Welcome to the North American Subaru Impreza Owners Club Sunday July 5, 2015
Old 04-15-2009, 04:59 AM   #101
Prosport Gauges
Member#: 124196
We also have a complete install video of our premium series gauges including the oil filter adaptor plate on our STI on the website. It is located on the amber/white premium page.
Prosport Gauges is offline   Reply With Quote
Old 04-15-2009, 04:00 PM   #102
ison031
Member#: 208244
2005 WRX
I just picked up a 05 WRX and it had a pillar cluster with oil pressure and vacuum/ boost. The oil pressure gauge works well (both light up with my lights); however the vac/ boost gauge needle just sits at 30 inhg. Its a mechanical gauge that runs a line through the firewall to a black box next to the turbo. From that box, the pressure line runs near the wastegate? and is tapped into one of those lines. Been tampering with the connection and have gotten the pointer to move although its all over the place... any ideas on what going on?
btw its an Autometer make ---- Cobalt series
ison031 is offline   Reply With Quote
Old 04-15-2009, 06:58 PM   #103
Prosport Gauges
Member#: 124196
maybe their is a leak in the line. With a mech gauge it should sit at 0 with the car off. Where does it sit?
Old 04-15-2009, 09:53 PM   #104
ison031
Member#: 208244
2005 WRX
when i first get in after its set for awhile its at 30inhg --- but after it warms up and i start to drive the pointer starts moving. It will idle any where from 11 inhg to 2 lbs boost.
Old 04-16-2009, 09:34 AM   #105
Prosport Gauges
Member#: 124196
Sounds like a boost leak to me.
Old 06-29-2009, 07:53 PM   #106
tekfoc
Member#: 21392
2014 45 AMG MB
WHITE /MB C300 4MATIC
any reason why you guys did not add the daisy chain feature to your pro sport premium wide band .
I was kind of pissed off that I had to make a custom wiring connection so I can just plug it in to my pro sport premium boost gauge for power .
tekfoc is offline   Reply With Quote
Old 06-30-2009, 07:54 AM   #107
Prosport Gauges
Member#: 124196
Yes, because the bosch heated O2 sensor draws so much power that the power running through the gauge is not enough.
Old 06-30-2009, 09:19 AM   #108
tekfoc
Member#: 21392
2014 45 AMG MB
THANKS , what kind of affects would you have if I did daisy chain it with premium boost gauge .
affect meaning how would the wide band behave if it was done .
Old 06-30-2009, 12:08 PM   #109
Prosport Gauges
Member#: 124196
If you wanted to do that run the wideband first in the chain
Old 06-30-2009, 12:43 PM   #110
tekfoc
Member#: 21392
2014 45 AMG MB
thanks , thats what I did.
wide band works fantastic and looks great .
Old 06-30-2009, 01:51 PM   #111
Prosport Gauges
Member#: 124196
Sweet !!
Old 01-18-2010, 04:21 PM   #112
silverf0x
Member#: 147664
2015 WRX Limited
Bump for Fuel Pressure Gauge impressions/install/comments ..
silverf0x is offline   Reply With Quote
Old 04-30-2010, 08:08 PM   #113
acmw
Member#: 215718
bump because i need the same!
searched and found nothing
acmw is offline   Reply With Quote
Old 05-03-2010, 02:34 PM   #114
Prosport Gauges
Member#: 124196
We will have these T-fitting avail. in a couple of weeks to put inline and make fuel press. gauges easier to install.
Old 06-18-2010, 01:17 AM   #115
menski
Member#: 249079
2006 STi
I want put 3 extra gauges on my car
boost, oil pressure, and exhaust or fuel pressure
which one is more important exhaust temp. or fuel pressure?
menski is offline   Reply With Quote
Old 06-18-2010, 01:17 AM   #116
menski
Member#: 249079
2006 STi
bump!
Old 06-18-2010, 04:03 AM   #117
Evilchargerfan
Member#: 183529
i wanna help teh
haters ... love life ...
they are both important so you should just buy both to be on teh safe side!!!
Evilchargerfan is offline   Reply With Quote
Old 06-18-2010, 08:09 AM   #118
Prosport Gauges
Member#: 124196
I think EGT is more important....
Old 06-20-2010, 03:51 PM   #119
IllustriousBrown
Member#: 200355
2006 WRX Wagon
WRB, Cobb Stage 2
Are there any good photos/instructions for installing oil pressure at the alternator. All the links here point to under the intercooler, which I just did, only to have the stupid galley plug strip like crazy. I'm in an 06 WRX wagon. Any help on what the plug looks like and how to get the alternator out of the way for the install would be very helpful.
IllustriousBrown is offline   Reply With Quote
Old 06-20-2010, 04:52 PM   #120
Prosport Gauges
Member#: 124196
Do you mean Oil Pressure.. whose galley plug are you using ?
Old 06-20-2010, 05:59 PM   #121
IllustriousBrown
Member#: 200355
2006 WRX Wagon
WRB, Cobb Stage 2
Yes, I mean Oil Pressure. Sorry about that. Everything I Have is prosport.
Old 06-21-2010, 01:59 AM   #122
Evilchargerfan
Member#: 183529
i wanna help teh
most important prosport gauge ever made:
Old 09-15-2010, 02:38 AM   #123
04EckoSti
Member#: 247135
2014 WRX
ISM
great write up
04EckoSti is offline   Reply With Quote
Old 09-26-2010, 11:40 PM   #124
UberSuber
Member#: 258884
2005 WRX
This post is exactly what I was searching for. I was going with Boost, A/F Ratio, and EGT. Why Oil Pressure instead of A/F ratio? Is that based on the assumption that if your A/F is off, the EGT will show it? Maybe, but probably not off boost, right? For instance, my new (to me) and highly-modified '05 WRX is blowing a little smoke when I take off, and backfiring on shift. I'm chalking that up to an aftermarket BOV (thanks to another helpful post), and thinking of getting a stocker to install. Anyway, would an EGT guage show a low a/f ratio under those conditions? By the time the Oil Pressure drops low enough for you to notice a problem (assuming you are staring at the guage all day), wouldn't it be kinda too late? Just like with the worthless light in the guage cluster that comes on to tell you that you just hosed your engine?? Fool added a STI turbo, STI intercooler, TurboSmart BOV, Downpipe, Exhaust, and a bunch of other stuff, and then tunned it with a COBB unit, but not one freaking guage to monitor it all!? Prolly shoulda let it go, but it seemed like a steal. I'm going shopping...
Da'oh! Gauge, tuned... can't type, or spell, not sure which!
UberSuber is offline   Reply With Quote
Old 09-26-2010, 11:42 PM   #125
UberSuber
Member#: 258884
2005 WRX
Oh yeah. Another question. Will any A/F gauge work with a wideband sensor? I want the prosport gauge since it seems to match my STI cluster pretty perfectly, but I plan on installing a REAL wideband unit. Will it work?
Ok, I see they sell a wideband gauge too. Missed that at first. I wonder how good the Wideband kit with the Bosch 5-wire sensor is. Seems inexpensive? Aren't wideband sensors ridiculously expensive??
Pulley FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 110 07-02-2015 11:25 PM
Wheel FAQ: Read if you are thinking of buying some! Unabomber Newbies & FAQs 133 05-27-2015 11:23 PM
Downpipe FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 313 05-15-2015 12:23 AM
Uppipe FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 373 04-27-2015 09:41 AM
