Welcome to the North American Subaru Impreza Owners Club Thursday April 17, 2014
Old 04-09-2008, 07:31 PM   #76
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
It tastes like burning
Originally Posted by dwrecckk View Post
There was nothing wrong with it, just a bit confusing.
Pin1 : Pin2: Pin3
+12v : GND : Trigger
Red : Blk : Green <--- wire colors I used in my picture
RY : BY : GY <--- '02 WRX harness colors
It was just reversed compared to the picture right below it
Pin1: Pin2: Pin3
Trig :GND:+12V
Green Black Red
matches the pic below.
That's why in the line above what you quoted it says;
Using the above picture as a reference, the pinning is as follows from left to right:
The picture above the description has it oriented correctly
Plus it's how the wiring diagram from the WRX manual has the pins numbered.
-Rob
EDIT: I went ahead and flipped the second picture to avoid future confusion.
rob is offline   Reply With Quote
Old 04-12-2008, 10:38 AM   #77
Not All There
Member#: 135615
1995 Impreza
The Ugly Panda
Hey guys, a friend on here sent me some coils for spares from japan, which look an aweful lot like the us wrx coils im about to convert to. I was wondering if anyone knew what exactly these are. Heres the pics, and the part numbers on them are the following...
22433AA390
Diamond
FK0053 12V
6725
im hoping i can just use these, they look identical and gave the rubber insulator boots that dont crack.
Not All There is offline   Reply With Quote
Old 04-12-2008, 02:50 PM   #78
Not All There
Member#: 135615
1995 Impreza
The Ugly Panda
I really want to make sure the pins and such are the same, part numbers are diffferent than the us coilpacks, but looks and size is identicle as far as i can see
Old 04-13-2008, 11:45 PM   #79
hail2theTheif
Member#: 42548
2005 GF8 05 STi
Red
what did you guys do with the untouched ground? did you just plug the connector back in and leave it there?
anyone who has successfully done this please read my problem thread. i could really help in getting mine fixed.
thanks.
hail2theTheif is offline   Reply With Quote
Old 04-14-2008, 04:45 AM   #80
dwrecckk
Member#: 110414
-Rob
Must have missed that, haha. Whoops. Sorry, wasn't trying to nitpick. Definately owe a big thanks for this sticky. Very useful mod.
dwrecckk is offline   Reply With Quote
Old 04-27-2008, 04:00 AM   #81
keirnna
Member#: 50167
1996 Subaru STI RA
22433AA390
Diamond
FK0053 12V
6725
I mentioned in the email, as I am sure you know now, but I will post in case someone else wants to know in the future. Those are EJ20H coil packs.
keirnna is offline   Reply With Quote
Old 04-29-2008, 04:54 PM   #82
Not All There
Member#: 135615
1995 Impreza
The Ugly Panda
your not going to believ this but i found my original coil... i kept it aside for you in case you need one. I have not done the swap yet, was hoping to do some more research in order to confirm these are wired the same way. They are wired and ready to install, i just want to confirm they work the same as the wrx coilpacks before i go threw the trouble of installing them.
So NASIOC, will EJ20H coilpacks, as seen above, work and wire up the same way as wrx coilpacks? they look identical to me...
Old 04-29-2008, 05:46 PM   #83
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
I don't think anyone here is going to be able to answer that definitively. My guess is that they are going to work the same. I would suggest that you convert just one cylinder and verify that it runs as expected. If it doesn't, it would be pretty easy to revert back.
-Rob
Old 04-29-2008, 05:48 PM   #84
Not All There
Member#: 135615
1995 Impreza
The Ugly Panda
thanks rob. Theres no wire diagrams of the EJ20H that would show a similar set up as the newer wrx's?
Old 04-29-2008, 06:00 PM   #85
keirnna
Member#: 50167
1996 Subaru STI RA
Also I if you like. I can clip the EJ20H wiring harness to send the ends to you for a cleaner wiring job.
Old 04-29-2008, 07:35 PM   #86
Not All There
Member#: 135615
1995 Impreza
The Ugly Panda
that would have been mint but i already sealed and wired the individual ones in there, came out pretty nice. Thanks for the offer.
Old 04-29-2008, 07:39 PM   #87
keirnna
Member#: 50167
1996 Subaru STI RA
Cool, sorry I didn't mention that earlier .
Old 05-04-2008, 03:06 AM   #88
WRX_RA
Member#: 151188
1997 GC8 EJ20G
2010 W204
HELP!
Just just this swap and I have no idea what I could have done wrong...
Can someone think of something really stupid that I might have missed?
I followed the instructions over twice.
My coilpacks I bought were a grey colour instead of being all black.
Off of a 2005.
Is there any wiring difference there?
I have a version 1 WRX (GC8-A EJ20G)
_Matt
WRX_RA is offline   Reply With Quote
Old 05-04-2008, 09:50 AM   #89
Not All There
Member#: 135615
1995 Impreza
The Ugly Panda
you got rid of the ignitor correctly as well?
Old 05-04-2008, 12:51 PM   #90
WRX_RA
Member#: 151188
1997 GC8 EJ20G
2010 W204
yep and I even tore off all the shrink wrap I had put on to take a look again.
Old 05-05-2008, 07:20 AM   #91
kike_ej20
Member#: 145440
MY96 WRX GT2835-ProS
EJ20G 2123cc!!
Is anybody running high boost on this kind of coilpacks to show me that they really work?
The reason I'm asking is because I have a lot of ej20g spare coilpacks that I use every time I break one under high boost....and it is really getting old.
kike_ej20 is offline   Reply With Quote
Old 05-05-2008, 12:31 PM   #92
hail2theTheif
Member#: 42548
2005 GF8 05 STi
Red
i'm running 16.5 pounds on the conversion and the difference from the old style coils is massive. no stuttering or misfires under WOT.
Old 05-05-2008, 01:10 PM   #93
kike_ej20
Member#: 145440
EJ20G 2123cc!!
Well,I'm running 22 that is probably why
For how long have you been running 16.5?and what do you mean by massive? Where the old style in good shape too?
Old 05-12-2008, 12:46 PM   #94
Not All There
Member#: 135615
1995 Impreza
The Ugly Panda
Another one now happily converted!
Old 05-12-2008, 03:18 PM   #95
johnny p
Member#: 141232
95 wrx
kinda blue
Amen!
johnny p is offline   Reply With Quote
Old 05-30-2008, 03:49 AM   #96
Kaymin
Member#: 96076
RIP 96 SBM GC8
05 Burnt Orange Evo
i'm in the middle of this, should my car be able to run on only three of them?
my soldering iron died on me on the last one and I just wanted to try it on three.
it cranks, starts and dies. does that sound normal?
just wanted to know before i get disappointed when i get all 4 done.
(the forth isn't plugged in at all)
Kaymin is offline   Reply With Quote
Old 06-01-2008, 10:38 AM   #97
Not All There
Member#: 135615
1995 Impreza
The Ugly Panda
it should run rough, mine idled with 3 before.
Old 06-01-2008, 08:12 PM   #98
Kaymin
Member#: 96076
RIP 96 SBM GC8
05 Burnt Orange Evo
not sure what was wrong before but i finished it all up and it idles better then before now. but now i think one of my connections somewhere came undone. lacking power and i'm getting back fire. so i'm thinking i'm running on 3 or less cylinders
Old 06-01-2008, 11:28 PM   #99
Not All There
Member#: 135615
1995 Impreza
The Ugly Panda
i had one come loose because of a crappy crimp, check you connections.
Old 06-02-2008, 02:24 AM   #100
Kaymin
Member#: 96076
RIP 96 SBM GC8
05 Burnt Orange Evo
i got rid of all my crimps. soldered everything.
got it running but on three cylinders. swapped that coil pack with another one to check the wiring. pretty sure that coil pack is dead.
WTB: WRX coil packs for the EJ20G coil pack conversion ASAP! Joshb120 Private 'Wanted' Classifieds 2 05-18-2008 12:42 AM
2000 Intake manifold, EJ20G Intercoolers, EJ20G coil Woki Toki Engine/Power/Exhaust 3 04-18-2008 11:54 PM
EJ20G coil resistance? snowman4us Pre-2002 Factory Turbo Powertrain 4 11-15-2006 01:52 PM
EJ20g Coil on Plugs newgensti Subaru Conversions 7 09-15-2006 11:07 AM
EJ20G coil packs scoobyimprza Subaru Conversions 2 08-29-2005 01:36 PM
