solution??
closest thread i found was old (03) and in Warranty forum here:
http://forums.nasioc.com/forums/show...ng+door+handle
thanks in advance
dm
dwmoss_68 is offline   Reply With Quote
Old 01-30-2007, 02:23 PM   #2
volkl23
Member#: 39092
2004 WRX STi
Java Black Pearl
I occasionally have this problem as well as a squeeky handle.
volkl23 is offline   Reply With Quote
Old 12-21-2011, 02:30 PM   #3
Big-E
Member#: 123843
2006 WRX Sedan SGM
Let LED's light your way!
My driver's side interior door release handle is also sticking and/or squeaking.
Pull on the handle and it won't fully retract on most occasions. As it's trying to retract and/or when pushed back in, it will squeak.
It sounds like plastic on plastic, meaning the handle is contacting the rest of the assembly that is effectively behind the bezel and/or door-panel.
I'm going to investigate this soon and see what I find. I'm thinking if the handle has distorted from use over time, but there are no apparent cracks or the like, I would more-than-likely use some silicone grease on the affected area(s).
We'll see.
WTB: Interior door handle from 99 Black interior xS2k Private 'Wanted' Classifieds 10 10-14-2006 05:57 AM
STI interior door handles on '02 WRX? JonnySubaru Interior & Exterior Modification 13 11-25-2003 05:13 PM
JDM interior door handles and my custom grill Cajual Legacy Forum 16 05-02-2003 03:36 PM
Baja interior door handles digitaltekniq Interior & Exterior Modification 4 06-29-2002 12:39 PM
passenger side interior door handle popped out! imprezive one Interior & Exterior Modification 2 06-20-2002 11:26 AM
