Welcome to the North American Subaru Impreza Owners Club Thursday May 28, 2015
Old 02-01-2007, 07:03 PM   #1
arcsound
Member#: 10603
2014 CrossTrek XV
Khaki
Default Heating System Question; 04 Forester
I have an '04 Forester XT which since Day 1 has had a problem with the heating system; when I start the car on cold mornings, and after the engine reaches NOT, the heat comes on full heat, regardless of the Temperature knob setting, except totally off (fully CCW). After about 20 minutes of driving, the Temp knob begins to respond normally, and I can select any temperature, from luke warm to extremely hot. Note: I have the climate control system, not the manual system, but I am always using it in the "manual" mode, i.e. Auto light off.
Has anyone else experienced this phenomenom? I would prefer not to choose between sweltering and shivering during the first part of my commute...
The dealer said they couldn't find anything wrong with the system, (of course...).
arcsound is offline   Reply With Quote
Old 02-03-2007, 05:41 AM   #2
06grayrex
Member#: 116132
2006 wrx tr Stage II
sgm Jorge tuned -RIP :(
I have heard that a lot of legacys have had a simular problem with the climate control but do not remember what the exact cause was. There maybe a problem with the programming that controls the air blend doors: ie vacuum leak or climate control unit itself????????????
06grayrex is offline   Reply With Quote
Old 02-03-2007, 07:54 PM   #3
Alan
Member#: 3601
2006 WRX Wagon
BRIGHT BLUE!
You need to take the fan control off the auto position if you want manual control of air flow. Otherwise if car is colder inside than about 50 degrees the fan will automatically try to put out full heat until the temperature sensor is warmed up.
Alan is offline   Reply With Quote
Old 02-04-2007, 03:58 PM   #4
frogmonk
Member#: 74489
'04 FXT/'05 Baja T/
'71 ff-1
This is a known and common problem. Here is one fix that I've installed on my FXT. It doesn't completely solve the problem, but it works better than w/o the fix,:http://www.geocities.com/samiam_68/S...CS/SSC_Fix.htm
frogmonk is offline   Reply With Quote
Old 02-09-2007, 11:12 PM   #5
arcsound
Member#: 10603
2014 CrossTrek XV
Khaki
Thanks to all the responders. Unfortunately, I think my situation is somewhat different, in that I am experiencing the problem while in the "manual" mode, i.e. not with the climate control system activated. It seems to be related to how the Temp control knob controls the coolant flow going to the heater core, i.e. it seems the valve is wide open regardless of the knob position, for the first 15 minutes or so after starting the car from cold. Weird.
Old 02-10-2007, 12:34 AM   #6
Alan
Member#: 3601
2006 WRX Wagon
BRIGHT BLUE!
The Temp control does NOT control the coolant, just the position of the airflow door (flap) inside the heater box. The coolant flows through the heater core all the time. I wonder if the door is sticking due to frozen moisture inside the heater box and when it warms up it thaws and then moves freely.
And in cold mornings the heater should come on full hot until the sensor is warmed beyond 50F or so.
Old 02-10-2007, 10:37 AM   #7
arcsound
Member#: 10603
2014 CrossTrek XV
Khaki
Interesting, this information re: the actual workings of the heater control mechanism helps. (Note: I can rule out freezing of the flap, since it also occurs when the ambient temp is above freezing) It is starting to sound like it is actually behaving "normally", which is too bad that Subaru would think that baking the customer is a good thing. Why couldn't they have offered Climate Control as an option on the XT, as I certainly prefer manual HVAC controls?!
So, the mod previously mentioned may help, by getting the "system" to realize the interior is actually warm enough to start closing the flap (earlier...)?
FS: brand new take-out sound system...04 Forester petrol Texas Impreza Club Forum -- TXIC 12 05-17-2004 03:22 PM
Forester XT Heating System arcsound Electrical & Lighting 0 04-16-2004 04:36 PM
Uneven heating system, vents bluestone Newbies & FAQs 1 10-28-2003 03:55 PM
Air/Heat System Legacy L Problem cz596n Legacy Forum 0 09-28-2001 08:43 AM
Retrofit heated mirrors on a Forester L ? Crashton Forester Forum 2 02-20-2001 04:38 PM
