Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 02-01-2007, 06:13 PM   #1
whitetyger23
Member#: 115472
2005 Impreza WRX
white
Default Oil questions and help please
I have a problem ....I had my oil changed at one those oil change places that specialize in mobile 1 oil. Now I have done this before and have had no problems. Now all of a sudden I have an oil leak ........I have gone back to the place twice and they tell me that nothing is leaking but I see the oil! they then proceeded to tell me that maybe I am burning the synthetic oil. I have never heard of that before. Has anyone else heard of this if so please tell me. I just think that they are incompetent and don't want to admit it. When I checked my oil I was a quart or so short. I just changed the oil a month ago and my car only has 27000 miles......please help. THanx
And yes I feel stupid.
whitetyger23 is offline   Reply With Quote
Old 02-01-2007, 06:47 PM   #2
Mavrik
Member#: 90347
2013 BRZ & Imp 2.5RS
Yamaha FZ8
Are you seeing a leak or noting any smells of burning oil? maybe they gave you a defective oil filter or double gasket on the drain plug?
Mavrik is offline   Reply With Quote
Old 02-01-2007, 06:50 PM   #3
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
Burning oil is quite common - in fact especially so with the 5W30 Mobil 1 synthetic.
Where are you seeing the leak? Can you trace it?
UkNuck is offline   Reply With Quote
Old 02-01-2007, 07:48 PM   #4
dibblejr
Member#: 94070
05 LGT
First taking your car to a quick lube place, I wont beat you up but man DIY or ask a buddy.
Most quick lube place lose the crush washer or reuse this $.04 washer. Also as mentioned above they could have accidently used a double oil filter seal, however usually doing this will result in a very sudden loss of all fluid.
I bet on the crush washer.
JAy-R
dibblejr is offline   Reply With Quote
Old 02-02-2007, 12:38 AM   #5
smyth
Member#: 42243
2003 Impreza WRX RIP
1996 Impreza L- Blown Eng
turboed cars tend to "consume" more oil than naturally aspirated vehicles. alo, in my experience, subarus seem to cosume a bit more mobile 1 than other brands, i recommend royal purple.
you said you lost 1 qt in a month, but how many miles did you put on it in that time?
-Kyle
smyth is offline   Reply With Quote
Old 02-02-2007, 12:39 AM   #6
smyth
Member#: 42243
what he said
+1
-Kyle
Old 02-02-2007, 12:47 AM   #7
my03rx
Member#: 126422
2003 impreza WRC
true true with all it could be the oil pan gasket. alot of the time the gaskets on the subaru's need to be changed if the car is turboed when the car gets hot what else gets hot the oil duhhhh where does the oil go when the car was just running to the pan and when it's hot and the oil sits it screws the gasket up, and it could be the washer but when your driving and you get pissed u tend to beat the hell out of the car and don't lie but mobl. 1 i had alot of oil loose so i switched it to royal. if it doesn't work try a thicker oil like 10w30 alot of turbo cars do it.
my03rx is offline   Reply With Quote
Old 02-02-2007, 04:04 AM   #8
Rexwagon03
Member#: 127429
2006 Legacy GT Limit
i use mobil one. i have a stage 4. i start losin some oil around 2,000 miles. if the car runs good. dont notice any blue smoke and u cant trace the leak, and u dont notice a huge puddle then ur probably good. you own a subie. they sip oil.
Rexwagon03 is offline   Reply With Quote
Old 02-02-2007, 04:10 AM   #9
eh1525
Member#: 116619
2005 Impreza RS
Crystal Grey
crush washer.
thats my guess.
and make sure they didnt stripp ur oil plug. they did it to mine. had to take it in for the first oil change. i went to change it my self next time.. and i had a hell of a time getting it off. i need to get a new one. somewhere..
eh1525 is offline   Reply With Quote
Old 02-02-2007, 08:57 AM   #10
Corkfish
Member#: 39503
Probably the crush washer or the filter gasket. Could be as simple as a loose filter or they may have accidently left the old filter gasket on when putting on the new filter. You might have two gaskets on there.
Corkfish is offline   Reply With Quote
Old 02-02-2007, 03:29 PM   #11
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
It could be anything mentioned here... i have something to add though... An X-Subaru mechanic once told me that useing synthetic oil in a sube isn't that great of an idea... He noted may times pulling the heads off subars with 30k on them (older head gasket issues) and still being able to see the hash marks in the cylinders from initial machineing... The use of synt early in the cars life doesn't allow proper break-in as he noted.
He said to me as long as you are changing your oil regulary there was no reasion to use synth, and was not really a good idea because it doesn't "coushion" parts the same as dino-oil.
I don't know it made sense to me at the time. Just my .02$
Also, i know your car is much newer than mine, but i had to have the threaded bung in my oil pan welded as it started to leak at the spot welds from the oil change process...and flexing the bung in the pan...
Old 02-02-2007, 03:43 PM   #12
smyth
Member#: 42243
I agree to a point, but dino oil is recommended for the break in period anyway, so i don't see how that situation could have been caused by synthetic oil used later on.
just my 2 100ths of a dollar
-Kyle
oil spill over!! help please! theycallmebrown Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 44 10-15-2008 11:16 AM
07 Sti oil feed line HELP Please BillMac Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 19 01-26-2008 01:46 PM
Smell like rubber burnt when engine oil is low? Help please. sfwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 06-20-2005 02:24 PM
Oil Pressure Guage help please?!? KJY9 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 07-28-2004 02:09 PM
clutch question need help please. Qaveboy Transmission (AT/MT) & Driveline 0 09-08-2003 02:44 PM
