#1 |
Member#: 123043
RMIC
Vehicle:1999 legacy 2.5GT green |
do you guys think it would be possible to fit brembo breaks system ( lines, rotors, capliers) from a stock sti on my 99 leg?
#2 |
out back
Moderator Member#: 1964
RMIC
Vehicle:01 BH Blue/Bronze |
Should fit, but you'll need 17" wheels to go along with them.
#3 |
Member#: 115154
Vehicle:2003 Legacy L Turbo silver |
fronts bolt up just fine. Rears will need the hubs.
#4 |
Member#: 94945
Vehicle:1995 Legacy OB 5MT 2003 Forester X 5MT |
#5 |
Member#: 115154
Hmm I think so; STi's got a beefier rear end (r180 lsd with matching axles and hubs) but double check in the brakes section about what wrx guys did to convert their rears to Brembo's.
AFAIK, there's a little more work involved than the front, which bolts up just like any other subaru front brake. |
#6 |
Member#: 123043
RMIC
hmm you guys think just adding new rotors be just as good? like say, cobb?
#7 |
Member#: 115154
pads and lines more like.
They won't be like brembos, but they'll be much better than what you have right now more likely. Get whatever rotors fit your budget. Cobb is just overpriced for anything that they make, but that's IMO. |
#8 |
Member#: 73102
Vehicle:1998 legacy outback white |
+1 pads and stainless lines.
The only boost you'll get from rotors is by getting beefier ones, more metal in them means they can absorb more heat. key words: more metal, as in not drilled and/or slotted. check out the brake faq. |
#9 | |
Member#: 38629
NWIC
Vehicle:1999 Legacy GT (STI) White |
The problem with the adapters, is they are pricey, around $600. I was going to buy the adapter, but that was before my tranny blew, so I'm just converting to the R180. |
#10 |
Member#: 123043
RMIC
so any suggestions on which brand i should go with?
#11 |
Member#: 115154
WRX front brakes if you want to size up.
#12 |
Member#: 38629
NWIC
I think the question is, what is your budget? Depending on what you're willing to spend you could go with several different options.
I'll have a set of WRX brakes and H6 rear brakes/calipers available soon, but I think someone else has dibs, I'll have to check. ![]() I'd recommend the Subaru 4 pots, but, at that price, I would either look used or go STI brembo's. https://www.subarugenuineparts.com/p...roducts_id=916 |
#13 |
Member#: 99289
tom@kartboy boy has mentioned in the past that he may be able to modify his existing Subaru 2 pot adapter plate to fit the brembo 2 pot rear calipers. That assumes that the Legacy R160 mounting is already same as the as the impreza. Which I think it is, since we can steal your rear caliper. Even after all of this, you still have a final issue. No emergency brake. The rear rotors from the Brembo have a larger emergency drum brake. One firx, that WRXbrakes has discussed, is custom rotors. This could be expensive in the long run. I've also run across a company in the UK that had an OEM rear emergency brake shoes made up with a thicker pad. As these usually last more than the lifetime of the vehicle, and could use a wide variety of rotors, I think this is the better idea.
#14 |
Member#: 115154
In all honesty; Brembos are bling. I mean, for the most part the people that put them on their cars will never really use them for the kinds of applications that they were intended for. Now if you want them, that's great, but it seems you are more looking to upgrade the way your car stops moreso trying to look good in addition to it...
#15 | |
Member#: 38629
NWIC
I think I mentioned this in the other braking thread, but I am picky. She even laughed at me that after all the mods I did (racing fluid, wrx fronts, H6 rears, semi-metallic pads) that the brakes weren't as good. I concluded that the only thing it could be is the larger leverage of the IS300 brake rotors. I'll hopefully be able to report the changes soon. I swear to god if it doesn't deliver what I want, I'll be saving my pennies for a full Stoptech kit. I'm obsessesed at this point. |
#16 |
Member#: 99289
My guess is that a lot of your dissatisfaction with the OEM brake setup is the master cylinder, not a lot of options there.
#17 |
Member#: 94945
#18 |
Member#: 99289
I think Subaru has one master cylinder in all products.
#19 |
Member#: 94945
#20 | |
Member#: 38629
NWIC
I'm not convinced it is the master cylinder. The other comparison I would make is my setup is not as good as my brothers Saab 92-x. He did a Stoptech front kit, and did H6 rears. As a test I pushed it up to 90, and did a hard brake (not a full on emergency brake). The effect was amazing. Granted, that type of performance is not needed for a daily driver though. |
#21 |
Member#: 60224
Vehicle:2008 FXT Sports 2.5 Dark Grey Metallic |
If you got to have the “Brembo’s” why don’t you just buy the wrx specific kit? Brembo makes a complete front & rear kit for the WRX platform (same as LGT) with an R160 rear diff and backing plates. In other words, completely bolt on…no adapters, no new backing plates, hubs, etc…
http://www.fastwrx.com/brstibrup.html |
#22 |
Member#: 52324
NESIC
Vehicle:2011 SWP WRX LTD 1990 T30 miata |
older imprezas had a single stage master cyl. This gave a much firmer pedal. The dual-stage master cyl makes you have to pump once before you get good pedal feel. fine on the street, but on the track it kinda stinks.
Unless your tracking the car I wouldn't spend that much $ on brembos. well unless your rich too. in that case, who cares ![]() |
#23 |
Member#: 53625
Vehicle:00 EJ205 LGT LTD 97 LGT Wagon |
^ Ditto. Subaru DEFINATELY uses a different master cylinder on older cars (especially those with rear drums), present cars, and STi's. A four pot piston like Brembos need more fluid pushed to make the pistons activate, hence the need for a larger piston in the master cylinder.
There is a size marked under your brake reservoir on the metal part that supports it (it's marked very small and you can read it with a flashlight and mirror). This tells you which master cylinder you have. I have a WRX one for sale, it reads 1 1/16". I sugest you upgrade to stainless lines, Super Blue fluid, better pads, and WRX front rotors (using 2002 wrx front caliper brackets). Upgrading to 4-pot calipers doesn't necessarily give much more power, but will give you more fade resistance, which is definately not needed in most daily drivers. Find out which master cylinder you have and upgrade it if it is a single stage, older model. Dont' bother with fancy pants slotted or drilled rotors. They actually reduce pad contact and braking power under normal circumstances. Again, you are unlikely to ever get them hot enough to warrant the need for slots or cross-drilling, and these also make the rotors more prone to cracking. A good set of Brembo blank rotors is cheap and will get the job done. |
#24 |
Member#: 99289
Yeah, I realize the older models have a different setup, but you will loose ABS going that route, from what I can tell. And what we have isn't technically a dual stage, just dual diaphram.
More here: http://forums.nasioc.com/forums/show...=dual+diaphram |
#25 |
Member#: 27874
NESIC
Vehicle:2002 WRX 6MT 312whp 05 LGT |
Defiantly run a bigger master cylinder.
I went from the stock signal pot front brakes and drum rears on my 96 Brighton Impreza to wrx front and rear brakes. With the stock master cylinder the brakes were not much better then the stock setup, but I switched out the master cylinder with one from Non-ABS SVX (1-1/16) and the brakes are great. I can lock the brakes up if i want now. (my car does not have ABS) I would think the WRX one would work if you need one for a car with ABS. |
| Thread Tools | |
| Display Modes | |
| STi Brembos in my '87 GL | Caboobaroo | Subaru Conversions | 62 | 02-07-2008 10:06 PM |
| Stoptechs or Brembo in my GC | joellg | Subaru Conversions | 23 | 12-31-2007 05:38 PM |
| Question on Installing V8 Brembos on MY 99 RS WRX Swap | Costas | Brakes, Steering & Suspension | 9 | 10-05-2004 04:15 PM |
| second air filter in MY 99 | tcmo | Normally Aspirated Powertrain | 9 | 01-15-2002 12:45 PM |
| second air filter in MY 99 | tcmo | Legacy Forum | 1 | 01-14-2002 01:24 PM |
