#151 |
Member#: 192443
Would these work?
http://cgi.ebay.com/ebaymotors/JDM-V...Q5fAccessories If not, could someone link any that would work. Not alot of coils here in iceland...
#152 |
Member#: 50167
Vehicle:1996 Subaru STI RA White |
Those are stock replacements. They will have just as many problems as the ones you already have. You need US 2002+ EJ20 coil-packs.
#153 |
Member#: 192443
#154 |
Member#: 50167
No, but the model years are different elsewhere. Basically any bug eye coil pack will work. 2000+ if Japanese.
#155 |
Member#: 197120
Hi. I have a 95 WRX that has had an engine swap and it turns out that it actually now has a legacy engine the one that uses the twin bolt coils. I still have the old engine with the 1 bolt cols and was wondering if I could swap the rocker covers over so I can use 1 bolt coils in the legacy engine. Or do the coils bold in the cylinder heads as well?
I have already modified the 1995 1 bolt coils to fit the legacy engine so Im sure I could do if to the 2002 coils as well I just wanted to know if changing the rocker covers is another option since I have them anyway |
#156 |
Member#: 196721
VIC
Vehicle:1993 GF8 WRX Wagon Black |
Just a note for anyone looking at their original coilpacks. The back of the coilpack is filled with a clear white resin. If this resin turns black, it usually means the coilpack is no good - even if you can't see any cracks.
#157 |
Member#: 50167
Not all of them came from the factory clear like that. Some came black.
#158 |
Member#: 189923
W. Canada
Vehicle:1993 JDM WRX Black |
Mine are now discoloured brown lol and 2 are cracked to hell. I need new ones bad. I am still looking for a good used set of 02+ WRX coils
#159 |
Member#: 196721
VIC
I just got a brand new set of replacements from Japan for mine - sure starts and runs a lot better now.
#160 |
Member#: 189923
W. Canada
How much and where?
#161 |
Member#: 196721
VIC
Mine were a favour from a friend, but you can buy them online here at a decent price: http://www.grahamgoode.com/subaru/pa...93&item=GGS564
You may even be able to order them locally, the part number is 22433AA330 |
#162 |
Member#: 180513
RMIC
Vehicle:Baby Baby C'mon! Looka Bomba! 99 JDM GM8 |
so in a nutshell
get 4 02 wrx ignition coils, cut old ones, solder these in, cut off the wire and done? |
#163 |
Member#: 192848
South East
Vehicle:1998 GC8 rsti BDP |
then straight wire the ignitor^^^^^ and make a ground for the usdm coils to ground where the bolt holds the coil down.
#164 |
Member#: 189923
W. Canada
Just ordered a brand new set from Subaru today. I should have them in about 4 days. I'll let you know how my hesitation and power loss works out.
#165 |
Member#: 189923
W. Canada
So the new coils are in and the misfire issues at idle are gone. The car is more responsive, but the car is still sometimes feeling like it has no power when you go wide open. The car is building full boost quick as usual. Its almost like the car isn't using the boost if that makes any sense.
#166 |
Member#: 192848
South East
boost leak possibly^
#167 |
Member#: 189923
W. Canada
So even with building full boost like normal it could be a boost leak hmmm........I wonder if it could be the recirc valve?
#168 |
Member#: 168594
Vehicle:1993 JDM GC8 WRX silver with dirt |
Sniper
Whats the latest on this? Sort out your issues? What part number did you use to order them here in canada? Or did you get the UK versions? I am running 93 jdm wrx here in vancouver. Some of the same problems, knocking sound at full boost, hard starts when warm, etc. cheers |
#169 |
Member#: 189923
W. Canada
I will have to look up the part number again. Basically any USDM 02+ WRX coils will work. One of the benefits to ordering new is that there have been several updates to the coils in the past few year. If you go into a dealer just get them to look up the latest coil for a 02 WRX.
I think I got it figured. The car came with some NGK platinum one step colder so #7's. I replaced these with NGK Lasers at the stock heat range #6's. This caused lots more misfires at idle. When I did the coil conversion it helped, but there was still a problem. I changed back to the plugs that came with the car and it was way better. Today I said screw it and got a set of Copper NGK BKR7E's because I was still seeing some misfires at idle. After the change to the cheap coopers the car is running amazing. I think my issues were both the coils and the plugs. I think it is weird that I need to run colder plugs to not have misfires at idle could this mean that my ECU is tuned from Japan? or is it possible I have another issue going on? Cheers |
#170 |
Member#: 189923
W. Canada
Well another update problem is not fixed. Power loss was gone for about a day and now intermittent power loss is back. Time to burn it.
#171 |
Member#: 164172
NWIC
Vehicle:97 OBS EJ20G ZILLA 87 GL |
i converted mine to 05 sti coils... and i was in 3rd... WOT... and it still mis fired 2 times.. ( i heard it )... but i tried it again... it worked.... idk i guess it just reduced the occurrence for me..
#172 |
Member#: 194742
E. Canada
Vehicle:1993 Impreza WRX JDM Silver |
Well, I'm glad at least we're all in the same boat, I seem to have it the worst with the power loss issue but we're all experiencing the same misfires / power loss / unused boost (yeah, really weird) / relay click.
first one to solve it gets a cookie :P |
#173 |
Member#: 171770
NWIC
Vehicle:1994 Impreza Wagon Dark Silver Mettalic |
Add another to the conversion list. I felt like a geniuus after all the soldering and wires cutting etc...
#174 |
Member#: 192443
So it works for some people and some it doesn't ?
Anyway, can I use these? http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=170306922175 This is what I am looking for right? + I do not have the Ej20G from an Impreza but from a (JDMyo)Legacy. Does this matter? From what I have seen there is a slight difference with the coils. In the Impreza(this i have only seen on ebay) there is only 1 bolt that goes in the coil(to keep it in place) but on mine there are 2. My country is broke and so am I so I am really concerned for buying the wrong coil. Last edited by olig; 03-04-2009 at 07:45 AM. |
#175 | |
n00b Moderator
Moderator Member#: 811
Vehicle:2000 RS-Ej20G It tastes like burning |
I would say the conversion works for everybody. However some people have other issues that they suspect are ignition related, but turn out to be something else. I have been running strong ever since I first posted this conversion, and now I'm up to around 320chp with no hint of ignition trouble. Since you have the Legacy motor, you will have to modify the new age coils a bit to fit the cam cover. Someone posted a really good detailed description of what to do (thought it was earlier in this thread). If you cant find it, I'll see if I can repost as I think I save the pictures. -Rob |
| Thread Tools | |
| Display Modes | |
| WTB: WRX coil packs for the EJ20G coil pack conversion ASAP! | Joshb120 | Private 'Wanted' Classifieds | 2 | 05-18-2008 12:42 AM |
| 2000 Intake manifold, EJ20G Intercoolers, EJ20G coil | Woki Toki | Engine/Power/Exhaust | 3 | 04-18-2008 11:54 PM |
| EJ20G coil resistance? | snowman4us | Pre-2002 Factory Turbo Powertrain | 4 | 11-15-2006 01:52 PM |
| EJ20g Coil on Plugs | newgensti | Subaru Conversions | 7 | 09-15-2006 11:07 AM |
| EJ20G coil packs | scoobyimprza | Subaru Conversions | 2 | 08-29-2005 01:36 PM |
