Old 01-31-2007, 11:43 AM   #1
ImprezaTron
Member#: 1549
04 WRX
Angry Transmission fluid capacity discrepancy with dealer
It is my understanding from the manual and many threads on here that the WRX 5-speed capacity is listed as 3.7 quarts. Also I've seen from many sources that the rear differential capacity is about less than 1 quart.
For my 30k service, I went out and bought 4 qts of Castrol Hypoy C and 1 qt. of Castrol Syntec for the rear. I get a call this morning from the service advisor that I'm about 1/2 qt short for the transmission and a little less than that for the rear diff. He told me that the capacity is more than listed for the transmission because you have to take into account the front diff . I know these guys work on Subarus everyday, but are they just mixed up about the capacities? Keep in mind they are just performing a drain and fill, not a flush or anything like that.
ImprezaTron is offline   Reply With Quote
Old 01-31-2007, 11:51 AM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Old 01-31-2007, 11:45 PM   #3
ImprezaTron
Member#: 1549
04 WRX
Thanks Unc Scotty! I was about to lay those pages on them.
It turns out the "highly trained/experienced tech that's been doing this for years" couldn't tell the difference between a pint and a quart. I don't even understand where they get the pint measurement as it's not listed in the service manual. Oh well, I'm enjoying my fresh tranny oil.
Old 02-01-2007, 01:25 AM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
...deargodinheaven.....
Old 02-01-2007, 09:59 AM   #5
BlueDominion
Member#: 73591
Up Back in Boston
Rollin the RSX
Yup, this is why I work on my own car. Where the hell do they find these techs?
BlueDominion is offline   Reply With Quote
Old 02-01-2007, 07:51 PM   #6
NWstiLTD
Member#: 133458
2007 WRX STI Limited
"urban gray metallic"
Ahem,
I just want to state that you have to add the fluid through the diff to get to the trans. Unless you want to push the crappy old diff fluid into the trans, you may want to drain the diff too. I think the tech is right. Just did mine(and am a tech) make sure you are on solid ground before you go cop an attitude with someone who is doing their job.
NWstiLTD is offline   Reply With Quote
Old 02-01-2007, 08:13 PM   #7
FD777
Member#: 84820
2005 WRX Sedan
Crystal Gray
Originally Posted by Subaru Service Manual
16.Front & Rear Differential Gear Oil
A: REPLACEMENT
1. FRONT DIFFERENTIAL (MT MODEL)
For MT vehicle, differential oil works as manual
transmission oil to lubricate differential. Refer to
“Transmission Oil”. <Ref. to PM-23, Transmission Gear Oil.>
Please refer to Uncle Scotty's post above.
The WRX 5-MT only has one drain plug.
FD777 is offline   Reply With Quote
Old 02-01-2007, 10:52 PM   #8
NWstiLTD
Member#: 133458
thats great, I didnt know it was a wrx, or that it was different. I saw the above post, I just know what i have dealt with on my own vehicle and others like it. If the vehicle holds only 4 then great. I just wanted to say that you want to make sure before confronting a mechanic. Most dont like it when you bring your own parts, and like it even less when you tell them how to install them.
That said if hes wrong then let him know
Old 02-02-2007, 10:41 AM   #9
sidewayz
Member#: 5810
2001 S366 2.5RS
dude.. your crying about what? $10? Just give them another quart and keep the rest
sidewayz is offline   Reply With Quote
Old 02-02-2007, 12:16 PM   #10
Uncle Scotty
Member#: 16200
OK buy Nates beans
.....d00000000d....ya didn't READ the thread....did ya????
Old 02-02-2007, 12:54 PM   #11
ImprezaTron
Member#: 1549
04 WRX
Haha, wow. The thread itself gives some examples of how misinformation leads to miscommunication.
I did the research before going with my own oils. When the dealer notified me I was short, I didn't rule out the fact that maybe I screwed up and double checked my sources. Not once did I cop an attitude with them. It basically came down to Subaru's word vs. the dealer's. Of course I put more faith in people who designed the car, and that's what I made clear to them before they got a second opinion from another tech.
Honestly, a mechanic who can't comprehend different units of measure is an insult to the other skilled mechanics and doesn't deserve whatever certification they earned. I think this thread is pretty much over.
Old 02-02-2007, 01:18 PM   #12
Uncle Scotty
Member#: 16200
OK buy Nates beans
This thread is over.
spark plug gap & fluid capacities jamest46 Service & Maintenance 5 12-18-2003 06:20 PM
Brake Fluid/Steering Fluid/Diff. Fluid/Transmission Fluid Jasno999 Brakes, Steering & Suspension 11 09-27-2002 11:22 AM
Minimum Rotor Thickness and Brake Fluid capacity? - MY98 RS glyphic Brakes, Steering & Suspension 2 07-19-2002 10:39 PM
Fluid capacity of clutch cmaj7 Transmission (AT/MT) & Driveline 1 07-13-2002 02:24 PM
Anyone know the full fluid capacity of the RS braking system? North Ursalia Brakes, Steering & Suspension 3 02-11-2001 06:46 PM
