Old 01-28-2007, 01:45 AM   #1
Donzo
Member#: 95337
2012 Jeep Overland
Default Mounting spare tires on spare wheels via flame method...
Has anyone done this? I've seen it done quite a few times but never knew exactly how it was done. I'd like to see if I can mount them myself using this method. I'm assuming I would have to spray the inside of the wheel with a flammable liquid (lighter fluid?), mount the tire on as far as I can get it on the wheel, then leave a thin stream of fluid on the ground so I can light it from a distance. Tell me if it's really this easy and what the actual risks are. I will have a bucket of water nearby lol
By the way, I searched for this under "fire" and "mount tire" but no luck.
Donzo is offline   Reply With Quote
Old 01-28-2007, 02:01 AM   #2
tw000
Member#: 119028
2005 Legacy 2.5i SWP
'06 WRX Wagon
I've seen it done w/ ether, but I've never done it. The tire was off the bead and needed to be re-seated. The dude emptied a can of starter fluid into the tire around the wheel then held an open flame near it and *BLAM* the gas exploded and caused the tire to seat on the rim.
It is really dangerous to do and it isn't easy at all.
tw000 is offline   Reply With Quote
Old 01-28-2007, 02:03 AM   #3
kennyvb
Member#: 70234
MY86 BMW E30 325
SCIC/NWIC tranplant (-_-)
macgyver much?
kennyvb is offline   Reply With Quote
Old 01-28-2007, 11:22 AM   #4
Hites
Member#: 138997
0000 Nothing
idk about a spare...
Hites is offline   Reply With Quote
Old 01-28-2007, 11:26 AM   #5
Donzo
Member#: 95337
2012 Jeep Overland
No, I didn't mean "spare" as in a donut. I meant that I just got a set of wheels and tires for dirt cheap and I'd like to try this out method. Anyone have a better idea or description on how to do it?
Old 01-28-2007, 04:05 PM   #6
Donzo
Member#: 95337
2012 Jeep Overland
Anyone else?
Old 01-28-2007, 06:30 PM   #7
Donzo
Member#: 95337
2012 Jeep Overland
Old 01-28-2007, 06:51 PM   #8
vtecTHIS
Member#: 48048
. Nasioc, serious
Bidnazz
it's like 20 bux to get tires mounted on "loose" wheels...
vtecTHIS is offline   Reply With Quote
Old 01-28-2007, 09:16 PM   #9
ddunk12
Member#: 116596
2012 STI
Holy crap I almost pissed myself watching those vids funny stuff. I def. would not do it like that
ddunk12 is offline   Reply With Quote
Old 01-29-2007, 12:38 AM   #10
tw000
Member#: 119028
'06 WRX Wagon
Originally Posted by TheDon427;16841593...
[url
http://www.youtube.com/watch?v=_M0GNLvPmAg&NR[/url]
Except for almost collapsing the tire, this is exactly what it looks like when the pros do it. I think the pros leave the valve out of the stem.
Old 01-29-2007, 12:49 AM   #11
kursplat
Member#: 89528
2005 sti
crystal grey
are you unable to bead them properly or does this just look like a cool way to do it ?
kursplat is offline   Reply With Quote
Old 01-29-2007, 04:24 AM   #12
folkstyle171
Member#: 134326
1998 STi Type R
Make sure you pull the valve stem out, or you may get 100 psi in the tire really quick. I carried a propane torch with me when riding quads, and popped the bead a few times, it works well, but if you have a choice do it on the machine, I burnt up an eyebrow doing it. And for god sakes do not use lighter fluid, only propane or eather. and not a bunch. If you are out on a trail that is!
folkstyle171 is offline   Reply With Quote
Old 01-29-2007, 08:28 AM   #13
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
Please video tape when you try it. And make sure there's a someone around to call 911. This seems like such a bad idea, just to save a few $'s.
mav1c is offline   Reply With Quote
Old 01-29-2007, 08:54 AM   #14
JCity
Member#: 131845
1994 Acura Integra
R-81
exactly, it's crazy this is the first time i've ever heard of this!...
how exactly does it work ? if anyone wants to take the time to break it down to me.
JCity is offline   Reply With Quote
Old 01-29-2007, 10:09 AM   #15
MFR Sweep
Member#: 103510
2006 rex
Aspen Brake Dust
It is not always to save a few $$.
I have done it out on the trail when the compressor wouldn't set the bead. Pulling the valve core out of a 31" tire isn't nessesary as long as you don't go crazy with the fluid. I just bolted the wheel back up to the truck so it wouldn't go anywhere if a part of the wheel failed.
When it is below 0*F you don't even need to spray anything into the tire, a lighter and some WD in the form of a flame thrower will do it!
MFR Sweep is offline   Reply With Quote
Old 01-29-2007, 10:20 AM   #16
SloSubie
Member#: 63411
2004 Impreza WRX
use spray ether spray inside tire for 5-10secs. then light using stick with flaming rags at the end. use stick about 4 ft long as so not to get burnt. this is what we do offroad to set beads. This works very well with larger tires but I am not sure how it will work with tires for your subaru.
SloSubie is offline   Reply With Quote
Old 01-29-2007, 11:28 AM   #17
Donzo
Member#: 95337
2012 Jeep Overland
Yea, it was just an idea since I have extra tires and extra wheels laying around. I always wanted to try it but I don't want to be one of those idiots on Break.com missing fingers lol
Old 01-30-2007, 04:51 PM   #18
Donzo
Member#: 95337
2012 Jeep Overland
But really, has anyone personally tried this? I'd like to know the details of it.
Old 01-30-2007, 06:14 PM   #19
Cre8ive
Member#: 15617
2007 WRX STi OBP
'02 WRX OBP
You mean the check-valve inside the valve stem right? Since the valve stem needs to be put on the rim before the tire.
I've never used the ether method but I have seated the bead by wrapping a rope around the curcumference of the tread and using a pipe like a tourniquet
to squeeze the tread so that it buldges out the side wall. Then use an air valve that flows a large volume of air to set the bead.
Getting a tire to bead on the rim is the easy part (unless you are going for that stretched look), the hard part is getting the tire ON the rim.
Cre8ive is offline   Reply With Quote
Old 01-30-2007, 07:22 PM   #20
fliz
Member#: 30342
That's what I'd think.
I'll stick to paying $2/per to the local garage to mount my tires.
fliz is offline   Reply With Quote
Old 01-30-2007, 07:32 PM   #21
MFR Sweep
Member#: 103510
2006 rex
Aspen Brake Dust
This way of beading a tire is more for 4x4 and offroad guys. It is also an emergency tecnique. Truck tires can be extremely hard to bead due to the amount of air it takes to fill them.
plus if you are in a car you aren't going to be where a towtruck can't get to you. Or if you are, you are most likely screwed anyway.
Old 01-30-2007, 10:10 PM   #22
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
Those dudes in the artic do that stuff when there 4x4's tires fall off the rims. They run like 2 psi in there tires and its below 0 out..which forces them to use the lighter fluid trick
mxpunk is offline   Reply With Quote
Old 01-30-2007, 10:14 PM   #23
MFR Sweep
Member#: 103510
2006 rex
Aspen Brake Dust
yeah, iceland hasn't caught on to beadlocks or anything
Old 01-30-2007, 10:22 PM   #24
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
no, like ant-artica
i saw some show on the discovery channel or TLC and they showed those guys using that technique to re-mount the tires
Old 01-30-2007, 10:28 PM   #25
MFR Sweep
Member#: 103510
2006 rex
Aspen Brake Dust
no, like ant-artica
The show you watched was about icelandic trucks in the Arctic.
Google Arctic trucks or Iceland trucks
they do some pretty cool things, but somehow haven't figured out beadlocks
Do you trust the dealer to mount tires on your wheels?? GeneralTsou Tire & Wheel 4 05-29-2010 10:35 AM
WTB 04 STI spare tire or OEM wheel Screwbal NWIC Private Classifieds 2 11-12-2009 02:34 PM
Mounting tires on Volk wheels InfamousDX Tire & Wheel 1 12-09-2005 01:55 PM
BAIC GB on Rota wheels via Redstar Racing... MPREZYA Bay Area Impreza Club Forum -- BAIC 76 03-02-2002 05:36 PM
Help Please... time to mount new tires on wheels cfwdfw North West Impreza Club Forum -- NWIC 0 05-25-2001 06:30 AM
