Old 01-31-2007, 09:52 PM   #1
page02wrx
Member#: 124053
Back to BONE STOCK
Default Idle air whatever control, weird idle
Got a weird idle, I think its that thing that I can't think of... hoping some one here can help me out so I can search on how to clean/replace it... IARC or something weird....
In any case, I put my car back together after winter and the idle was a little high (1.5k+).... I've been saying for a week now I'd fix it but its so damn cold and I work hard and well..... I'm just lazy.
Anyway at the auto car wash today something weird happened.
I'm sitting there at my usual 1.5k idle, in neutral.... when all the sudden its like the ecu took over and dropped me down to 900.... And for about 5 seconds it was a steady 900rpm idle... but then after every 2-3 seconds there would be a quick surge down to 800 or so and then it shot back up to 900...
It was barely noticable by the tach, but you could hear it in the idle.
Anyway, when I reset my ECU it goes away and I go back to idling at 1.5k.... but if i let it idle for more than a few minutes then I get that weird idling AGAIN. It also effects the car during very slight throttle position.... I'll get bucking if I just press the gas in like 10%, but if I put it about halfway down its fine.
Maybe its just a dirty maf....
page02wrx is offline   Reply With Quote
Old 01-31-2007, 09:56 PM   #2
hondaeater69
Member#: 60324
dirty maf, dirty IAC.. are you throwing any codes? TGV is also a thought...
thread on how to clean IAC:
http://forums.nasioc.com/forums/show...ight=clean+IAC
Old 01-31-2007, 09:59 PM   #3
page02wrx
Member#: 124053
Back to BONE STOCK
Thanks, the IAC wow I was even saying Idle air control but I was thinking that was wrong....
Codes I have no idea my check engine light is always on due to my "leaky gas cap" thats turned in the whole way... i'll grab my friends obd2 scanner tomorrow though and we'll see.... i'll start by cleaning the maf and iac tomorrow though
Old 01-31-2007, 10:08 PM   #4
hondaeater69
Member#: 60324
def check the codes...that may tell you exactly what you need to clean/fix.
and that small leak you have, may not be from your fuel cap, could be a leak anywhere in the system...charcoal box...somone found a small leak in one of the lines under the hood that threw that code... i would search the PXXX and you'll probbaly narrow it down. if you cant, and it doens't pose any real problems, you can probably defeat the code if you're using a reflash software... i was throwing a TGV code that doesn't affect ish so i just defeated the code to be done with it, now no more CEL. that way if you throw a CEL for a real problem you'll know about it
Old 01-31-2007, 10:13 PM   #5
page02wrx
Member#: 124053
Back to BONE STOCK
yeah
I actually got completely sick of it one day so I took it to a dealer, they tried finding the leak.... cost me a couple benjamins for them to tell me
"we couldn't find the leak...."
followed by
"you should just leave it because you'll end up spending more money on finding it than what its worth"
if enginuity can clear the code, tell me how lol
Old 01-31-2007, 10:28 PM   #6
hondaeater69
Member#: 60324
don't know how enginiuty works, but with street tuner i just check the box next to the PXXX code and it's put to bed.
Old 01-31-2007, 10:33 PM   #7
page02wrx
Member#: 124053
Back to BONE STOCK
OT but allentown, i was just there yesterday installing a countertop =-o WEIRD
i dont think enginuity lets you mess with codes, i'll do more research on it..... i dont have an AP to do that
Idle Air Control Valve: Anyone had this replaced? IceClimber Service & Maintenance 7 04-04-2015 05:33 PM
Idle Air Controller Yotsuya Normally Aspirated Powertrain 15 06-27-2004 07:56 PM
WRX Idle/Air control valve djerickd Private 'Wanted' Classifieds 11 12-02-2003 11:37 AM
Idle Air Controller SubaruImpreza_power Normally Aspirated Powertrain 3 09-19-2003 02:04 PM
idle air control valve, after a turbo mod mild_se7en Normally Aspirated with bolt-on Forced Induction Powertrain 1 08-10-2002 07:45 AM
