Old 09-25-2008, 10:01 PM   #126
evankanga
Member#: 189730
1983 westfalia
check this out...... http://picasaweb.google.com/evankanga/WRX#
the final 5 or 6 pics there show the cover, the old and the new.
the new coil packs have a larger diameter spacer/ bolt hole than the old style.
are people just using the skinny old style/original bolt and popping out the bolt plug thing, or are they drilling out the hole on the head for the new style bolt plug and using the skinny bolt.
i dont really want to drill in to the cover.
since this is not a direct fit.. does that mean i have some strange early jdm model ej20?
thanks all.... reallyy
--evan
evankanga is offline   Reply With Quote
Old 09-25-2008, 10:14 PM   #127
oldhat
Member#: 113036
Yes.
oldhat is offline   Reply With Quote
Old 09-25-2008, 10:23 PM   #128
evankanga
Member#: 189730
1983 westfalia
any advice from the peanut gallery?
Old 09-25-2008, 10:53 PM   #129
theonlygreat
Member#: 65916
1996 Impreza WRX
As long as you can get it secured on top of the spark plug, fit isn't real important. You could remote mount the coils, take off the boot, and run short spark plug wires to each one if you really wanted to.
The main thing is you don't really want them shaking around and you want the spark plug to be fully engaged with the boot.
theonlygreat is offline   Reply With Quote
Old 09-25-2008, 10:58 PM   #130
evankanga
Member#: 189730
1983 westfalia
i will go out and check out what i can do fitment wise with the copper bolt home pressed out. i am afraid it is going to be a pain, and might need to dremmel off a little material from the area around the hole on the coil side to make it fit.
--maybe just mounting manifold mounter coil packs would be easier?
Old 09-26-2008, 03:31 AM   #131
Aerotech
Member#: 159525
1991 Legacy 2.5RS-RA
I just finished doing mine (Legacy RS-RA heads, same as your van; offset holes), you have to hack off the big corner of the metal coil as pictured in the earlier post about Legacy fitment. I cut in about 1/2-inch deep from the corner... Use a Dremel, and buy a container of cutoff wheels. I tried a grinder, but it started to make a mess of the thin plates. Shoot it with some paint before install to prevent rust.
Left (drivers) side of the motor will fit easier than the other, for some reason, only a little filing of the ignitor case is needed. The other side required a lot of grinding (Dremel again, w/ drum sander) of the plastic case, on multiple corners, just work slowly and test fit a lot. Both sides will orient with the wire pigtail on the bottom. I re-used the original thin mount screws, one is plenty to hold it in.
It's a bit more of a hack on this motor, but end result is the same.
Aerotech is offline   Reply With Quote
Old 09-26-2008, 04:09 PM   #132
evankanga
Member#: 189730
1983 westfalia
Aerotech
i have found much out today.. but check out my latest pics and see if it makes sense.
it seems i have two igniters to bypass. http://picasaweb.google.com/evankanga/WRX#
the last two pictures show i have two igniters[ up on the right corner.. is this normal???
there is also an airflow sensor connection on the intake
so if i have two igniters.... what to do?
i am sure i can get fitment, but the electrical would be nice to know ahead of time
253 255 2168 just to shoot the $%^& if it makes it any easier
Old 09-26-2008, 05:17 PM   #133
evankanga
Member#: 189730
1983 westfalia
the coil packs now fit perfect!
--still waiting on advice on the supposed two igniters shown in the pics
thanks for all the help.
--evan
Old 09-26-2008, 05:44 PM   #134
evankanga
Member#: 189730
1983 westfalia
i have to igniters?? http://picasaweb.google.com/evankang...47612070767858
#1
red--green stripe
blue[lighter blue]
black
green--yellow stripe
yellow--blue stripe
#2
red--green stripe\
blue[darker]
black
green--white stripe
yellow--blue stripe
does this make any sense to anyone.. and no -- i did not build this. i'm only trying to clean it up
--thanks evan
Old 09-26-2008, 08:45 PM   #135
Aerotech
Member#: 159525
Sorry, that's beyond my experience... never seen that before. My best guess is that there's one for each bank of cylinders... looks like the installer marked the positions. You are going to have to shoot the wires with a multimeter or continuity tester to see for sure what goes where.
Pull the plugs off the ignitors and check continuity between there and the coil connectors, and also to the ECU plug that has the ignition pins... make a diagram or map of what goes where, it will help.
What you're trying to do is establish the trigger path from the ECU to the ignitors to the coils, then eliminate the ignitors by bypassing them so the wiring goes from ECU right to the coils. Make sure your battery is disconnected first.
Pay attention to the 12V routing, as mentioned in the write-up, Subaru wiring is usually 12Vdc switched = yellow/red stripe, but that stops at the coil connector, the red wire on the coil pigtail is 12V, the yellow is the trigger.
Nice setup in that van...air/water intercooler and all! I have a 1986 Syncro, and can't use that setup since my gas tank is living in that space above the transaxle. Anyhow, I went over to the dark side and am doing a TDI conversion now, ditched the Subie setup.
Old 09-26-2008, 09:07 PM   #136
evankanga
Member#: 189730
1983 westfalia
have fun with the tdi conversion
i did a 2001 ALH fly by wire with the immobilizer and everything.... and can only tell you to GO WITH A MECHANICAL INJECTION PUMP! no other advice needed.
as for gearing i did a 1.14 3rd and .70 4th with 29" BFG's on a syncro ... larger nozzles but with the manual tranny IP, and loved it. great MPG's do a TD, or AHU only
i also snapped an axle while wheeling///and flipped it over on it's side. whoops
thanks for the advice
Old 09-26-2008, 09:09 PM   #137
evankanga
Member#: 189730
1983 westfalia
However... to the rest.. have you seen this and ...any advice??
thanks
evan
Old 10-01-2008, 12:14 PM   #138
evankanga
Member#: 189730
1983 westfalia
well... i opened up the loams and traced wires and cut out the twin NA legacy igniters and made some temporary electrical connections. it fired right up and everything is fine so far.
solder next and then off for a test drive.
thanks everyone
Old 10-02-2008, 11:52 PM   #139
Aerotech
Member#: 159525
Nice!
I got mine all back together only to fry the (very rare and expensive) ECU with a mis-wired aftermarket O2 sensor... Took my sweet time with the coil setup, but rushed and botched a simple 3-wire connection.
Bollocks.
Old 10-20-2008, 08:29 AM   #140
mpaone
Member#: 3
2012 Geeteeeye
and 71' VW Gulf Beetle
Question
Question on symptoms of failing coilpacks...
Is a repetetive hesitation on full boost (about 4500, 5500, 6000) a possible coil?
I was going to do this conversion anyway but it seems more urgent now.
My Power FC is reading 15-20 knock level when this happens.
Thanks,
-Mike.
mpaone is offline   Reply With Quote
Old 10-20-2008, 12:52 PM   #141
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
It tastes like burning
Yep. Main symptom is misfires under boost, getting worse as boost and RPM goes up. Misfires will feel like hesitation or bucking when severe enough.
-Rob
rob is offline   Reply With Quote
Old 10-20-2008, 01:17 PM   #142
mpaone
Member#: 3
2012 Geeteeeye
-Rob
Awesome, thanks for the info.
Changed one out during lunch break (yes I am a sick man). Runs much better until I do the conversion.
-Mike.
Old 11-06-2008, 01:46 AM   #143
sniper512
Member#: 189923
1993 JDM WRX
Will bad coils cause misfire that you can hear at idle but not break up at higher boost(12psi)? I do have a bit of hesitation sometime in the upper rpm range and then it cleans out and pulls hard again. Other times it pull hard right to redline its very random.
sniper512 is offline   Reply With Quote
Old 11-06-2008, 02:19 AM   #144
Kaymin
Member#: 96076
RIP 96 SBM GC8
05 Burnt Orange Evo
does it hesitate under full gas and like 3/4 or even like 9/10 throttle feel fine?
that's how mine was and one of them was cracked
Kaymin is offline   Reply With Quote
Old 11-06-2008, 10:22 AM   #145
sniper512
Member#: 189923
1993 JDM WRX
Ya if your not at full throttle the car seems pretty good if not stronger than when at WOT. To me it feels like its pulling timing, but I guess it could be the coils causing misfires. The car doesn't break up even at full boost which is why I didn't think it was the coils, but I guess if they are on their way out this is how they would do it lol.
Old 11-06-2008, 08:38 PM   #146
mpaone
Member#: 3
2012 Geeteeeye
Completed (sort of) my coil conversion tonight. I just twisted and taped the ignitor wires for now to ensure it was all connected correctly.
Did not actually go for a ride since I have other things to install but let it warm up and revved it to about 6k. It is smooth as butter up top but idle is a little rough and searched between 1500 and 1000 for a while when cold. I think this is more the result of my PFC not being tuned correctly after removing the boost control kit and going back to stock solenoid and MAP.
I'll post back up once the car is tuned. I suppose I may have a bad coil but it's not likely (then again my stock MAP could be bad too).
-Mike.
Old 11-08-2008, 11:11 PM   #147
sniper512
Member#: 189923
1993 JDM WRX
Will 05 STI coils work for this conversion?
Old 11-19-2008, 10:38 PM   #148
beaviscih
Member#: 123362
'93 Crapcan, '98L
Sold, '04 STi - Sold
Going over the EJ20G while it's on the engine stand and sure enough, one of the coils is cracked. At least it will be easier to do while the motor is out of the car. Great write-up!
beaviscih is offline   Reply With Quote
Old 11-19-2008, 11:30 PM   #149
gongeuzler
Member#: 16103
GC's
Im using 05 STi coils, well supposedly from what DS1 says. It took many PM's and a couple months of BS shipping excuses to get them so who knows what they really are but at least they work.
gongeuzler is offline   Reply With Quote
Old 11-20-2008, 01:17 AM   #150
sniper512
Member#: 189923
1993 JDM WRX
Nice well hopefully its the problem. It's just so hit or miss. Just before the car is fully warm it seems to go like a raped ape then dog at full temp. If you continue driving it, it will sometime be fast again. Could the IAC cause this issue or maybe even the recir valve?
WTB: WRX coil packs for the EJ20G coil pack conversion ASAP! Joshb120 Private 'Wanted' Classifieds 2 05-18-2008 12:42 AM
2000 Intake manifold, EJ20G Intercoolers, EJ20G coil Woki Toki Engine/Power/Exhaust 3 04-18-2008 11:54 PM
EJ20G coil resistance? snowman4us Pre-2002 Factory Turbo Powertrain 4 11-15-2006 01:52 PM
EJ20g Coil on Plugs newgensti Subaru Conversions 7 09-15-2006 11:07 AM
EJ20G coil packs scoobyimprza Subaru Conversions 2 08-29-2005 01:36 PM
