Old 03-19-2007, 05:00 PM   #26
05 wrx sti
Member#: 106596
2005 CGM Sti 23psi
GT35R+METH 471whp/448trq
+1 helpful info!
05 wrx sti is offline   Reply With Quote
Old 03-21-2007, 09:52 PM   #27
strohausii
Member#: 26770
'02 WRX
midnight black
+ subygirl single gauge pod
spa gauges (esp. dual digital w/ data & warning light):
http://www.spatechnique.com/
strohausii is offline   Reply With Quote
Old 03-24-2007, 11:27 PM   #28
turbo_dude
Member#: 144331
Found this post through a link on another forum. Curious why you chose to leave out all the popular digital gauges (Cyberdyne, Dakota, VEI, etc).
turbo_dude is offline   Reply With Quote
Old 04-03-2007, 11:10 PM   #29
R6_rider
Member#: 138768
2013 evo x
white
my oil pressure gauge only reads 20-40 when i sit at a light and reads at a 100 when im driving is this correct?
R6_rider is offline   Reply With Quote
Old 04-09-2007, 04:06 PM   #30
racerpj
Member#: 96523
05 STi
Rally Blue
This FAQ is missing a link for fuel pressure gauge install. search is taking a long time. I'm sure I'll find it eventually, but it would be helpful.
racerpj is offline   Reply With Quote
Old 05-12-2007, 11:02 AM   #31
Foska Oats
Member#: 144081
2003 WRX
Nuff Nuff respect Unabomber.
you the man
Foska Oats is offline   Reply With Quote
Old 05-17-2007, 02:49 PM   #32
RootUsr
Member#: 39652
2007 WRX TR (UGM)
R.I.P d00m Wagon
This post was awesome I got just what I needed (simple boost gauge, prosport) and managed to get it installed by myself in just under a few hours (never worked on a WRX before, so it was interesting)
Thanks again!!
(With the supplied links, I even managed to do it without removing the intercooler!)
RootUsr is offline   Reply With Quote
Old 05-26-2007, 04:49 AM   #33
mintcycles
Member#: 149794
Default Wow...
I thought my boost guage was excessive..
mintcycles is offline   Reply With Quote
Old 05-27-2007, 11:00 AM   #34
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Those are NOT popular on Subarus. Plus this post is not the end all/be all of every manufacturer.
Wish I had one, if you find a write up, please post back with it.
Old 05-27-2007, 08:59 PM   #35
strohausii
Member#: 26770
'02 WRX
midnight black
Btw, Cyberdyne makes a pretty convient Voltage guage (digital as most of their line), that just plugs into the cigarette/acc plug. Big plus with this is that you can just move it from car to car if you need to check something out.
Old 07-05-2007, 02:59 PM   #36
Foska Oats
Member#: 144081
2003 WRX
Has anyone used the Prosport Air/Fuel gauge with the volts meter in the middle. If so how long have you been running it and has it give you any problems?
Old 07-23-2007, 08:17 AM   #37
Prosport Gauges
Member#: 124196
That is a very popular gauge.. and simple to install. power, ground & one wire to your output wire off your stock O2 sensor. They deliver instant readings direct from your cars computer/O2.
Prosport Gauges is offline   Reply With Quote
Old 07-31-2007, 02:05 PM   #38
boarder916
Member#: 154204
Some of the best information I've found so far on this site. Keep it up.
boarder916 is offline   Reply With Quote
Old 07-31-2007, 03:10 PM   #39
Prosport Gauges
Member#: 124196
yeah, big props to the unabomber for taking the time to put all this together.
Old 08-06-2007, 10:19 PM   #40
MULEZSTI
Member#: 142487
2006 Impreza WRX STi
Element Tuning Crew Chief
Can anyone answer the oil press question. Mine reads 40-50 psi at idle and 95 to 100 psi when I'm on any form of gas( Hard or coasting). Also I was told that you should wait to drive your car hard until your oil reaches 160 F. But here it says 220. It takes a while for my oil to reach that temp. Will it hurt if I start getting on it at 160 F? BTW Excellent thread. I just bought A BDL fuel rail that has a spot for the sending unit on my Fuel press gauge. Can't wait for it to go in. Thanks for the help.
MULEZSTI is offline   Reply With Quote
Old 08-07-2007, 08:05 PM   #41
SoloSTI
Member#: 113854
2004 Impreza STI
This thread is great, Prosport gauges are just like Megan racing coilovers, more bang for your buck.
SoloSTI is offline   Reply With Quote
Old 10-15-2007, 07:17 PM   #42
i am sigma pi
Member#: 127806
some what?
i am sigma pi is offline   Reply With Quote
Old 10-20-2007, 02:51 PM   #43
X-Factor
Member#: 101720
2006 Evo IX GSR/SSL
Electric Blue
Is there any reason I can't install EGT into the DP? exhaust is totally catless too.
X-Factor is offline   Reply With Quote
Old 10-21-2007, 12:25 AM   #44
Prosport Gauges
Member#: 124196
Most install in the DP, in fact most aftermarket Dp come with or can be ordered with a 1/8"NPT bung.
Old 10-21-2007, 08:56 AM   #45
cucamelsmd15
Member#: 122980
2010 F150, 2013 CX-5
92 Miata 15 TTF/PTF/E3
Yes there is a reason: Inaccurate readings.
cucamelsmd15 is offline   Reply With Quote
Old 11-10-2007, 12:10 PM   #46
Prosport Gauges
Member#: 124196
FYI
Next month we will have the full line of digital gauges available. Including a digital boost gauge that goes to 45 psi !!
Old 11-18-2007, 04:19 AM   #47
jsquar3d
Member#: 164073
2008 WRX STI
World Rally Blue
The "extra" wires that most previous model gauge install guides refer to isn't present in the 2008 WRX (at least, on my Premium model..). The wire color codes on the radio & a/c harness may be different as well (I'm new to Subaru..). I finished installing an electrical boost gauge by tapping into the fusebox.
Also the hole in the firewall specified in boost gauge install guides for previous models was not to be found, so I went with a large grommet on the passenger side that houses a ton of wires, and routed it under the dash to the driver's left side. The same hole might be there (there are two small grommets in roughly the same spot) but I found foam / paper insulation to be pretty thick.... I did hear the 2008 did a lot to lower the noise level inside...
jsquar3d is offline   Reply With Quote
Old 11-18-2007, 08:24 AM   #48
Prosport Gauges
Member#: 124196
nice clean install.
Old 12-03-2007, 03:57 PM   #49
extol1337
Member#: 129266
for a boost gauge, wouldn't tapping the line for the T fitting + vacuum line at the FPR be more accurate than the BOV line?
extol1337 is offline   Reply With Quote
Old 12-10-2007, 12:52 PM   #50
Beanboy
Member#: 4814
2005 LGT Wagon 5MT
Garnet Red Pearl
Have room for two 52mm gauges and a turboxs knocklight in my cubby pod on the Legacy. Boost is obvious, followed by either oil pressure or EGT.
My understanding regarding EGT as explained in the FAQ here is that it is a good way to see if you are experiencing lean conditions as temps will rise.
Will monitoring the stock knock microphone with a knocklight overlap what the EGT is telling me in terms of detecting lean situations?
In what situation would the EGT rise to dangerous levels without the event being picked up by the knock sensor?
Just trying to figure what is the better combination for keeping an eye on things with a 20G going on, thanks!
Beanboy is offline   Reply With Quote
Downpipe FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 325 09-12-2016 12:22 AM
Uppipe FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 386 09-10-2016 06:42 PM
Pulley FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 116 08-01-2016 10:03 PM
Wheel FAQ: Read if you are thinking of buying some! Unabomber Newbies & FAQs 134 09-02-2015 04:05 AM
