Old 02-02-2007, 06:46 PM   #1
nast
Member#: 124325
98 Forester S
Default Problem with Idle Air Controller
After turning the car off the idle air controller makes a strange humming/buzzing noise. If I unplug it the noise stops. If I plug it back in while the car is off the noise does not start again. If I put the key to the on position without starting the car, the noise starts again. The fast idle and idle speeds are pretty good. The idle does jump around a bit when in fast idle mode though.
Does this mean the sensor is broken or is it a control related issue?
nast is offline   Reply With Quote
Old 02-03-2007, 05:32 AM   #2
06grayrex
Member#: 116132
2006 wrx tr Stage II
sgm Jorge tuned -RIP :(
Have you tried cleaning the IAC? You should be able to take out the IAC and clean the plunger and the housing it sits in. It maybe gummed up and stuck and that why your hearing it b/c it is trying to actuate. Check the wires that plug into it to make sure one is not grounding out, or is shorted to another power source. If that fails then I would replace it, and go from there.
06grayrex is offline   Reply With Quote
Idle Air Control Valve: Anyone had this replaced? IceClimber Service & Maintenance 7 04-04-2015 05:33 PM
Idle Air Controller Yotsuya Normally Aspirated Powertrain 15 06-27-2004 07:56 PM
WRX Idle/Air control valve djerickd Private 'Wanted' Classifieds 11 12-02-2003 11:37 AM
Idle Air Controller SubaruImpreza_power Normally Aspirated Powertrain 3 09-19-2003 02:04 PM
idle air control valve, after a turbo mod mild_se7en Normally Aspirated with bolt-on Forced Induction Powertrain 1 08-10-2002 07:45 AM
