Old 06-06-2008, 06:25 PM   #101
DSM_Outback
Member#: 56345
93 Swapped L
Green
FWIW & Archival purposes, anyone running a Stinger 4424 or 8860 standalone with external igniters, the trigger wires are as follows:
From ECU
Pink Cyl 1 trigger
Orange Red stripe Cyl 3 trigger
Yellow Red stripe Cyl 2 trigger
Grey Black stripe Cyl 4 trigger
Yellow wire to old coil pack connectors is common 12+.
DSM_Outback is offline   Reply With Quote
Old 06-13-2008, 07:41 PM   #102
gongeuzler
Member#: 16103
GC's
I found an interesting method of soldering the wires to the plugs. I took .250" 16-14 gauge quick disconnects, and you can slide the bottom end over each pin, and they literally click in. The pin somewhat slids into the crease where you would normally crimp. With all 3 in place its a very snug fit. Im not to handy with the soldering gun yet so I cut off a tiny bit of solder, and it fits perfectly down the quick disconnect where you would normally crimp. So with the solder in place, I click the quick disconnect in place, and then let the solder melt and fall onto the pin. Gave it a tug to make sure the connection was good. With all 3 in place it came out looking like this.
To me this seems like a good idea, but then again the first time I touched a soldering gun was to do this swap so im still pretty new at it. What do you guys think? Some heatshrink and some epoxy and it should be good? Im hoping to get to the conversion this weekend.
gongeuzler is online now   Reply With Quote
Old 06-13-2008, 10:09 PM   #103
Kaymin
Member#: 96076
RIP 96 SBM GC8
05 Burnt Orange Evo
nice dude! looks clean unlike my **** but i just cut off the surrounding plastic and soldered right onto the pins and epoxied over it lol
Kaymin is offline   Reply With Quote
Old 06-13-2008, 10:57 PM   #104
Aphex28
Member#: 11506
2015 WRX
ah not bad. I ended up just buying a wrx engine harness for something like $40 just so I can have the pigtails
Aphex28 is offline   Reply With Quote
Old 06-14-2008, 12:36 AM   #105
Kaymin
Member#: 96076
RIP 96 SBM GC8
05 Burnt Orange Evo
wow! you must have found one used!
Old 06-14-2008, 10:51 PM   #106
kaos200
Member#: 2692
I have a set of new age coil plug connecters (with wire ofcourse) if anyone needs a set.
kaos200 is offline   Reply With Quote
Old 06-15-2008, 03:41 PM   #107
JayRObrero
Member#: 65744
02 wrx
white
i just did this conversion yesterday.. my car wasnt firing up. and it kept blowing fuses .. ne idea what causes this problem? everything is wired up as the instructions says i bought the pig tails for the newer coil packs and we wired merged it from there. if ne 1 can help with whats is going wrong please contact me thanks alot guys
JayRObrero is offline   Reply With Quote
Old 06-16-2008, 07:11 PM   #108
JayRObrero
Member#: 65744
02 wrx
white
Helppp!!!
Old 06-19-2008, 11:47 AM   #109
Not All There
Member#: 135615
1995 Impreza
The Ugly Panda
make sure non of the pins arent in contact with each other inside the new coilpacks, if they are touching it can cause the short to blow fuses, something is wrong with the wiring, check it all again, even the basics.
Not All There is offline   Reply With Quote
Old 06-24-2008, 10:05 PM   #110
brentos
Member#: 183155
Anyone got any sources to get 02 coils? every store around me is charging 190+ for each coil. Ill buy some used ones even i need some asap to get my car running.
brentos is offline   Reply With Quote
Old 06-25-2008, 12:31 PM   #111
kingsubi
Member#: 19239
2011 WRX
Get used ones. The new style hardly ever fail in comparison so going used is usually a safe bet.
kingsubi is offline   Reply With Quote
Old 06-25-2008, 03:22 PM   #112
brentos
Member#: 183155
Anyone know of a site that might have used coil's? Like a auto wreckers place or something?
Old 06-26-2008, 09:30 PM   #113
Not All There
Member#: 135615
1995 Impreza
The Ugly Panda
I have two 05 sti coils for $50. Wire up the same as the 02's and such, thats what im running on my car right now and these are my spares
Old 07-03-2008, 12:31 AM   #114
Joshb120
Member#: 179074
just finished the conversion on my car, works wonderful. couldn't be more pleased thanks for the write up!!
Joshb120 is offline   Reply With Quote
Old 07-10-2008, 02:27 AM   #115
clean 93
Member#: 181440
1993 wrx
Is there a model of the EJ20 that has a central coil pack rather than a coil on plug design? Reason I'm asking is because I have a set of nology plug wires that seem to be made for one and it's for an EJ20G.
clean 93 is offline   Reply With Quote
Old 07-10-2008, 03:01 AM   #116
keirnna
Member#: 50167
1996 Subaru STI RA
Yeah the EJ20K and the GC8 EJ205/7 both used central, manifold-mounted coil packs.
keirnna is offline   Reply With Quote
Old 07-25-2008, 12:11 AM   #117
DSM_Outback
Member#: 56345
93 Swapped L
Green
Awesome mod, thanks Rob.
I had to hack ish out of them to fit the Legacy style cam covers but well worth it.
18 psi and it pulls clean.
Old 07-25-2008, 01:56 AM   #118
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
It tastes like burning
cool. Glad it worked for you.
-Rob
rob is offline   Reply With Quote
Old 08-24-2008, 02:01 AM   #119
awd4ever
Member#: 31573
I found the
meaning of life!
an one knows if you can convert 98 rs into Coil on plugs?
awd4ever is offline   Reply With Quote
Old 08-24-2008, 05:45 PM   #120
keirnna
Member#: 50167
1996 Subaru STI RA
I'm sure it could be POSSIBLE, but why would you want to?
Old 09-09-2008, 07:05 PM   #121
oldhat
Member#: 113036
Almost two years later, one of the all time greatest hacks on a 20G.
oldhat is offline   Reply With Quote
Old 09-19-2008, 03:42 PM   #122
evankanga
Member#: 189730
1983 westfalia
Default which years/ models work? thanks
Going to do the mod.. one of mine is misfiring.
can i get STI's if only they are available?
is there a "best year to get" ?
thanks evan
evankanga is offline   Reply With Quote
Old 09-19-2008, 04:00 PM   #123
evankanga
Member#: 189730
1983 westfalia
hhhhhb
Last edited by evankanga; 09-19-2008 at 04:02 PM. Reason: posted in wrong section...sorry
Old 09-19-2008, 04:04 PM   #124
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
thanks evan
I don't think it will matter. Get what you can find cheap.
-Rob
Old 09-19-2008, 04:13 PM   #125
evankanga
Member#: 189730
1983 westfalia
thanks
WTB: WRX coil packs for the EJ20G coil pack conversion ASAP! Joshb120 Private 'Wanted' Classifieds 2 05-18-2008 12:42 AM
2000 Intake manifold, EJ20G Intercoolers, EJ20G coil Woki Toki Engine/Power/Exhaust 3 04-18-2008 11:54 PM
EJ20G coil resistance? snowman4us Pre-2002 Factory Turbo Powertrain 4 11-15-2006 01:52 PM
EJ20g Coil on Plugs newgensti Subaru Conversions 7 09-15-2006 11:07 AM
EJ20G coil packs scoobyimprza Subaru Conversions 2 08-29-2005 01:36 PM
