Welcome to the North American Subaru Impreza Owners Club Monday March 2, 2015
Old 11-29-2001, 09:43 AM   #1
AndyHidley
Member#: 1031
Default Misfires- P0301 P0302 P0303 P0304
Mark,
I would like to share this info with you since you have replied to my numerous e-mails with very good technical info!!
I got a unichip from you a month ago and have been haveing problems with the car since , they have been getting progressivly worse. It had boost spiking like others in the i-club have reported. No matter what i did I couldn't stop it. the car seemed to run strong, until reciently.
I had changed the silicone (jelly) hose that you sent with a rubber vaccuume hose with no noticable difference in the boost spiking.
I have a KN air/fuel meter. The kind with 9 LEDs . It was displaying like a christmas trees blinking lights. then the car started runningn really ****ty through a week or so and then check engine lights started being displayed. they were p0302
misfire in cylinder 2 ..
I finally put the car back to stock and took it to the dealer. They said it had a loose wire on the coil. I never had my hand down near that ever.
I see alot of people reporting misfires on i-club. I know I had them and didn't get a check engine light.
Now since its fixed I put the unichip back in and the boost spiking is fixed, everything is nice and smooth. Unichip works great!! The air/fuel guage is now lighting across the scale like your dinning room light would with a dimmer switch vs the blinking xmas tree..
My feeling is that unburned fuel entering the exaust, because of a undetected misfire, is then igniting and causing the turbo to spool eratically and causing the spikes.
I believe everyone should check their ignition wires to the coils for good contact, it could become a recall???
I know that the rally cars squirt in fuel into the exaust to keep the turbo spoold when they let off the gas to shift at the cost of longevity to the turbo. I believe something simular is happening with a misfire causing the turbo to over spool eratically resulting in the boost spikes
AndyHidley is offline   Reply With Quote
Old 11-29-2001, 01:43 PM   #2
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
u were running anti lag unintentationally....actually the cylinder was probably partially firing as opposed to totally firing....and a partial fire is enough to dump raw fuel in the exhaust. Talk about boost spikes.
jeremy
Old 11-30-2001, 01:41 AM   #3
Dave_MacKinnon
Member#: 10823
2007 STi
Thanks for the very usefull feedback... Any 'better checks' are always a good thing!
Dave_MacKinnon is offline   Reply With Quote
Old 11-30-2001, 02:18 AM   #4
GDA
Member#: 4324
02 GDA
Platinum
ill check the coil harness' to see if mine arent contacting properly, that might be the reason for misifire in all cylinders.
thanks
EJ20WRX
GDA is offline   Reply With Quote
Another P0301, P0302, P0303, P0304 question Zoharid Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 10-02-2007 09:08 PM
P0301, P0302, P0303, P0304 questions slvrwrx02 Warranty Issues & SOA Problems 30 09-28-2007 03:51 PM
Missfire Dtc P0301, P0303.p0304 yrlegacy Normally Aspirated Powertrain 8 08-28-2007 01:00 AM
P0301 P0302 P0303 P0304 Cylinder Misfire Help choie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 53 06-14-2006 01:40 PM
P0301 P0302 P0303 helpp ice_bomb Engine Management & Tuning 52 11-02-2005 08:49 AM
