Old 01-31-2007, 07:26 PM   #1
Drive4Ever
Member#: 65376
2004 Impreza WRX
Default 04 Sti Hid --> 04 Wrx
Hi all,
I have recently purchased a set of JDM STI HID headlight system and custome wiring harness from wagons_ho!
http://img226.imageshack.us/my.php?image=img0369eb8.jpg
I installed the lights and harness today but here comes the problem. As you all can see, its an easy plug and play with both ground goes to the fender. but for some reason whenever i turn the light on, the driver side HID keeps flashing and passenger side HID lid up just fine, and also, both highbeams are on, not lid completely but enough to make people notice. At first, i though it was just a bad ground connection, but i have checked over and over again and its not the connection. Then i though it might be the harness, but the harness works just fine and so are the headlamps. So right now, i'm completely clueless about how to fix it. Anyone? help!!!
Thank you.
-andy
Drive4Ever is offline   Reply With Quote
Old 01-31-2007, 08:28 PM   #2
crewchief97
Member#: 97269
2007 Toyota Tacoma
Dbl Cab 4x4 Super White
Did you disonnect your DRL lights from behind the glove box?
crewchief97 is offline   Reply With Quote
Old 01-31-2007, 10:36 PM   #3
Drive4Ever
Member#: 65376
2004 Impreza WRX
I have disable my daytime running lights for almost 2 years now.
unless you are talking another DRL module that i wasnt aware of? is it the one by the factory turbo location?
Old 01-31-2007, 11:30 PM   #4
richy_21
Member#: 58670
2005 got muuuuu?
could be the hids themselves.
richy_21 is offline   Reply With Quote
Old 02-01-2007, 12:34 AM   #5
Drive4Ever
Member#: 65376
2004 Impreza WRX
nope, test them out already, no problem. i think i may have find the problem. will find out tomorrow. going to try to disconnect the DRL module completely
Old 02-02-2007, 03:50 PM   #6
crewchief97
Member#: 97269
2007 Toyota Tacoma
Did you get your lights working? If not try this link to see a pic of what connector you need to disconnect. Brian
http://forums.nasioc.com/forums/show...&highlight=drl
04 sti tranny --> 07 wrx - new seals or axles? Bad Noodle Transmission (AT/MT) & Driveline 15 01-30-2009 10:35 PM
04 STI engine -> 02 WRX questions SpooksRex Subaru Conversions 3 10-01-2008 01:43 AM
? about 04 WRX <-> 06 WRX and 04 STI <-> 06 STI scoops. Aleksey Subaru Conversions 3 03-26-2006 11:52 AM
PnP Adapter 04 STI Hid to 05 WRX gqchynaboy Electrical & Lighting 9 11-03-2005 06:30 PM
04 STI spoiler -> 02 WRX undrilled trunk help needed LDragon Interior & Exterior Modification 7 07-08-2003 09:57 PM
