#51 |
Member#: 159177
Vehicle:'07 WRX Wagon Ltd. WRB |
#52 |
Member#: 136837
SCIC
Vehicle:07 WRX TR |
Is it necessary to get gauges when going stage 2 or doing any minimal modding ?
#53 |
Member#: 134465
noob here sorry if this is a repost but i cant find a pod for 60mm defi gauges this spot. are 52s the only size made for that location? ive serched ebay and cant find anywhere else to look. I have a 2004 sti
http://www.daddysscp.com/dcart4/prod...&cat=13&page=3 |
#54 |
Member#: 132286
NWIC
Vehicle:2006 STI sgm |
Lo-Tek, they have single, double, and triple pods in 52mm or 60mm.
#55 |
Member#: 168099
South East
Vehicle:2004 impreza sti wrb |
i was wondering about the gauges on the steering column.... i see them on ebay but they are listed only for wrx. that should work on my sti right? any brand in particular i should aim to get?
thanks, sid |
#56 |
Member#: 124196
Yes the WRX gauges will work for your sti.
#57 |
Member#: 124196
I think Omori is out of business. no response to emails or phone calls ??
#58 |
Member#: 131944
BAIC
Vehicle:2002 WRX Wagon |
any ETA on the prosport Wideband A/F gauge? Been kinda waiting for it to become available...
#59 |
Member#: 124196
Sorry bro, no exact release date yet. We are now working with Bosch to get the programming down for the O2 sensor.
#60 |
Member#: 140147
Vehicle:02 B12S 04Odyssey I make minivans look hot |
Ron,
Tried your link for the Omori gauge and it locked up. How about this site...it also lists the authorized US vendors http://www.omoriusa.com/ actually tried every vendor listed and none have any omori products. Looks like they MAY be out of business or going through some transition (per Prosport's post above) ![]() edit: just noticed this was from LAST february . Ah well, still applies ![]() Last edited by The Motel Fella; 02-13-2008 at 03:32 PM. |
#61 |
Member#: 163202
autometer is the best
#62 |
Member#: 168099
South East
it would be nice if someone can take a picture of the clock harness and tell us which wire is what.... that should provide, power, ground, constant and dimmer.
thanks, sid |
#63 |
Member#: 122980
South East
Vehicle:2010 F150, 2013 CX-5 92 Miata 15 TTF/PTF/E3 |
#64 |
Member#: 172864
NESIC
Vehicle:2004 WRX STi silver |
is it just me or does the clock not dim. i put in a boost gauge and i had to tap into wires near my ic sprayer now they dim with my gauges.. super easy to get to and makes it really easy if your mounting the gauge on the steering column if anyone wants tips let me know
#65 |
Member#: 159829
SCIC
Vehicle:07 STI OBP |
Unabomber,
As you should probably know already, this thread has a lot of useful infromation. It helped a novice like myself understand all aspects of gauges very significantly. Thank you Unabomber. Now i have to figure out how to wire that dam EGT gauge. More reading ![]() |
#66 |
Member#: 158901
Vehicle:02 BuGeYe I got more ƒlush than a toilet |
Whats the difference between imperial and metric? Which is better and how do i read the guages to make sure my car is running good, so i dont overheat anything? I plan on running Boost,EGT,and Oil pressure. Whats the safe zone that my guages should be reading?
#67 |
Member#: 172736
When you replace clock with a gauge pod, is there any problem with the airbag indicator? I know it will be gone, but does it cause any electrical problems?
#68 |
Member#: 122980
South East
#69 |
Member#: 147219
Vehicle:07 WRX Blue |
Some great info!
#70 |
Member#: 30364
NWIC
Vehicle:2005 Devilish STI Angelic white |
Are there any instructions or tips on using the vacuum line in the cabin of an existing OEM boost guage for an electronic aftermarket boost guage? I have an OEM boost guage and want to run a Greddy one... And I am thinking that there is no need to go through the firewall. Am I right?
Sorry if this was covered already, but I didn't see it through any of the links or by searching the forums. |
#71 |
Member#: 163842
NESIC
Vehicle:2002 WRX Platinum Silver Metallic |
I may be blind but I couldnt find an install guide for the Prosport electrical boost gauge... i want to install it in my 2002 wrx, but the included instructions im not to sure... any help?
#72 |
Member#: 124196
Sure, What color/series electric boost do you have so I instruct you??
#73 |
Member#: 120057
Vehicle:2004 "Bugeye" WRB |
Well I just bought the Prem boost, and the Performance oil pres. Any help would be great
#74 |
Member#: 124196
Premium boost:
red wire: constant ground White wire: 12v acc. power black: ground orange: headlights:~ a power source that gets 12v power when the headlights are turned on. Perf. OP: Red wire: 12v acc. power white: 12v acc. power black: ground orange: headlights Green: sender (G terminal on sender) As you can see they wire up differently. You can wire all like wires to the same source (ex. all white wires together..) |
#75 |
Member#: 151390
International
| Thread Tools | |
| Display Modes | |
| Pulley FAQ: Read if you are thinking of buying one! | Unabomber | Newbies & FAQs | 103 | 05-15-2013 01:15 AM |
| Uppipe FAQ: Read if you are thinking of buying one! | Unabomber | Newbies & FAQs | 309 | 04-23-2013 03:16 PM |
| Wheel FAQ: Read if you are thinking of buying some! | Unabomber | Newbies & FAQs | 97 | 04-17-2013 01:52 AM |
| Downpipe FAQ: Read if you are thinking of buying one! | Unabomber | Newbies & FAQs | 283 | 03-15-2013 06:56 PM |
