Old 05-27-2008, 10:01 AM   #76
Prosport Gauges
Member#: 124196
We tested this on our STI with a new oil change and that is normal readings for idle and we saw 90-100 WOT.
Prosport Gauges is offline   Reply With Quote
Old 07-31-2008, 11:11 AM   #77
Cbias1717
Member#: 185820
04 Srt 4
hi im new to the forum.. helping a friend with some gauges that he wants to install on his 08 wrx.... not really having any luck finding mounting solutions. can someone point me in the right direction??? He has a - pillar airbags to that threw my first thought out the window
Cbias1717 is offline   Reply With Quote
Old 07-31-2008, 11:16 AM   #78
ryan_west06
Member#: 139045
05 STI SnowmanTune
There is plenty of mounting solutions! steering wheel, center pod, cluster pod....
ryan_west06 is offline   Reply With Quote
Old 07-31-2008, 11:52 AM   #79
Cbias1717
Member#: 185820
04 Srt 4
i understand that there are plenty i'm new to the Subaru world and don't know where to get them or which ones to go with. Any links?? and where are people finding the best luck on install? the easier the better!!!
Old 07-31-2008, 03:09 PM   #80
LastResort
Member#: 99289
http://forums.nasioc.com/forums/showthread.php?t=255488
Work from the last page back, as many of the first post are missing pictures.
LastResort is offline   Reply With Quote
Old 09-07-2008, 12:44 AM   #81
Impreza_R34
Member#: 186935
2004 Impreza OBS
Green/Gold
I've looked at the Defi website and it seems you cannot buy off of that site. I was just wondering what site you guys have bought all of your Defi equipment off of.
Impreza_R34 is offline   Reply With Quote
Old 09-07-2008, 08:53 AM   #82
Prosport Gauges
Member#: 124196
If you want defi's you can start at http://www.tein.com/
thay are the US importer.
Old 09-07-2008, 09:02 AM   #83
IAG Performance
Member#: 158123
You can look at your local trusty performance shop web site and should get a good deal that way. Also, with you being in PA, if you shopped somewhere close, you would get the gauges in one day.
Regards,
JJ
www.iagperformance.com
IAG Performance is offline   Reply With Quote
Old 09-07-2008, 03:02 PM   #84
Impreza_R34
Member#: 186935
2004 Impreza OBS
Green/Gold
Regards,
JJ
Haha, ya when I posted that I was only looking at the 08's, then I thought gauges are universal...so I went to the 06-07 STi and it hit me, I need to pay more attention and think a little bit. Your going to be getting a lot of business from me in the future.
Old 09-25-2008, 12:01 AM   #85
gopsu
Member#: 96448
02 WRX VF34
can you please add normal gauge reading for AFR gauge? Thanks!
gopsu is offline   Reply With Quote
Old 09-25-2008, 07:03 AM   #86
cucamelsmd15
Member#: 122980
2010 F150, 2013 CX-5
92 Miata 15 TTF/PTF/E3
There is no normal gauge reading for an AFR gauge.
cucamelsmd15 is offline   Reply With Quote
Old 09-27-2008, 07:55 PM   #87
aferrari88
Member#: 174581
2010 Ferrari 458
Red
Originally Posted by Unabomber View Post
Boost: 11.9 PSI max 2008 WRX, 11.6 PSI max 2006/2007 WRX, 13.5 PSI max 2001-2005 WRX, 14.5 PSI max STi.
Oil Pressure: 100 PSI cold, 20-40 PSI normal.
Oil Temperature: Cold = outside temperature, 220 to 260 F normal
Coolant Temperature: Cold = outside temperature, 170-200 F normal.
Fuel Pressure: 30-48 PSI normal.
EGT: 1400 F normal cruising, 1600 F during spirited runs
Now this may seem like a noob thing to ask but lets say that (for instance) my fuel pressure gauge running low or really high. Are there common answers as to why this may be happening?
Now replace fuel pressure gauge with any of the other gauges with either a high or low reading. (This is where the noob part kicks in) Are there common answers to why any of the aforementioned gauges may be high or low?
The reason I ask is, I would like to have a gauge setup one of these days, but I would want to actually know what a bad reading is telling me (or what a bad reading might be telling me). Thanks in advance.
aferrari88 is offline   Reply With Quote
Old 01-19-2009, 02:09 PM   #88
Scott_2.5TS
Member#: 163806
Hi, i searched aorund a bit but couldn't find anything
I'm only getting a boost gauge (at least for now), and was wondering where's the easiest place to mount one? without ripping apart too much
A pillar single pod Vs. steering column Vs. VMR's in vent gauge Vs. Subiegal pod
thanks
Scott_2.5TS is offline   Reply With Quote
Old 01-19-2009, 02:24 PM   #89
DustinTarditi
Member#: 139798
2005 WRX Wagon
Single pod and SubieGal pod are pretty similar in location.
Steering column is easy to route everything to, also.
I'm not a fan of anything in my vents, personally. I've seen some slick installs, but I like my heat & cool air with nothing blocking the way. :-)
If you think you will be getting more gauges, I like the clean, factory look of a gauge pod that replaces the clock. I have a WRXtra and I've gotten a lot of compliments on it - it looks OEM.
DustinTarditi is offline   Reply With Quote
Old 03-13-2009, 11:32 PM   #90
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
Does the RS/i have similar wiring to the WRX/STi as far as lighting goes? Should it have the unused connector behind the radio head unit that is mentioned as a good place to get gauge lighting spliced to? its for my 07 2.5i and a couple STRI DSD's. cant find anything about the RS/i's on this subject.
Old 03-15-2009, 10:43 AM   #91
dankjeweler
Member#: 40720
03 wrx/jdm 6mt
been looking around and cant seem to find. anyone know where to get the glove box gauge pod shown in the start of this thread? i can only find one that fits 52mm gauges. need one to fit my 60mm defi gauges.
dankjeweler is offline   Reply With Quote
Old 03-31-2009, 05:45 PM   #92
jasonspeed
Member#: 187971
03 Grocery Getter
subyshop.com
Dont' know if you're still looking butr I saw one on ebay yesterday.
jasonspeed is offline   Reply With Quote
Old 04-03-2009, 11:57 PM   #93
Web Foot STi
Member#: 39086
2004 STi
Anyone know of a wide band A/F gage that matches an '04-'07 STi cluster? Preferably in 60 mm dia. Oh boy have I looked!
Web Foot STi is offline   Reply With Quote
Old 04-04-2009, 08:55 AM   #94
Prosport Gauges
Member#: 124196
Our 60mm Premium Series Amber/White Wideband AFR kit comes out April 15th.
Those match the STI cluster !
Old 04-10-2009, 02:59 AM   #95
renhoek
Member#: 71339
1995 WRX STi RA
1995 WRX STi LS1
Default Sandwich plate and pressure sensor
Snipped......What the heck is a sandwich adapter? It is a machined aluminum piece that goes in between your block and oil filter. It is pre-tapped to allow you to run oil pressure and oil temperature senders into it......
I just want to be real sure that I can run an oil pressure sender off my sandwich plate.
My sandwich plate has an inlet/outlet set up so I can run an oil cooler in line. The plate also has the 2 usual ports for attaching sensors but I'm just not sure I can sense pressure from here. I am thinking that if I am running an oil cooler off this plate, then the oil going to it may not be under the same pressure as what the engine sees.
Anyone know if mountin a pressure sensor here would give accurate readings, similar to say the oil plug under the intercooler?
renhoek is offline   Reply With Quote
Old 04-10-2009, 04:23 AM   #96
renhoek
Member#: 71339
1995 WRX STi RA
1995 WRX STi LS1
While I'm on this, does the oil filter see engine oil pressure or something lower? If it sees the same, then I expect the oil pressure sender being in the sandwich location is ok. If it's lower in the filter, then it is hard to see how the sender at the sandwich would give a good reading.
Old 04-10-2009, 07:26 AM   #97
Prosport Gauges
Member#: 124196
The oil filter adaptor plates can and do give you the same reading for oil press as the oil galley plug.
So yes, you can run OP off your oil sandwich plate.
Old 04-10-2009, 07:01 PM   #98
renhoek
Member#: 71339
1995 WRX STi RA
1995 WRX STi LS1
Thank you. I have connected the temp and pressure sensors up. Just hope that there's room for all this stuff under there
Old 04-11-2009, 03:22 AM   #99
Prosport Gauges
Member#: 124196
oh yeah, they will fit.
Old 04-14-2009, 08:00 PM   #100
MrSweet
Member#: 202436
2007 02 WRX Wagon
07 WRX sedan, 320 WHP
Here is the link to the install I did of a ProSport Premium Boost gauge in my 07 WRX... it took a bit of time to get it perfect, but well worth it. Feel free to PM me if you have questions!
http://forums.nasioc.com/forums/show...5#post26349175
MrSweet is offline   Reply With Quote
Pulley FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 111 06-11-2016 09:28 AM
Downpipe FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 322 05-18-2016 02:47 PM
Uppipe FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 378 12-27-2015 07:49 AM
Wheel FAQ: Read if you are thinking of buying some! Unabomber Newbies & FAQs 134 09-02-2015 04:05 AM
