#1 |
Member#: 136510
Vehicle:2007 Impreza Wagon Black |
I've got an '07 Impreza Wagon I'll be installing springs on soon. I'm hoping to get the torque values for the various nuts/bolts. Any help is appreciated.
#2 |
Member#: 95621
SCIC
PM me when you're ready for your the torq spec, as I'm not sure what the legality is for posting partial service manual pdf's.
#3 |
Member#: 80663
SWIC
Vehicle:1997 Outback |
Bottom one's...A LOT (broke two ratchets), top ones...very little...known for stripping. Do a search, there are threads on it. Scoobymods.com is your friend.
#4 |
Member#: 16200
Vehicle:OK Houston we have an Uncle |
#5 |
Member#: 95621
SCIC
Well, here you go:
This is for the 2004 WRX/STi, so check and see if they're the same for your year and model. Front Strut Assembly Rear Strut Assembly Front Suspension General Description Rear Suspension General Description Hope that helps, Ric- |
#6 |
Member#: 136510
Ric - That is exactly what I was looking for. Thanks a bunch!
Anyone know the limits of the stock front camber adjusting bolts? I purchased one pair of aftermarket bolts from SPC. My thought is to install them on the rear. Another idea I had, if it's even possible, is to move the factory fronts to the rear and install the aftermarket ones on the front. Any opinions? |
#7 |
Member#: 21808
E. Canada
Vehicle:02 GroceryGettAr Nonemore Black |
Leave the factory ones in the front. You can install the aftermarket ones in the lower hole in the front in addition to the factory ones.
#8 |
Member#: 136510
#9 | |
Member#: 21808
E. Canada
Of course it depends what your goals are (e.g. for autox you might want bolts in the rear to reduce the camber right down and make it super loose). And I may be misreading your whole purpose - bolts to 'correct' the camber back to stock aren't really necessary after a spring install - lowering springs will make the camber more negative than stock (more so in front than in the rear) which is good. I'm talking about 'correcting' beyond the stock settings. |
#10 |
Member#: 136510
When I say correction I'm referring to returning back to stock. This car is many for daily driving with trips on the weekends for snowboarding. I've got a Civic I use for autox that I'll take out to local events. For any events that require some travel I'll take the wagon just to give it a try. So it may see 3 events a year but not to be competitive, just for fun you know. I'll keep the stock bolts up front and install the SPC bolts on the rear. Thanks for all of your help. I'm currently working on the front and working my way to the back soon.
#11 |
Member#: 136510
Just got the alignment done and the camber adjustments I guessed at we're right on, all that needed to be adjusted was toe.
| Thread Tools | |
| Display Modes | |
| Torque specs for Cosworth rod bolts for EJ25? | Navid | Built Motor Discussion | 0 | 10-20-2007 10:57 PM |
| looking for torque specs for valve cover, spark plugs and coil packs | Tobey | Factory 2.5L Turbo Powertrain | 2 | 04-13-2005 03:35 PM |
| Torque Specs for various suspension bits | pj's_Rex | Brakes, Steering & Suspension | 6 | 09-23-2004 08:45 PM |
| Torque specs for pulley? | JGard | Normally Aspirated Powertrain | 9 | 04-12-2001 10:01 AM |
| Torque specs for suspension bolts? | JGard | General Forum Archive | 3 | 12-28-2000 07:12 AM |
