Old 11-29-2001, 05:18 PM   #1
yamarocket630
Member#: 9436
05 Saab 9-5 Aero
Question Driveline power loss and dynos
O.K. theoretical question here.
Let's assume that car X makes 100 crankshaft horsepower, and puts 85 hp to the wheels stock. That gives us a net driveline loss of 15% or 15 hp in this case.
Now lets bolt on high performance part Y, that bumps this motor to 125 crank hp. Assuming that all other variables (tire size, gear selection, max power rpm etc) stay the same, would we see 106 hp (125hp minus 15% loss) at the wheels or would we see 110hp.
What I'm asking is if the drivline loss will be a fixed amount? It seems to me that it would, but I've been known to be wrong.
yamarocket630 is offline   Reply With Quote
Old 11-29-2001, 05:27 PM   #2
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
Its both a fixed amount and a percentage. Ie if a 100 hp engine loses 15hp to driveline, a 1000hp will not lose 150(percent) or only 15hp. From everything Ive read that for moderate power increases its more accurate to look at driveline loss as a fixed number than percent. (IE if you gained 12whp with an intake, you probably gained like 12.5bhp or something like that.)
Anyone else with better info out there?
Midwayman is offline   Reply With Quote
Old 12-01-2001, 01:56 PM   #3
yamarocket630
Member#: 9436
05 Saab 9-5 Aero
Noone?
Old 12-01-2001, 03:53 PM   #4
p-car
Member#: 5534
2000 Cliffdiver RS
hmmm...
go here and click on "performance" in the left nav. The info is at the bottom of the page after all the graphs and discussion of hp vs torque.
http://www.mivec.co.uk/
p-car is offline   Reply With Quote
Old 12-01-2001, 04:49 PM   #5
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
Yamaharocket, like I said, for small power gains, assuming the drivetrain loss is a fixed number is a pretty good bet.
There was a good discussion about this awhile ago revolving around a low pressure turbo kit. Basically if you ran percentage loss, the calculated crank power was absurd, but using straight loss, It worked out to what the turbo should be producing.
Power Loss and loud knock from under the hood. STIdreamer17 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 10-05-2009 06:34 PM
Power loss and strange chirp/cough jagatek Service & Maintenance 7 12-30-2008 08:19 PM
Dysfunctional AC, massive power loss, and a phantom CEL t3hWIT Service & Maintenance 6 07-30-2008 04:11 PM
Help! Power loss and whining noise N00b xdionx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 08-24-2006 10:58 AM
Power Loss on a 9-2x with UTEC Stage 1 Map, Logs, Dyno Plots, Graphs included. antrey Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 12-16-2005 12:14 AM
