#1 |
Member#: 9878
Vehicle:2002 WRX/GTX WRX Wagon/Mazda GTX |
I just called my local parts store on the NGK plugs for the WRX. $17 EACH!!!! Come now, there has to be another option???
Anyone have a source for plugs that may be more resonable and just as good as the NGK's? I really want the NGK though because I have always had very good results with them. I was after one heat range cooler and the NGK parts catalog does not list a 7 range plug yet. PS: sitting up here on the 6th floor at Madigan hospital I see a white WRX sedan trolling for a parking spot. I always park at the very end where no one wants to park because its too long of a walk for those lazy butts. Keep the chilly bin full!
#2 |
Member#: 10228
Vehicle:2002 Subaru WRX |
That doesn't sound too bad, denso Iridium's go for that much but I haven't been brave enough to swap mine out. Actually it's more being lazy.
#3 |
Member#: 3409
NWIC
Vehicle:1998 Ram 2500 Green. |
$17 each? I just bought two sets for my RS for a hair over ten bucks.
![]() Stick with the copper. |
#4 |
Member#: 456
NWIC
Vehicle:2008 Forester XT Steel Gray Metallic |
Horatio, have you tried running copper plugs in a forced induction engine?
Sure, they work, but you'll be changing them in 8,000-12,000 miles or so. Subarus are hard enough to change the plugs that using platinum is worth it. Why do people always want to fix something that ain't broke? I've had 5 turbo cars in the last 8 years, 4 of them with NGK platinums from the factory, and the other one I switched to NGK plats and it cured a bunch of problems I was having. I tried a bunch of different plugs too. Glenn PS the white WRX wasn't me Greg! |
#5 |
Member#: 9015
Vehicle:2002 Impreza 2.5RS Platinum Silver Metallic |
Are the plugs that tough to change? I only have experience on my RS, which is rather easy. Does the turbo equipment of the wrx block easy access to the plugs?
#6 | ||
Member#: 3409
NWIC
And the RS is easy to change plugs. Plug socket, 6" extension, ratchet, and a 10mm socket are all you need for it. The only plug I have to remove anything for is the driver's rear, and I have to pull the washer reservior screws out to move it to the side a little. It took about ten minutes. Put new plugs in tonight while I was changing the oil. The hesitation/jerking while under wot is gone. Smooth as a baby's butt. ![]() Anybody got that little photo that shows how to read spark plugs? |
#7 |
Member#: 456
NWIC
I seem to recall it involves battery and tray removal, washer bottle on one side, and part of the air box on the other side.
And of course you have to unbolt the coil packs from on top of the plugs as well (use care). Pretty sure they're supposed to be good for at least 30,000 miles. Glenn PS I use NGK coppers in my Lotus engine. Lov-er-ly. Nothing wrong with them in N/A cars. |
#8 |
Member#: 3409
NWIC
My dainty hands get around the battery & tray just fine. The washer bottle had to move though. I guess the stock air stuff would be in the way, but the Cobb intake isn't.
What's this about unbolting the coil packs? Is this a new WRX thing where the coil sits on the plug itself? |
#9 |
Member#: 456
NWIC
Yes, like the SVX. I think they're a 10mm bolt? Very light torque too (don't strip!).
Glenn |
#10 |
Member#: 7962
Vehicle:05' V35 Skyline PSM 02WRX -SOLD |
What tools will i need on hand to change my plugs in the WRX??
Also, what is the NGK part # for one and two ranges colder? Thanks Bill |
#11 | |
Member#: 7089
NWIC
Vehicle:05 Legacy GT Sedan 07 4Runner Limited |
#12 | |
Member#: 3409
NWIC
#13 |
Member#: 12647
Vehicle:2011 STi Obsidian Black Swirl |
Slut = Does it with everybody
Whore = does it with everybody but you LOL ![]() |
| Thread Tools | |
| Display Modes | |
| NEED: Plug/Clip that plugs into WRX spark plug coil | BeBop86 | Private 'Wanted' Classifieds | 16 | 07-16-2008 03:05 AM |
| Colder WRX Spark Plug, assistance needed! | JayGold | Factory 2.0L Turbo Powertrain | 1 | 04-16-2002 06:54 PM |
| WRX Spark Plug Questions?? | PunksWRX | Factory 2.0L Turbo Powertrain | 5 | 02-25-2002 10:42 AM |
| 2002 Wrx Spark Plugs?? | mdntridr | Factory 2.0L Turbo Powertrain | 3 | 01-03-2002 05:07 PM |
| WRX spark plugs wanted. | gpd323 | Service & Maintenance | 3 | 11-29-2001 05:26 PM |
