Texas Impreza Club
Texas Impreza Club Forum sponsored by Gillman Subaru Houston
and Gillman Subaru San Antonio
Go Back   NASIOC > NASIOC Chapters > Texas Impreza Club Forum -- TXIC
Old 02-02-2007, 04:31 AM   #1
prototypeWRX
Member#: 78739
06 RSX Type S
White/CF
Default It's just after 3am and I just finished installing the TiC rear diff race bushings
Not a commonly installed part from what I've seen/heard. I'll actually drive on it tomorrow and see what a difference the bushings make.
Getting the two center studs out is a real pain, but the stock bushings pulled right out with just a flat head screwdriver and no C-clamps/workbench.
That is all.
prototypeWRX is offline   Reply With Quote
Old 02-02-2007, 07:47 AM   #2
jamesohoh7
Member#: 39070
GTF off my lawn!
That is all.
I put them on my car. Makes a good difference on shifting... no more huge clunk. I was shocked at how squishy the stock bushings were. Well worth the $$ + effort just to get rid of that clunk.
I had no trouble getting the studs out, but it was a beeotch getting them back in... took at -least- half an hour of nudging the brace around to get it -perfectly- lined up over the holes so that I could get the threads started. A fair dollop of cursing helped that right out though... after which, the car complied and bent to my will and I finished the install.
jamesohoh7 is offline   Reply With Quote
Old 02-02-2007, 09:32 AM   #3
TJ
Member#: 41735
I'm on your lawn
do something about it
congrats on the install chris
stuff benting at james' will...Impossible! ahah
TJ is offline   Reply With Quote
Old 02-02-2007, 10:52 AM   #4
bpwatts
Member#: 111635
That is all.
I'm not looking forward to my install of those either.
bpwatts is offline   Reply With Quote
Old 02-02-2007, 11:57 AM   #5
aschen
Member#: 30733
2007 tiny car
striped
I have always wanted to get these but never pulled the pin. What was your total instal time? James did you install the whole kit? I thought you just did the otrigger bushings or something?
aschen is online now   Reply With Quote
Old 02-02-2007, 12:01 PM   #6
prototypeWRX
Member#: 78739
06 RSX Type S
White/CF
Getting the diff back up and the holes lined up was simple, I just held my finger to the outer bolt hole while jacking the diff back up slowly. Once I felt the holes seemed to line up sure enough it was a perfect fit. I could do that part again with my eyes shut.(they pretty much were anyways because I left the rear diffuser on and couldn't see the holes)
Old 02-02-2007, 12:06 PM   #7
prototypeWRX
Member#: 78739
06 RSX Type S
White/CF
Probably took me about two and a half hours.
I was up late working and then felt like getting something on the car done before going to sleep. Also just got over strep throat after almost a week and I'm really really sick of staring at all these parts laying around on my floor.
Old 02-02-2007, 12:09 PM   #8
aschen
Member#: 30733
2007 tiny car
striped
Thanks, 2.5 hrs is not too bad, ill prob order some soon.
Old 02-02-2007, 01:48 PM   #9
H.K. Phooey
NASIOC T-Shirt Crew
Member#: 35509
That is a great read and thanks for the step by step.
H.K. Phooey is offline   Reply With Quote
Old 02-02-2007, 02:33 PM   #10
prototypeWRX
Member#: 78739
06 RSX Type S
White/CF
Just drove on it for the first time. I have to say I definitely like it. The rear end feels more predictable now. I also have the Whiteline outter rear subframe bushings installed though. I haven't tried the subframe locking bolts yet, but they're in my glovebox and next in line.
Old 02-02-2007, 03:09 PM   #11
jamesohoh7
Member#: 39070
GTF off my lawn!
I only put the diff support bushings in, same ones he's talking about in the original post. I didn't do the outrigger bushings b/c there's still some 'debate' as to whether they're ST legal.
It took me about an hour + 15 or 20 ... a large chunk of which was lining up the stupid diff and the holes in the bracket upon reinstall. It is incredibly 'tight' and you're screwing this thing back into aluminum threads, which I was very leery of stripping. I applaud the luck of prototypewrx for getting his to line up so fast.
Old 02-02-2007, 03:15 PM   #12
prototypeWRX
Member#: 78739
06 RSX Type S
White/CF
I think I'll be helping Brian pretty soon so we'll see if I can do it again or if it was just luck. One thing that I think might have made it so easy is that I used a jack that only goes straight up and down, not like the typical jack that slides either front/back or side to side. So when it was time to reinstall all I had to worry about was getting the height right which was easy to feel w/ my finger in one of the outer bolt holes.
Old 02-02-2007, 05:32 PM   #13
jamesohoh7
Member#: 39070
GTF off my lawn!
That's a good idea, using a 'vertical only' jack (guessing you used a bottle-jack?)... I can see how that would've helped. My jack let the diff rock around a bit.
Old 02-02-2007, 06:11 PM   #14
prototypeWRX
Member#: 78739
06 RSX Type S
White/CF
Stock butterfly jack FTW! Haha so many people don't think to use it in some of the most useful situations. I just turned it by hand to raise/lower.
Old 02-02-2007, 07:02 PM   #15
rjacobs
Member#: 80127
Well, I guess there will be enough people who know how to do the bushing install that will be able to help me once the weather warms up. Im gonna do lots of bushings at the same time; Klunk Killer, Holy Shift set, and Cusco Mounts.
rjacobs is offline   Reply With Quote
F/S MD: TiC Rear Diff Mount Bushings COMFORT passion4JC MAIC Private Classifieds 3 08-28-2008 10:03 AM
F/S MD: TiC Rear Diff Mount Bushings COMFORT passion4JC Drivetrain 3 08-28-2008 10:03 AM
F/S MD: TiC Rear Diff Mount Bushings COMFORT passion4JC Suspension/Brakes/Handling 1 08-28-2008 10:02 AM
TIC Rear diff mount bushings e-zee Transmission (AT/MT) & Driveline 10 06-28-2008 10:37 PM
FS: TiC Rear Diff Mount Bushings - COMFORT - $35 shipped InfamousDX Drivetrain 4 06-11-2008 08:52 PM
Message Board Statistics All times are GMT -4. The time now is 03:51 PM.
