Old 11-29-2001, 12:32 AM   #1
Daveish
Member#: 8935
2001 Impreza 2.5RS
Default Stalling problem...
Hi folks.
I'm posting this for a friend who has an older model impreza (mid-90's). We're having an issue where the car is throwing a CE light, giving the reason as a problem with the fuel pump relay system. The car semi-stalls intermittently while driving, in any gear, at any speed above idle. The car dosent stall completely, though -- the tach drops to zero and quickly jumps back up again.
Would it be a bad idea to hard-wire the relays (so that the circuits they control are always "on") just to see if that is the problem? Any other ideas on what it could be? I think he has replaced the relays once already.
Any suggestions appreciated. Thanks...
Daveish is offline   Reply With Quote
Old 11-29-2001, 03:07 AM   #2
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
sounds like the Main Realy is going out....change it...
Jeremy
Old 11-29-2001, 05:01 PM   #3
yamarocket630
Member#: 9436
05 Saab 9-5 Aero
Hardwiring the relays won't hurt anything, just be sure to rememer to undo it. I would suspect an electrical problem, because of the tach that suddenly goes to 0 at the same time as the stall/stumble. Look for anything that would be common to both the fuel relay and the tach(or ignition system) like power feeds from the ignition switch for example.
yamarocket630 is offline   Reply With Quote
Old 11-29-2001, 05:53 PM   #4
Daveish
Member#: 8935
2001 Impreza 2.5RS
Thanks for the ideas...
Changed the relays... same thing.
I'm looking over the wiring now... will update later.
Dave
Stalling Problems....??? GraVitY0 Normally Aspirated Powertrain 4 03-04-2004 12:51 AM
Ideas on stalling problem? BIGSKYWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 11-04-2003 09:22 AM
Compressor stall problem I think. Also, is there a such thing a wastegate slap? knuckles Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 11-19-2002 07:28 PM
stalling problems jbdesros Normally Aspirated Powertrain 7 09-17-2001 01:44 PM
Stalling Problems with MY98 RS Turbo yebokmj Normally Aspirated with bolt-on Forced Induction Powertrain 24 08-29-2001 10:37 PM
